Old 04-02-2015, 09:09 AM   #1
nody6262 OP
nody6262's Avatar
Oddometer: 13
Puke Depressurize Fuel Tank
Hi all.
New member here, could anyone point me to where I can get information to depressurize my fuel tank. I am in the process of removing the ABS Servo. I have a 2003, R1150 GSA Adv.
Thanks for any help.
nody6262 is offline   Reply With Quote
Old 04-02-2015, 09:58 AM   #2
Sniperx
Oddometer: 477
Open the gas cap?
Seriously...I don't think the tank should be holding any pressure. When I pull mine I just unhook the QDs and pull.
Motorcycles are like chlorine for the gene pool. 8/31/2013
Sniperx is offline   Reply With Quote
Old 04-02-2015, 10:14 AM   #3
cele0001
Instigator
cele0001's Avatar
Oddometer: 426
Tank depressurization lever is to the left and above the coolant drain.
I want to be unique, just like everybody else.
WORN INPUT SPLINES CLUTCH HUB SPACER R1150XX
http://advrider.com/forums/showthread.php?t=964425
cele0001 is offline   Reply With Quote
Old 04-02-2015, 11:04 AM   #4
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,749
The QDs shut off on each side an the tank is vented through the carbon canister, so I'm not sure what pressure you're worried about.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 04-02-2015, 01:56 PM   #5
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,743
That's the Knuter valve! Don't mess with it!
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 04-02-2015, 05:35 PM   #6
nody6262 OP
nody6262's Avatar
Oddometer: 13
Hi, I am not sure, the manual talks about De-pressurizing the tank before removal, but does not say how?
Old 04-02-2015, 05:59 PM   #7
JMforPres
JMforPres's Avatar
Oddometer: 439
I believe they are talking about the fuel lines. When I put quick disconnects on my 02 they were under pressure even after sitting overnight.
Jon
R100GS
R1150GS
R1150RT
77 R100RS
"I picked up a nice burlap thong. It makes me feel pretty." - BluRidgeRider
JMforPres is offline   Reply With Quote
Old 04-02-2015, 06:06 PM   #8
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,415
What's going on with the ABS unit that you need to remove it?
The woods is closing in on me...I need a D6.
def is offline   Reply With Quote
Old 04-02-2015, 06:09 PM   #9
Twilight Error
Oddometer: 22,749
Jon
Except I don't think there is any manual pressure relief for those lines, both QDs close when disconnected. You'll lose whatever fuel is trapped in the cavity - a couple drops at the most - as they're separated, but they won't spray or leak.
Old 04-03-2015, 04:53 AM   #10
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,209
Good practice is to turn away and/or wear safety glasses when disconnecting.
But I've never noticed mine squirt out when separating them.
Cheers, RVT
This week's ride: http://share.findmespot.com/shared/f...Vcz6Icqrhsbbpq
rvt is offline   Reply With Quote
Old 04-03-2015, 05:10 AM   #11
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,526
The tank is not pressurized. Either you are misreading the manual, or it is wrong. Disconnect the tank and remove it. Simple.
Old 04-03-2015, 05:43 AM   #12
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,344
It could be that the disclaimer is in the manual as sort of a standard safety precaution, there can be small amounts of residual pressure inside a fuel tank from temperature variations even though the vented fuel cap normally prevents this.
I'm thinking a more likely scenario is a warning message to "depressurize the fuel lines".
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 04-03-2015, 06:59 AM   #13
def
def's Avatar
Oddometer: 10,415
Does this have anything to do with those masks that drop down in case of sudden cabin depressurization?
Old 04-03-2015, 07:48 AM   #14
thirsty 1
Rider
thirsty 1's Avatar
Oddometer: 201
Be careful if you have the older plastic disconnects. The male ends brake off easily and then your stuck using a barbed connection or you'll need to buy some new ones from BMW or Beemer bone yard.
2004 R1150GS Adventure
thirsty 1 is offline   Reply With Quote
Old 04-03-2015, 08:50 AM   #15
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,344
Ahhhhhhh..........NO.
Just make sure that your wife puts your mask on first, then hers and you'll be OK.
Pull chocks.
Times are GMT -7.   It's 12:36 AM.
