Go Back   ADVrider > Riding > Regional forums > West – California, the desert southwest and whatever is left
Old 07-07-2013, 03:58 PM   #6481
Klammer OP
Old and Grumpy
Klammer's Avatar
Location: Single track,desert, surf, water & snow ski Heaven
Oddometer: 2,369
Cool2
Originally Posted by 150ron View Post
Did lots of Rowher, then DWF today, to the power station, Ive noticed that they changed Bouqet trail from Black diamond to Blue, and they graded the F out of that trail, its so smooth and easy now....
Dang Ron, I thought you were kidding, but then I find Bouquet trail paved to the top with the little metal rail installed up the center just like autopia at disneyland. Better get your spring bumpers installed front and back boys, it's balls to the wall all the way to the top!
All joking aside, the Big Oaks Lodge is under HOT new management. She kept the great I talian menu that we en"JOY"ed many full moons ago. Live band every other Saturday. Good burgers and big fat weiners for those so inclined. Build your own pizzas and homemade tamales. Check em out and let Joy know that Klammer sent you. I feel the need for a full moon ride with dinner at the Big Oaks Lodge soooon!
If it's got tits or tires,eventually,it's gonna give you trouble
RFBK videos http://advrider.com/forums/showthrea...2#post16352382
Rowher Flats Trail Krew (RFTK)
Save $5.00 on SmugMug (coupon vJQj53lXRtVfs) http://smugmug.com/
Klammer is offline   Reply With Quote
Old 07-07-2013, 05:31 PM   #6482
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
Just don't post it up here.
notmybikemodelname is offline   Reply With Quote
Old 07-07-2013, 05:35 PM   #6483
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,367
+10000,pm's only, last Rowher nite ride broke up LA ADV.
But letas do it
GO KINGS!!!!(Edit:2 TIME STANLEY CUP CHAMPION KINGS) 00'KX500 (dune wrecker)08'SE ,06'EXC,02'YZF/W,76'04'H-D
92 YJ extreem ,76 CJ 5 sand beast ,07 JK cruiser
dunerat screwed with this post 07-07-2013 at 05:50 PM
dunerat is offline   Reply With Quote
Old 07-07-2013, 05:52 PM   #6484
Klammer OP
Old and Grumpy
Klammer's Avatar
Oddometer: 2,369
Cool2
Pm's only, and yes they have your poached salmon ravioli!
Originally Posted by dunerat View Post
+10000 pm's , last Rowher nite ride broke up LA ADV.
But letas do it
Just the straw that broke back mountian the hump day camels.
Old 07-07-2013, 07:16 PM   #6485
mattpetro
motomatt
Oddometer: 8
Wink Got It, KTM 990 ADV
Know learn how to ride it.
Ha Ha, No really
ROCKO
mattpetro is offline   Reply With Quote
Old 07-07-2013, 07:20 PM   #6486
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,367
Ha Ha, No really
ROCKO
Congrats
When in doubt , gas it!
LC8s rule
Old 07-07-2013, 07:27 PM   #6487
mattpetro
motomatt
Oddometer: 8
Awesome beast
TECHNICAL DETAILS
ENGINE
Design 2-cylinder, 4-stroke, 75° V-Twin arrangement, liquid-cooled
Displacement 999 cm³ (60.96 cu in)
Bore 101 mm (3.98 in)
Stroke 62.4 mm (2.457 in)
Performance 84.5 kW (113.3 hp)
Cold start device Electric starter
Transmission 6-speed
Engine lubrication Dry sump lubrication system with two rotor pumps
Primary transmission 35:67
Secondary drive ratio 16:42
Cooling Water cooling, permanent circulation of coolant by water pump
Clutch Multidisc clutch in oil bath/hydraulically activated
Ignition system Contactless controlled fully electronic ignition with digital ignition adjustment
CHASSIS
Frame Lattice frame made of chrome molybdenum steel tubing, powder-coated
Fork WP Suspension Up Side Down 4860 MXMA PA
Shock absorber WP Suspension PDS 5018 DCC PA
Suspension travel Front 210 mm (8.27 in)
Suspension travel Rear 210 mm (8.27 in)
Brake system Front Double disk brake with floating brake calipers and brake discs
Brake system Rear Single disc brake with floating brake caliper and brake disc
Brake system Two separate brake circuits without ABS (antilock brake system)
Brake discs - diameter Front 300 mm (11.81 in)
Brake discs - diameter Rear 240 mm (9.45 in)
Chain 5/8 x 5/16” X ring
Steering head angle 63.4°
Wheelbase 1,570 mm (61.81 in)
Ground clearance, unloaded 261 mm (10.28 in)
Seat height, unloaded 860 mm (33.86 in)
Total fuel tank capacity, approx. 20 l (5.3 US gal)
Super unleaded (ROZ 95/RON 95/PON 91)
Weight without fuel, approx. 209.5 kg (461.9 lb.)
Old 07-07-2013, 07:32 PM   #6488
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 2,093
Cool2
Dang I feel the need for a full moon ride with dinner at the Big Oaks Lodge soooon!
But letas do it
Pm's only
Full moon 22nd 10:51 pm.
can you pull it off? I will be coming for SD area so...?
Originally Posted by pcvance View Post
Who's the clueless noob?
theGrinch is offline   Reply With Quote
Old 07-07-2013, 07:34 PM   #6489
1224R
Oddometer: 2,113
Nite ride... Comonnnn!!!
I thought YOU had the map......
1224R is offline   Reply With Quote
Old 07-07-2013, 07:48 PM   #6490
Klammer OP
Old and Grumpy
Klammer's Avatar
Oddometer: 2,369
Cool2
We must syncronize and calibrate our crackerjack super secret decoder rings because even in pm's the message will be encripted so well that native americans heads will explode!
Old 07-07-2013, 07:52 PM   #6491
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,367
I polished my Cracker Jack ... Ready for explosion
Old 07-07-2013, 08:25 PM   #6492
Off Limits
Off Limits's Avatar
Oddometer: 3,481
But letas do it
It did? But we are still here. Post it up, it's more fun that way.
Off Limits is offline   Reply With Quote
Old 07-07-2013, 09:15 PM   #6493
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 9,242
IN on the Full Moon ride.
we used to do it on the weekend nearest the full moon.
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE
SPOT
RAZR is offline   Reply With Quote
Old 07-07-2013, 09:25 PM   #6494
1224R
Oddometer: 2,113
Fuck yeah!!
Old 07-07-2013, 09:33 PM   #6495
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,833
Got a place we can stage from if everything does explode
RIDE ON!
Content, NEVER!
dzrtracin is offline   Reply With Quote
Times are GMT -7.   It's 07:34 AM.
