Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 07-24-2013, 02:36 PM   #15436
SchizzMan
pronounced `skiz-man
SchizzMan's Avatar
Oddometer: 8,254
Originally Posted by Dahveed View Post
Running electrics is an excellent idea. I'm planning on putting a Fuzeblock under my seat. Like this guy did. Its got the relay built in and each circuit can either be on the relay or constant on by how the fuse is installed. Pretty cool and neat installation. Then its easy to add farkles.
Had Mike Goff install a fuse block (not sure which brand) prior to farkling up the GSA. It's real smart to have the fuse block switch off with the ignition to avoid current leaks with added electrics. Just run your battery tender conn directly from the battery. Charges better that way.
"You don't take photos for yourself, you take them for the old man you will become - if you are lucky." - Falang
"As long as there's a horizon and I can see it, then I want to know what's there, mentally, physically and visually" - rtwpaul
SchizzMan is online now   Reply With Quote
Old 07-24-2013, 03:12 PM   #15437
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,562
WANTED: CENTRAL TEXAS ADVers
I use the Touratech fuse block thing and have converted my additional outlet to direct to battery so that I can run heated gear or a pump. Works fine for me.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 07-24-2013, 03:51 PM   #15438
RubberDuck1111
RubberDuck1111's Avatar
Oddometer: 128
oh god i hate wiring and electrical stuff
Well just got my Adv Spec bars in today for my birthday woohoo so just gotta get pics up... Sure itll take 11 hrs
RubberDuck1111 is offline   Reply With Quote
Old 07-24-2013, 04:00 PM   #15439
japako
japako's Avatar
Oddometer: 592
It's not that bad RubberDuck. Just don't get any arcing and sparking going on and you'll be ok.
japako is offline   Reply With Quote
Old 07-24-2013, 04:01 PM   #15440
RubberDuck1111
Oddometer: 128
first pic i was looking at how the pelican case would look
NOW THE BARS!
DDont mind the beers in the back...
Old 07-24-2013, 04:04 PM   #15441
RubberDuck1111
Oddometer: 128
Now on the right side of the bike there was suppose to be a spacer between the frame and the motor? It wasnt there at all so seeing what its for, if i need it, and yea all that Jazz
Any ideas?
Old 07-24-2013, 06:24 PM   #15442
veriest1
Grand NOOBlet
veriest1's Avatar
Oddometer: 2,502
Any ideas?
Edit: meant to quote pictures of your bike but you get the idear.
Hawt!
Remember to use rubber washers under your regular washers on the top case. That should keep things waterproofish. BTW it WILL crack and come off in a high side. :
On a side note I see AutoZone is selling universal marine grade kill switches now... Schizz?
Sent from my HTC using magic.
veriest1 is offline   Reply With Quote
Old 07-24-2013, 07:12 PM   #15443
RubberDuck1111
Oddometer: 128
Yea I just mounted it with reg washers need to get the rubber ones tho for sure... But yea hopefully there won't be any high siding!!! Haha
Old 07-24-2013, 10:09 PM   #15444
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,084
HD Sportster
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is online now   Reply With Quote
Old 07-24-2013, 10:23 PM   #15445
veriest1
Grand NOOBlet
veriest1's Avatar
Oddometer: 2,502
Originally Posted by pizzaboy View Post
HD Sportster
205
But a good 205.
Old 07-24-2013, 11:39 PM   #15446
SchizzMan
SchizzMan's Avatar
Oddometer: 8,254
On it!
Old 07-24-2013, 11:40 PM   #15447
SchizzMan
SchizzMan's Avatar
Oddometer: 8,254
Nice! Are they SW-Motech bars?
Using blue thread lock?
Old 07-24-2013, 11:43 PM   #15448
SchizzMan
SchizzMan's Avatar
Oddometer: 8,254
That's it.
Old 07-25-2013, 06:28 AM   #15449
RubberDuck1111
Oddometer: 128
no they are Adventure Spec bars, and i didnt use blue thread lock but i will now!
Old 07-25-2013, 06:48 PM   #15450
RubberDuck1111
Oddometer: 128
Man if I didn't know any better I'd say everyone's out ridding since its so quiet in this thread
Times are GMT -7.   It's 06:52 PM.
