11-14-2009, 05:02 AM
#31 |
now in Mt. View, AR
Oddometer: 588
I had the smokey start up on my /5. I cleaned out the choke units on each carb and the smoke went away.
insert meaningless phrase here.... |
11-14-2009, 11:33 AM
#32 | |
mostly listens
Oddometer: 510
). You will find some oil droplets in the breather tube, as a big twin moves a lot of air around in the crankcase.When you get around to it again, check out the internals of the crankcase breather. My '78 RS had the older one, which apparently doesn't work as effectively as the new style. The older one is a fibre washer and a coil spring, while the newer one is like a reed valve. My RS puffed quite a bit of oil when warm, and the new style breather virtually stopped it. Check an on-line parts fiche (like maxbmwmotorcycles.com) and view section 11, diagram 11_1725. Assembly #2 is the older style, and #3 is the newer replacement part. If you have the older one, try upgrading to the new one as it's only $30mumble bucks. If you already have the new style (and the diaphragm is intact) then I'll hush and let somebody more experienced speak up ._jay
Ride it. Maintain it. If it breaks, Repair it. Repeat. |
11-14-2009, 12:42 PM
#33 |
Further...
Oddometer: 5,146
A few thoughts:
The crankcase breather could be a problem (worn reed valve allowing a bit too much venting into the carbs). However, too much oil past the breather could also be caused by more serious problems such as worn rings (compression blowing past the rings, into the case and out the breather). When I had worn valve guides on my 78 R100S the most noticeable symptom was smoke on deceleration esp. going downhill (cut the throttle and the piston starts sucking through every possible opening such as the valve guides which sucks oil into the compression chamber). Hard tellin', not knowin'. A compression check is step one. Keep at it!
Forging ahead, down a false trail. |
11-20-2009, 05:24 AM
#34 |
über-n00b
Oddometer: 281
Sucess, of a sort
Inmates,
Post oil change/air filter change/cleaning of the breather system followed by 700 km at or above 110 km/hr (does that count as blowing the snot out of it?) and the bike hasn't acted up since... I'm not saying it's cured, since as soon as I do the problem will be back with a vengeance. Thanks one and all! Cheers! Craig
Larger than life and twice as ugly! My photos: stewie.smugmug.com |
11-20-2009, 08:05 AM
#35 |
Now with TURBO!
Oddometer: 5,477
A compression check will probably not show worn valve guides as the valves will probably still seal on the seats.
R bikes have guides that have alot of clearance and no valve seals. Check into new guides and valves if you find this to be the problem. Matt at Motor West in Milw. WI. Sells some "tighter" guides and seals. (high quality) I am sure others sell the same ones. But give Matt a call.
A fight to the death between zombies has a few inherent problems. |
