Old 07-28-2013, 01:45 PM   #9166
T
stay classy
T's Avatar
Oddometer: 5,265
Tom- here's a stator that lost a phase. Notice burnt area. Even so much as a small nick in the insulation on the winding(s) can cause problems.
New Mosfet Reg/Rectifier
All Triumph owners should keep one of these handy.
This is the kind of bullshit that keeps Triumphs from ever being great bikes.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 07-28-2013, 02:06 PM   #9167
eddie bolted
BOING!!!
eddie bolted's Avatar
Oddometer: 3,618
Originally Posted by tom c View Post
Well I did some investigating today. No charging is going on. As there is no output from the alternator.
Some corrosion can be seen.
Damn.
And my laptop has also shit the bed. Double damn.
And its pouring rain.
Sigh
There's one thing I have to say about this.....KLR
If it stops raining now, i'll be pissed!(BEANTOP)
It's mostly Dan........I knew he couldn't keep a secret(SCOTTY P)
eddie bolted is online now   Reply With Quote
Old 07-28-2013, 02:17 PM   #9168
WayneJ
LFC/CCCCC
WayneJ's Avatar
Oddometer: 5,605
Or Honda.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
I got a chill standing outside wiggling wieners.. - LadyDraco
There is no odometer when it comes to pie - VACommuter
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 07-28-2013, 02:21 PM   #9169
tom c
tom c's Avatar
Oddometer: 3,029
Thanks for the advice. I will investigate further, in the meantime the KLR is my primary mode of transportation. Writing this response on a Surface at the best buy. Shopping for replacement for the broken laptop. Can I get used to a touchscreen keyboard? Hmmmmm
2010 Triumph Tiger 1050 SE , 2009 KLR650
Where's Tom?
tom c is offline   Reply With Quote
Old 07-28-2013, 02:24 PM   #9170
T
stay classy
T's Avatar
Oddometer: 5,265
Originally Posted by WayneJ View Post
Or Honda.
VFR's had/have their share of electrical woes.
all this makes a V-Strom seem rather attractive
Old 07-28-2013, 02:34 PM   #9171
tom c
tom c's Avatar
Oddometer: 3,029
I will completely remove the stator and check for damage. And also check resistances. When I started her this morning the voltage was 12.8 V whether the bike was running or not running. This tells me that there was no charging going on.
Where's Tom?
Old 07-28-2013, 02:43 PM   #9172
T
stay classy
T's Avatar
Oddometer: 5,265
Careful when you pull it out....pretty strong magnetism. Might try to "jump" out of your hand.
Old 07-28-2013, 02:45 PM   #9173
tom c
tom c's Avatar
Oddometer: 3,029
Let meask a dumb question, now from a galaxy note 10.1. Is there supposed to be some oil in the space where the stator is? I kinda like the touchscreenon the Surface tablet better
Where's Tom?
Old 07-28-2013, 02:53 PM   #9174
T
stay classy
T's Avatar
Oddometer: 5,265
Yes, a small amount of oil....couple tablespoons, give or take.
Old 07-28-2013, 04:02 PM   #9175
JaxObsessed
RushMoran....... :D
JaxObsessed's Avatar
Location: From Alabama to Newfoundland it's all Appalachian
Oddometer: 13,133
Stator/rectifier Can't be completely dead or the battery would be deadern hell.
Thanks for the wisdom T. Something for me to consider just doing. Mine plays the same games as Tom's, but when it's running it's flogging almost 14V at the battery.
ADVers are out of control and that's their charm, they don't line up, they don't have standards they follow, each and every one does their own thing. They know how to ride free - BugSister.
Jax mediocre photo thread
20% Smugmug discount coupon
JaxObsessed is offline   Reply With Quote
Old 07-28-2013, 06:51 PM   #9176
badguy
Susan
badguy's Avatar
Oddometer: 1,678
Damn Tom, glad it wasn't acting worse yesterday. No need to apologize...I don't have to fix it Good luck with the repair, it sounds like Mr. T has the right idea. Like Jack said though, if it were completely dead I don't think you would've been going anywhere.
bad·guy [bad'-gi]
vb (tr) bad·guyed bad·guy·ing bad·guys
1. To refuse to commit to an event, but most likely attend at the last minute.
2. To ignore an event until the last minute so as to avoid any expectations of attendance, but then show up anyway.
badguy is offline   Reply With Quote
Old 07-28-2013, 07:32 PM   #9177
sloburban
sloburban's Avatar
Oddometer: 1,413
TomC, shoulda bought a KTM!
I've never had a reliability issue with mine yet........of course I've only ridden it about two miles so far
Hope you get your issue fixed soon.
sloburban is offline   Reply With Quote
Old 07-29-2013, 05:08 AM   #9178
JaxObsessed
RushMoran....... :D
Oddometer: 13,133
Did you have to do this on your steamer Slo?
Only have 13K on mine and I have decided to go mosfet just cause, what good is a bike you cant trust to start EVERY time. Thanks again for the wisdom Mitta T> You da man.
Oh and Tom, if the battery is showing 12.8v after sitting, it has survived the torture of a malfunctioning charging system. Seems like you caught this thing early enough to save a tow.
Old 07-29-2013, 06:28 AM   #9179
tom c
tom c's Avatar
Oddometer: 3,029
You sure your volt meter is correct?
I find it hard to believe it ran all the way back to DE if it wasn't charging.
I didn't think the ECU or FI would continue to function once the voltage fell a few tenths below 12v.
Yes my voltmeter works.
I charged the battery overnight, volts now read 13.8, it was reading 12.8V after Saturday's ride, so it seems that the battery was not being fully charged. The battery is relatively new, bought in December 2012, a Bikemaster Gel. My tiger has HID headlights and and LED tail light - perhaps she does not use too much electricity in normal operation? Could explain why I was able to make it all the way home. So maybe the battery is better than I thought!
Originally Posted by T View Post
Tom- Take your multi-meter and check stator for continuity and output. Doesn't look like there are any windings burnt.
Bad thing is, when the stator goes it often takes the Regulator/rectifier with it. Go Mosfet if that needs replacing.
BTW: Rick's is pretty cool to deal with.
Wayne- The Tiger/Michaux curse has returned....
Stator and Regulator/rectifier ordered from Rick's this morning. KLR is now my primary mode of transportation!
Where's Tom?
Old 07-29-2013, 06:48 AM   #9180
WayneJ
LFC/CCCCC
WayneJ's Avatar
Oddometer: 5,605
12.6 - 12.8 is a fully charged battery.
It's impossible for a 12v battery to read 13.8 volts. A 6 cell 12 volt battery makes 2.1 volts per cell. 6 x 2.1v is 12.6 volts.
13.8 volts is what you should have when it is being charged. You got 13.8 volt reading because it still had a residual charge from being charged. Or your meter is incorrect.
The way your bike was acting makes me think there was a bad connector or loose cable somewhere.
20% Smug Mug Credit
WayneJ screwed with this post 07-29-2013 at 08:00 AM
Times are GMT -7.   It's 02:36 PM.
