Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 07-23-2013, 06:15 PM   #15421
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 870
Thumb
Originally Posted by Mr2mch View Post
Well...Then click on this
http://www.twtex.com/forums/showthread.php?t=85459
I posted a few of my better photos on this thread.... It has a bunch of others too. Jus thought ya'll might like it.
Great pics Rod, I might have to pick your brain about the route you took. I'm planning a two week run up to Crater Lake and back down through Cali in September. I'm assuming you used the Butler Maps? I need to buy that from you if you have one.
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is offline   Reply With Quote
Old 07-24-2013, 09:00 AM   #15422
bigdave-gs
Explorer
bigdave-gs's Avatar
Oddometer: 2,585
(Do you kno where the peekaboo bike pic is from??)
The I C U Forum ? ? ?
I'd be unstoppable if not for Law Enforcement and Physics !
When your 6'8" with a 40" inseam, the bikes that fit you are limited ! ! !
2004 BMW R1150GS Adventure for street work / KTM 950 Super Enduro for Dirt work !
bigdave-gs is offline   Reply With Quote
Old 07-24-2013, 09:05 AM   #15423
RubberDuck1111
RubberDuck1111's Avatar
Oddometer: 128
Just got a pelican case for the top rack cause I'm sick of loading my pockets up on the bike! Should be pretty straight forward... Drill holes and 4 bolts?
RubberDuck1111 is offline   Reply With Quote
Old 07-24-2013, 09:11 AM   #15424
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,724
WANTED: CENTRAL TEXAS ADVers
Before you do it, do a search on adv. I bet you want/need a plate of some kind.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is online now   Reply With Quote
Old 07-24-2013, 09:14 AM   #15425
RubberDuck1111
Oddometer: 128
http://advrider.com/forums/showthread.php?t=693332
Found this guy, I got that plate back there already think that would work? Also was considering running a 12 volt back there to charge the phone and stuff... Good bad idea?
Old 07-24-2013, 09:33 AM   #15426
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,724
There may be nobody less qualified than me to answer that.
slowoldguy screwed with this post 07-24-2013 at 09:56 AM
Old 07-24-2013, 09:51 AM   #15427
japako
japako's Avatar
Oddometer: 592
You should not have a problem with the 12v as long as you use a fused relay off the battery, and a switched trigger wire. That is unless you have the CAN Buss system.
If you do, you'll have to ask a Beemer guy..
On edit,, you do have a Can buss system and I am not familiar with that.
Good luck.
japako is offline   Reply With Quote
Old 07-24-2013, 09:57 AM   #15428
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,724
He can bypass canbus with a direct connection to the battery . We all do it for our accessory plugs.
Old 07-24-2013, 10:15 AM   #15429
japako
japako's Avatar
Oddometer: 592
Thanks, I have never worked on Can buss, but have read about it.
What happens if you use a trigger wire for the relay from a switched source?
Old 07-24-2013, 10:46 AM   #15430
TXjames
High Sider
TXjames's Avatar
Oddometer: 1,095
That works. The diagnostic plug under the seat is commonly used on the 1200. But it may trip Canbus if other sources are used. Not sure.
Roll The Bones V - No premature incinerations. Oct 24-26, 2014.
TXjames is offline   Reply With Quote
Old 07-24-2013, 10:49 AM   #15431
cavemanjed
cavemanjed's Avatar
Oddometer: 191
I have a direct wired 12v to my battery on My GSA, it's not switched and has yet to be an issue. I suppose you could use a relay, but it seems to be adding complexity for not much gain, but then again I'm not sure what your ultimate goal is so maybe I keep my mouth shut. I would definitely recommend the water tight female plug housing though (obvious choice). Bought the stuff off amazon for pretty cheap.
Embrace the Chaos
cavemanjed is offline   Reply With Quote
Old 07-24-2013, 11:07 AM   #15432
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,564
Running electrics is an excellent idea. I'm planning on putting a Fuzeblock under my seat. Like this guy did. Its got the relay built in and each circuit can either be on the relay or constant on by how the fuse is installed. Pretty cool and neat installation. Then its easy to add farkles.
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
'13 R1200GS
'08 WR250R
Dahveed is offline   Reply With Quote
Old 07-24-2013, 11:12 AM   #15433
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,564
Some people like using the headlight or taillight for the switch aspect. The trigger wire draws so little energy, its usually fine. On the new GSW the taillight can show a warning, I've heard.
'13 R1200GS
'08 WR250R
Old 07-24-2013, 12:57 PM   #15434
japako
japako's Avatar
Oddometer: 592
If it's not switched, you can forget and run the battery down.
Old 07-24-2013, 01:04 PM   #15435
japako
japako's Avatar
Oddometer: 592
I like the FZ1 and have used it on my larger bikes. It looks like he is using the blue running light wire for the switched. It's just a little more money to use it.
Times are GMT -7.   It's 05:38 PM.
