11-12-2009, 11:04 AM
#1 |
über-n00b
Oddometer: 285
Airhead R100 horrible smoke at cold start
Inmates! Opinions solicited!
Specs: 1983 R100RT Stored overnight in the garage On centre stand Fuel valves off Symptom: Left (when astride the bike) cylinder burns clean at start up but smokes FURIOUSLY after about 1-2 seconds of running. Right cylinder burns (relatively) clean upon start up. If I was storing it over night on the side stand, I could buy the "oil lays in that cylinder" song. But I'm not, and it's sitting upright all night. It DOES clear, and if started up later on (i.e. warm start) no problem. This just started a few days ago. It also seems to be using a bit of oil. I know, it's a boxer, live with it... My thoughts, and feel free to tell me what an idiot I am for this line of reasoning: Over night, everything is cold, and a valve guide or valve stem contracts. This opens up a clearance into the cylinder. At start up, things are relatively dry and away it goes. Oil gets pumped into the top end (do boxers actually have "TOP" ends?) and out this opening into the combustion chamber. Smoke like hell... Warms up, things expand, seals back up and Bob's your uncle. Also, cold is in the -5 degree C range... Tonight when I get home, I'm going to pull the plugs to take a look. I also should get a compression tester sometime. I'm wondering if at 107000 km with an unknown engine I'm due for a top end rebuild.
Larger than life and twice as ugly! My photos: stewie.smugmug.com |
11-12-2009, 11:31 AM
#2 |
British
Oddometer: 753
If you're lucky, it may only be the valve guide seals
Or at worse, the guides! |
11-12-2009, 12:22 PM
#3 | ||
airhead or nothing
Oddometer: 7,976
"punkrocks what it's all about" - J. Strummer Quote:
11-12-2009, 12:49 PM
#4 |
Knows all - tells some.
Oddometer: 12,969
This sounds too simple, but in many cases where there is a mix of cool weather and humidity and the bike has not been ridden enough to get all the moisture out of the exhaust system, it will blow smoke-like vapor like a sumbich until all the moisture in the mufflers is gone.
Odd thought, but could well be the case, especialy if this seems to be a brand new problem.
- "The turd follows the fart as surely as the rain follows the plow." Emily Bronte |
11-12-2009, 01:04 PM
#5 |
Grin!
Oddometer: 4,441
That's a thought!
See if you can tell whether it is smoke, or steam. Though why one side would have more condensate than the other.... If it is oil, my guess is that it continues to burn the same amount on the left side, but when it is hot, the oil is burned up more, leaving less to "see".... Your idea of pulling the plugs should give you additional clues/information.. |
11-12-2009, 01:07 PM
#6 |
Oddometer: 609
You only put oil in upto the halfway mark between bottom & top mark's on dip stick? Otherwise it'll just burn off any oil above.
Karl. |
11-12-2009, 01:46 PM
#7 | |
is a bit slow sometimes..
Oddometer: 66
11-12-2009, 02:00 PM
#8 | |
Oddometer: 12,969
11-12-2009, 02:12 PM
#9 |
über-n00b
Oddometer: 285
Results of plug pull
Gentlemen and ladies,
Pictures to follow as soon as I can find my %!@#& cable for my camera... Card reader is still at work. Prior planning prevents piss poor performance I guess. Verbal (textual?) description: Left plug was somewhat brown, darker shade than lighter. I wouldn't consider it too bad but my prior experience has been with a 2 stroke that was running rich on the oil pump so I may be biased. Right plug was lighter, had a grey/white patch on the outside of the bend of the electrode. Personally I would think it's running too lean on that side, but again my previous experience is probably biasing me. So I set up the camera on the tripod, and started recording. Its always easier to SHOW what is happening than to describe it. The bike had sat for 22 hours from when I got home last night until just now when I tried to demo it. Of course, being a bike with "personality and character" it didn't do anything untoward.... ![]() Data point: It's been sitting in the unheated garage all day. Currently it's in the 10 degree C range, and considerably warmer than when it USUALLY manifests this behaviour. So, we're back to condensation... Possibly. Think I might just live with the "personality" and take my ribbing when I smog out the parking lot in the spring and fall... If I can catch it tomorrow morning I'll post the results. Just keep telling myself that personality and character is good in a bike. Otherwise it's a Tupperware clad two wheeled refrigerator...
11-12-2009, 02:15 PM
#10 | |
über-n00b
Oddometer: 285
11-12-2009, 03:02 PM
#11 |
mostly listens
Oddometer: 510
Just thinking out loud here...
You have a '83 which has the "new" style airbox, right? The breather might be different, but I'm wondering about the crankcase check valve and breather hose(s). The older style motors (with the round air filter) used a fiber washer and coil spring style check valve for the breather. These could get tired and allow excess crankcase vapor to be vented thru the breather hose(s) and into the airbox. This check valve was updated, at some point, to a reed valve which works much better. I also think the standard models used one breather hose which was routed into only one intake tube, while the S and RS models had a "T" and twin hoses - one into each intake tube. This might explain why only one side smokes. In any event, the check valve is located under the starter cover and is fairly easy to access. _jay
Ride it. Maintain it. If it breaks, Repair it. Repeat. |
11-12-2009, 04:04 PM
#12 | |
Oddometer: 12,969
I really think you need to take the bike for a longish (20 mile) ride and blow the snot out of it, put it on the center stand and see if the problem repeats. If it is as bad as you say the area should reek of oil; thus I am still betting on condensation. It takes a long time to get everything heated up enough to completly get the moisture out of the muflers (actually, you can't ever get them totally dry, but you get the idea).
11-12-2009, 04:55 PM
#13 | |
airhead or nothing
Oddometer: 7,976
So it looks like no one asked...
What color is your smoke? Also, FWIW, the stock BMW vavle guides on the early 80's bikes are soft garbage... my exhaust guides were totally played out at 20,000 miles!
11-12-2009, 04:56 PM
#14 | ||
airhead or nothing
Oddometer: 7,976
11-12-2009, 05:21 PM
#15 | |||
über-n00b
Oddometer: 285
But when warmish, no problems. More on smell and colour momentarily...Quote:
I dropped the bowl's on the carbs tonight just to see if there was anything settled in there. There wasn't actually. I'm really leaning more towards "it's the way the bike acts when it has better sense than the rider does about cold" kind of answer.
