11-27-2009, 03:29 PM
#31 | |
North Forest Rider
Oddometer: 3,619
One other question too. How do you orient the spring in the forks and on the rear shock when you put them on? Softer side with tighter winds to the bottom? Or Firmer side with looser winds to the bottom? |
11-28-2009, 08:41 AM
#32 | |
Oddometer: 2,039
my favorite bike - R1200GS |
11-28-2009, 10:43 AM
#33 | |
Greg
Oddometer: 1,552
I'm a bit confused by the whole "dirt bike" mentality. The fact that people are disappointed that it doesn't ride like a dirt bike straight off the show room floor baffles me.
Originally Posted by NAZDirt Quote:
The suspension is a hell of a lot better than the 1200, but it's not a KTM. I have modified my bike for it's stock short comings, but I was never surprised by any it's needed improvements. ok I'll stop now.
CASCADE EXPEDITIONS WABDR Tours & More. PSSOR - Dualsport Training & Adventure Camps. |
11-28-2009, 10:55 AM
#34 | |
Oddometer: 77
Dual sport definition
Since the bike is a dual sport by definition is should be able to handle both terrains. For the price I would hope it could do better than a street bike on the dirt. I am not suggesting you can take it to the motocross circuit but it should be able to travel on a gravel road with out shaking itself to death.
If you are happy with yours great. For the rest of us that want to ride as it should this is a cheap fix. Quote:
09 F800GS |
11-28-2009, 12:38 PM
#35 |
North Forest Rider
Oddometer: 3,619
I by no means have been 'disgusted' with the suspension on this bike. I actually like the stock Sachs/BMW rear shock. The front end however, is a bit too soft for me in the mid and end of the stroke, and it's initial beginning of the stroke is to hard. I just figured as long as I'm putting Hyperpro progressive springs and Hyperpro 10w oil in the forks, why not put a Hyperpro progressive spring on the rear too. And for $252.50 for the entire kit, I couldn't pass it up.
11-28-2009, 01:07 PM
#36 |
NoMoTDM still Gary
Oddometer: 3,700
I was one that was very disappointed in the bikes suspension. Not that I wanted to ride single track or motocross, but I did expect to ride some Sierra forest service roads that any two wheel drive pickup could manage.
It is not that it couldn't, it was all the harsh feedback through the suspension that radiated both through the bike and me. The most disapointing, was that BMW chose to put some very low tech suspension on this bike, that made it very difficult or expensive to fix even to the levels I wanted to go. BMW did advertise this aspect of the bike and even got positive feedback, but for the life of me I can't understand why. If stock is OK with you, thats all right with me, I have managed to make enough mods that is does fine for what I will use it for and I realize that it does have limitations. |
11-28-2009, 01:45 PM
#37 | |
Flame Bait
Oddometer: 937
The end of the spring with the coils that are spaced closer (not technically any "softer" than the other end, but that's a tangential discussion...) are the first to touch each other as the spring compresses. As that happens, those coils essentially become a solid mass. If that mass is on the bottom, its always moving with the suspension. If that mass is on the top, as the suspension compresses the total unsprung weight actually decreases. Is spring orientation really an issue on the F800GS? Considering the rest of the suspension, I doubt it. |
11-28-2009, 02:56 PM
#38 | |
Oddometer: 2,039
11-28-2009, 03:40 PM
#39 | |
Flame Bait
Oddometer: 937
In the specific 'progressive' circumstance described above, the fully compressed coils of the spring become dead weight. You'd have a similar situation if you cut the spring and put a slug of metal in its place. If that dead weight is below the spring, it is most certainly "unsprung". |
11-28-2009, 03:47 PM
#40 | |
Oddometer: 2,039
11-28-2009, 06:19 PM
#41 |
Oddometer: 77
Wow, well said by both sides. That was the best discussion with oppposing views I have heard yet without crying and name calling.
For the naysayers on which side goes up.... I was told orientation doesn't really matter since the valving is the same over the entire travel and it is not dynamic like many high end shocks used in the racing industry.
09 F800GS |
11-28-2009, 06:57 PM
#42 | |
Flame Bait
Oddometer: 937
The previous 'progressive spring orientation' issue aside, which way the spring is oriented has no bearing on which end of the spring compresses first. In a nutshell the "softer" end will always compress first, regardless if its on the top of on the bottom. For a straight rate spring, the compression is basically even across the length of the spring. Furthermore, the valving of the GS's suspension is indeed 'dynamic'. Its not as sophisticated as many higher end shocks, but the way it works is more or less the same. |
11-28-2009, 08:13 PM
#43 | |
Oddometer: 77
I agree the softer part will compress first. During this segement of shock travel the dampening is going to be softer/slower than when say hitting the ground hard from whoops. The shocks are only dynamic in that the pressure of the fluid flow will change through out the cycle and "affect" dampening. If we had high end shocks we would be lucky enough to have bypasses and multiple valve rates as the high end shocks get.
09 F800GS |
11-28-2009, 08:57 PM
#44 | ||
Flame Bait
Oddometer: 937
12-01-2009, 09:34 AM
#45 |
North Forest Rider
Oddometer: 3,619
I'm chompin' at the bit to get these springs!!
![]() They're not shipping until Wed due to my special black rear spring request. |
