Old 11-29-2009, 07:42 PM   #61
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,426
Originally Posted by markjenn
I see lowering links from this vendor but not raising links. I've been looking for a vendor of steel raising links for the DL650 for a couple years but haven't found one.
- Mark
I think it'd be cheap enough to have a local machine shop make some up for you. Show up with one of your stockers and tell them to make it of the same material, but shorter. I have a set of 1" aluminum raising links I can measure center to center for you if you need.
Where the fuck...
Where the fuck is the bike?
You gotta be shitting me.
Where the fuck is the road?
Old 11-29-2009, 07:43 PM   #62
markjenn
Oddometer: 10,397
I'd be surprised if any machine shop would do this for less than $150+ on a one-off basis. Not worth it to me for that.
- Mark
Old 11-29-2009, 08:05 PM   #63
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,426
- Mark
To me, that seems high. I'd imagine that 50-60$ is what I'd pay for that at my local guy. Compared to some of the one off stuff I've had made these things are simple. Hell, you could probably save some money and do the shaping your self with a grinder.
Where the fuck...
Old 12-01-2009, 11:07 PM   #64
Jud OP
Jud's Avatar
Oddometer: 2,291
Yep,,, jig saw with metal blades, a drill and a grinder.
Pics- http://s563.photobucket.com/albums/s...eon/?start=all
Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/
Endeavor to Persevere
Blue Skies Coming
Jud is offline   Reply With Quote
Old 12-01-2009, 11:49 PM   #65
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,261
raising links - $34
http://burkhartcycle.com/store/index...&products_id=2
this guy did it. past tense & has some info
http://www.ofb.net/~sethml/motorcycle/vstrom/links/
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 12-02-2009 at 12:03 AM
eakins is online now   Reply With Quote
Old 12-02-2009, 09:47 AM   #66
markjenn
Oddometer: 10,397
The vendor of steel links does have raising links on Ebay - they are a little hard to find in his store.
http://cgi.ebay.com/ebaymotors/ws/eB...m=280368971242
I just ordered some and will give them a try. Thanks for pointer....
- Mark
Old 12-02-2009, 05:24 PM   #67
robertothemexican
let´s ride !!
robertothemexican's Avatar
Oddometer: 54
which oil and amount for the rear shock ??
waz up guys !!
just pull out the rear shock out of my vstrom 1000cc 2007, it has 20,000 miles and i ride most of the time 2 up.
the shock need new oil and nitrogen !! how much does oil does the shock needs and what kind do u recommend? i would like it harder ...
thanks
Roberto de la Garza
xr 650l 05
voyager 1200 02
brute force 750 cc(sold)
robertothemexican is offline   Reply With Quote
Old 12-02-2009, 08:24 PM   #68
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,426
Originally Posted by robertothemexican
waz up guys !!
thanks
You want a 450$ sasquatch shock rebuild/full modification.
LINK
Sasquatch is a member on ADV, shoot him a PM
Where the fuck...
Old 12-03-2009, 01:03 AM   #69
robertothemexican
let´s ride !!
Oddometer: 54
LINK
thanks boon, i was thinking of him, and do email him, but i leave in mexico and is to much hassel and expensive to mail things from here, so a mechanic is doing it for me... but i am afraid he wont know that correct amount and kind of oil.
Roberto de la Garza
xr 650l 05
voyager 1200 02
Old 12-03-2009, 12:35 PM   #70
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,484
Awesome!
Originally Posted by glitch_oz
Here's a K6/ 650
...and the 2 thou's at either end
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 12-07-2009, 11:34 PM   #71
TRAVELGUY
Old Traveler
Oddometer: 636
+1
25,000 plus miles aluminum lowering links. Many of those miles pot holed Central American road bottoming both ends. No problems when properly installed and torqued.
When properly torqued, the hole of the link shouldn't be taking much if any of the loads.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY screwed with this post 12-07-2009 at 11:43 PM
TRAVELGUY is offline   Reply With Quote
Old 12-07-2009, 11:42 PM   #72
TRAVELGUY
Old Traveler
Oddometer: 636
Leverage doesn't change. The lowering or raising links end at the pivot point of the L link. The L link attaches to the frame and the shock. That determines the leverage on the shock.
Originally Posted by mousitsas
Since leverage changes, wheel travel should change too, IMHO.
If eg shorter links result to an 'effectively' 10% stiffer spring, then that should mean that the wheel travel is now 10% less. Only reason the spring seems stiffer, is because the same spring travel works against a lesser wheel travel.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
Old 12-12-2009, 03:23 PM   #73
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,426
But as the angle of the dogbone, link and swingarm interface changes, so does the leverage.
Looking at it it would seem like shortening the dog bones would put the interaction of the swing arm and the dog bones closer to perpendicular making the initial movement of the swing arm easier, sort of decreasing spring rate.
It's a complicated piece of geometry to be sure, but I do think changing the link length would change the rising rate aspect of the linkage a little bit. If I had to guess, I'd say shortening the dog bones, and thereby raising the rear would give you a little more suspension travel, and a little leverage on the link. All of it being pretty small changes.
Where the fuck...
Old 12-12-2009, 06:00 PM   #74
Jud OP
Jud's Avatar
Oddometer: 2,291
The internal dimensions of the shock determine travel "most" of the time. I do not see how changing a link {with-in reason} can change travel. Change the effective spring rate? Yes,,, travel no. JMO though.
Blue Skies Coming
Old 12-12-2009, 06:56 PM   #75
Audacious Nick
Forever indecisive
Audacious Nick's Avatar
Oddometer: 656
Mods you could do for better offroadability:
KTM 950SM forks, or any dirt bike forks if you don't mind a single caliper
Adjust rear linkage to fit a dirt bike rear shock in. Doing this would increase ride height and travel, making it much more offroad capable.
Bikes:
2006 Husky SM610
2000 Honda Superhawk
Audacious Nick is offline   Reply With Quote
Times are GMT -7.   It's 10:37 PM.
