Old 11-16-2009, 11:34 AM   #1
euromotorcycles OP
Oddometer: 168
Airhead racers SUMP windage trays and baffles INFO?
Anyone have info on those special windage trays and baffles used on some post 1970 airhead boxer twins racers crankcase and sump.I was told that the Buttler and Smith race bikes used them to control air and oil flow from the crankcase.
euromotorcycles is offline   Reply With Quote
Old 11-16-2009, 01:07 PM   #2
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,923
995 pan, cast in April 1983, from an R65. Cast with part number 1 336 994.
I don't know if this is what you are asking about, but this is lifted from Anton's page on oil pans and dipsticks, linky here.
Take a look at Anton's site, it may have the information that you are looking for.
And, as always, a big thanks to fellow-ADV'r Anton Largiader for sharing his website and knowledge with airheads everywhere...
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 11-16-2009, 01:57 PM   #3
PaulRS
Dutch fool
Oddometer: 814
Something like this?
Don't know nothing about them, exept they turn op once in a while for big money, this guy wants 375.
Paul.
PaulRS is online now   Reply With Quote
Old 11-16-2009, 02:31 PM   #4
euromotorcycles OP
Oddometer: 168
Don't know nothing about them, exept they turn op once in a while for big money, this guy wants 375€€€.
Paul.
Wow this is a good looking oil pan. I think it's a Falert made of magnesium should contain at least 4 liters.
A windage tray is usually a stamped piece of sheet metal that is mounted between the crank shaft and the oil pan. Baffles are raised sections inside the oil pan that limit oil sloshing within the sump wile chanelling the oil supply near the oil pick-up.
Old 11-16-2009, 02:52 PM   #5
pommie john
pommie john's Avatar
Oddometer: 1,477
I use the same sump as pictured above..the one from Anton's site.
It has baffles but no windage.
I think you only really need the windage for sidecar use.
I have a sump extension, but not to increase oil volume, to increase crankcase volume for better crankcase breathing.
Here it is.
pommie john is offline   Reply With Quote
Times are GMT -7.   It's 09:51 AM.
