Old 04-08-2013, 07:00 PM   #46
Graminal95
Oddometer: 40
I rode a little tonight with only one low beam as I'm waiting for the wiring to arrive. It is definetly better then stock. I have HID's I purchased for this project last year that I will be trying out as well. The nice thing about the 90mm Hella are that they are all glass and aluminum reflector, no plastic to melt and perfect for the highest wattage you can find.
Here are a few more build photos.
1995 R1100GS 101K+
Graminal95 is offline   Reply With Quote
Old 04-08-2013, 07:06 PM   #47
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,547
Thumb
NICE work Gram!
Cheers!
Dave
Racegun is offline   Reply With Quote
Old 04-08-2013, 07:09 PM   #48
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,294
A friend used similar lights on his XR400 with an HID conversion. Nice and bright.
twinrider is offline   Reply With Quote
Old 04-08-2013, 08:36 PM   #49
RAL88
Marineboy
RAL88's Avatar
Oddometer: 77
Ok, here I am with mine.
Cut off the tabs on the back of the light with my dremel. I ground down the back silver plate so the back of the lights would fit in. I then ground down the front black plate so they would fit in. Squeezed it all together and screwed it down.
I put in my 35watt 6000k HID and bench tested it. I was skeptical about the HID being about 3 times brighter than a halogen but I have to say that it was freakin bright. I left it on for about 20 minutes to make sure there was no melting going on and everything seemed to be fine. I will have to wait until I get it mounted on the bike to see what the beam spread is but with two HIDs I think it will more than the single halogen or just replacing the one halogen with one HID.
Rich
____________
'96' K1100LT-SE
'97' R850GS-R
"If it ain't broke take it apart and make it work better"
RAL88 is offline   Reply With Quote
Old 04-08-2013, 09:22 PM   #50
PaperBoy OP
Dig that Crazy Beak
PaperBoy's Avatar
Location: Oroville, Washington, USA - 48.938665, -119.427047
Oddometer: 341
Looking good guys
These are looking great.
My dog hates my bike!
1999 R1100GS - Blue & White, the fastest colors.
BMWMOA #142415
Valley BMW Riders member "Bigfoot"
PaperBoy is offline   Reply With Quote
Old 04-08-2013, 10:04 PM   #51
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,547
Thumb
GOOD STUFF there Rich!!! THX!
Cheers!
Dave
Old 04-08-2013, 11:41 PM   #52
PaperBoy OP
Dig that Crazy Beak
PaperBoy's Avatar
Oddometer: 341
Hi/Lo Setup
Rich, are you going to have one side high beam and the other low. Or are you using the bi-xenon that moves in and out for high and low? I know a third option is one where the bulb/capsule has both a xenon low and a skinny halogen high.
BMWMOA #142415
Old 04-09-2013, 06:29 AM   #53
RAL88
Marineboy
RAL88's Avatar
Oddometer: 77
I am using bi-xenon so I can have low beams and high beams in both lights.
Rich
____________
'96' K1100LT-SE
'97' R850GS-R
Old 04-11-2013, 11:26 PM   #54
Graminal95
Oddometer: 40
What do you guys think of the cover I'm going to make? It is a lot like the Wunderlich cover because it think it looks really good with the owl eyes.
I'm also going to leave enough room behind the oil cooler guard so that I can install 2X 100mm fans for cooling if I decide its needed in the future.
1995 R1100GS 101K+
Old 04-12-2013, 12:28 AM   #55
PaperBoy OP
Dig that Crazy Beak
PaperBoy's Avatar
Oddometer: 341
Great
Can't wait to see it fitted.
BMWMOA #142415
Old 04-14-2013, 03:09 PM   #56
RAL88
Marineboy
RAL88's Avatar
Oddometer: 77
So I got the HIDs mounted in the lights and tested them. The are really bright. Next is to mount it on the bike.
Rich
____________
'96' K1100LT-SE
'97' R850GS-R
Old 04-19-2013, 11:00 AM   #57
Graminal95
Oddometer: 40
The headlight cover is roughed out, but needs some sanding, epoxy, and paint.
1995 R1100GS 101K+
Old 04-19-2013, 12:56 PM   #58
PaperBoy OP
Dig that Crazy Beak
PaperBoy's Avatar
Oddometer: 341
Wow!
Looks professionally done. What did you form the headlight cover/surround from? Any photos of the process?
BMWMOA #142415
Old 04-19-2013, 09:39 PM   #59
Graminal95
Oddometer: 40
I used a cheap 3d printer and made them out of pla. They need to be finishe and painted, and a grill guard made up for the oil cooler. The headlights are awesome! So bright that speed limit signs are almost blinding.
1995 R1100GS 101K+
Old 04-29-2013, 09:45 AM   #60
Graminal95
Oddometer: 40
Almost done. Just needs a little sanding, some clear, and a grill for the oil cooler.
1995 R1100GS 101K+
Times are GMT -7.   It's 06:05 PM.
