Old 11-15-2009, 08:46 PM   #1
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,249
Airhead Paralever GS vs RS rear hub ratios
I've got this thing in my head to find an RS or RT rear hub to put on the 91 GS, try to get the engine revs down a bit. Anyone try this?? How available are these hubs out there? I've never had any problems with that portion of the drive system [gearbox & driveshaft, don't get me started!], it's probably be off a wrecked one.
Steve
Steve G. is offline   Reply With Quote
Old 11-16-2009, 04:31 AM   #2
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,287
You'll need to modify the pinion. The Airhead Paralever pinion spline length is only available in the two ratios (3.09 and 3.20) that came on those bikes.
Old 11-16-2009, 04:07 PM   #3
JimX
Oddometer: 718
Would have to be an internals swap, with the requisite re-shim, etc. No Paralever housing ever came on a RS or RT.
JimX is offline   Reply With Quote
Times are GMT -7.   It's 11:29 PM.
