Old 12-17-2012, 06:09 PM   #1846
flying.moto
Earthbound Misfit, I
flying.moto's Avatar
Oddometer: 221
I'll take one of those coolers! I'm very impressed with a few goodies i got from Stephan. easy sell for me especially at that deal
Btw, thanks Walter :) I need to get out more to the local desert.. lots of neat riding there.. if i only had more time!
EDIT: Ordered!
flying.moto screwed with this post 12-17-2012 at 06:18 PM
flying.moto is offline   Reply With Quote
Old 12-17-2012, 10:50 PM   #1847
libratrades
libratrades
libratrades's Avatar
Oddometer: 85
Interested
I will take one as well.
libratrades is offline   Reply With Quote
Old 12-18-2012, 01:40 AM   #1848
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
Originally Posted by TobyG View Post
Hmmm.... I would guess that it would fit all the Rotax Engines from 2000 up to 2007?
(Probably the China 650's, too?)
Could anyone confirm especially if this would fit the single spark Rotax?
Other than that, cool item, for a pretty good price, I've been thinking about the oil cooler issue for some time now.
They all have the same oil filter cover (just different colours): You may or may not have to carve away a bit of the plastic chain guards on other models , but the cooler should fit the engine.
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 12-18-2012, 01:55 AM   #1849
magno
Oddometer: 38
OIl Cooler
I'll have one too please. Are we ordering directly from Stefan's site or is it just a show of hands on this thread?
magno is offline   Reply With Quote
Old 12-18-2012, 03:16 PM   #1850
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,934
Originally Posted by Colebatch View Post
Had a fair few questions this year about the oil cooler prototype from Terry Brown that Terry and I were running in Siberia this year ... the round cylindrical thing where the oil filter cap normally lives.
Well the legendary Stephan Scheffelmeier is now set to begin producing a batch, improved and refined from the prototypes we had, to his normal fantasy quality and will kick start the CNC machine for it once there are an initial 20 takers.
In return for being one of the initial 20, he is offering a 20% discount, for a price of 114.24 EUR.
The oil cooler adds a couple hundred ccs to your oil capacity (2.5 litres) and by both increasing oil volume and by proving a finned cooling chamber to reduce the temperature of the oil, the level of protection for the engine is significantly enhanced. One of the few causes of failures on this engine under rallying conditions was losing the main bearings, due to the oil being too hot under extreme conditions and being behind bashplates that cut off any airflow to the bottom of the engine. Increasing the volume also increases the service life of the oil, meaning cleaner, better lubricating oil at any given amount of mileage.
For me personally, fitting some sort of oil cooler has been a goal for several years, both to increase capacity and cool the oil. But there was never an easy or economical way to do it ... until Terry hit upon his simple solution. Rather than 500-600 EUR for an oil radiator,plus plumbing, plus finding some way to tap into the oil circuit twice, this simple easy solution has done exactly what I wanted something to do ... offer both cooling and extra capacity for the oil that is simple to fit and use and is very affordable (much cheaper than I thought it would turn out to be). To get it manufactured with scheffelmeiers quality is the icing on the cake.
So can we have a show of hands .... and when we get to 20 I will tell Stephan to fire up the CNC machine.
Walter, can you see this idea able to be adapted to the 70 Degree motors?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 12-18-2012, 08:18 PM   #1851
Kainic
Almost there
Kainic's Avatar
Oddometer: 380
I am in for one
I am in. Placed my order.....
Kainic screwed with this post 12-19-2012 at 04:40 PM
Kainic is offline   Reply With Quote
Old 12-19-2012, 06:25 AM   #1852
Bubba Bauer
Bubba Bauer's Avatar
Oddometer: 156
How the hell could be the terra about 30kg-s heavier than the X challenge? Is there any way to burn that fat off?
Bubba Bauer is offline   Reply With Quote
Old 12-19-2012, 08:03 AM   #1853
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,934
All steel frame and swing arm, twin exhausts, bigger fuel tank. Can't see you dropping much weight without it costing an rm and a leg.
xronly
Old 12-19-2012, 08:39 AM   #1854
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
Well technically speaking its 21 kgs heavier. Dry weight of 165 kg vs 144 for the XC.
A lot of the XCs frame is cast alloy. Only the uppermost part of it is steel.
The Swingarm will obviously weigh more ... I doubt anyone will come up with an aftermarket swingarm in alloy for the bike ... so that one you are wearing.
On the other hand ....
The XC needs weight added to it that the Terra doesnt ... so not all of the 21 kgs difference is as real as it looks.
On the XC you really should swap the airshock for an emulsion shock. The difference in weight there is about 2 kgs. Then you have the steel subframe. A steel subframe on the XC adds 3.5 kgs.
So once you give the XC the steel subframe and emulsion shock it really needs you are up around 149 - 150 kgs ... which oddly enough is about what the X-Country weighs with those bits on it.
Then the difference is only 15 kgs. Out of that 15 kgs, I reckon you will lose 5 kgs by getting rid of the cat, and putting a single exhaust in.
Now you are down to only 10 kgs difference.
Not sure there is much more you will be able to shift. I reckon the frame and swingarm are just about 10 kgs heavier. Just a shame they didnt build it with a lighter frame and swingarm to begin with
Old 12-19-2012, 08:43 AM   #1855
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
Actually its probably better going direct to his site and ordering. Since he has it up on his site anyway.
Old 12-19-2012, 08:43 AM   #1856
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
Good question ... I would need to ask Terry / Stephan .... but I cant see why not.
Old 12-19-2012, 09:17 AM   #1857
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Ordered! Thanks Walter for always pushing the envelope...
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 12-19-2012, 11:17 AM   #1858
TymeRider
TymeRider's Avatar
Oddometer: 373
Ordered one. Thanks for the heads up.
2007 BMW G650X Challenge
2005 KTM 950S Adventure
2002 BMW R1150GS Adventure
TymeRider is offline   Reply With Quote
Old 12-19-2012, 01:08 PM   #1859
Bubba Bauer
Oddometer: 156
first of all sorry for the rant and hijack and your right mate, but first when I heard about it I thought they`ll shoehorn the 650 into the te630-s frame and suspension and well reading about what they`ve done...just disappointed it could have been IT...
Old 12-19-2012, 07:39 PM   #1860
TobyG
be happy :)
TobyG's Avatar
Oddometer: 544
Great, just ordered one
I am running an aftermarket alloy sprocket guard, anyways
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is offline   Reply With Quote
Times are GMT -7.   It's 05:43 AM.
