Old 01-27-2015, 03:45 AM   #1
ME 109 OP
ME 109's Avatar
Oddometer: 2,572
81 final drive clunking
Just put the bike in the shed afetr a 1000k 3 day ride. While rolling it, I could here a clunk clunk clunk from the ass end.
I spun the rear wheel and what is going on in there!!
I drained the oil expecting to find the magnetic plug looking like a punk hedgehog, but it was ok.
If I rotate the wheel, I get 12-13 clunks per revolution.
Something has come loose and I think it's the pinion nut, if that's what it's called. That big bastard in the bell coupling.
I can't get to it again tonight but thought I'd post to get some ideas from the experienced folk.
It isn't the wheel bearings, and the lack of metal on the drain plug is promising, I think.
It's about time there was a problem with the bike anyway. I was becoming most concerned there was something wrong with it.
Edited to add, the only symptom was more backlash than usual, but no noise.
Lord of the Bings, kangaroo farmer
ME 109 screwed with this post 01-27-2015 at 03:51 AM
ME 109 is offline   Reply With Quote
Old 01-27-2015, 04:15 AM   #2
damurph
Cold Adventurer
damurph's Avatar
Location: The far east of the far east of North America
Oddometer: 1,656
Pinion bearing but it would be my thought some of it would end up on the drain plug. Never heard of a pinion nut loosening but have seen the backlash affected by a broken pinion bearing.
R1150 GSA, KLR650, K75s, RD350, PS250 (Big Ruckus), R65, 990 Spyder
If I still had every dollar I spent on motorbikes I would be a richer man but a poorer person.
damurph is offline   Reply With Quote
Old 01-27-2015, 04:50 AM   #3
100RT
100RT's Avatar
Oddometer: 664
Did you put it on the center stand and rotate the wheel while you feel the rear end? Can you move the wheel when holding it at the 9 and 3 o'clock positions? What about the U-joint?
100RT is offline   Reply With Quote
Old 01-27-2015, 05:04 AM   #4
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,342
Sounds like a rear u-joint to me. I don't think there is anything in the ring and pinion gear that can clunk. Good luck!
Edit: there is no rear u-joint, so that isn't the noise. That noise is a bit of a mystery - and one with a foreboding ending. On the bright side, at least it isn't winter there and taking the bike apart won't be quite so miserable.
Stan_R80/7 screwed with this post 01-27-2015 at 05:40 AM
Stan_R80/7 is offline   Reply With Quote
Old 01-27-2015, 05:21 AM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,418
Jeff, when my pinion bearing had 2-3 mm of movement, there were no symptoms whatsoever. I only found the problem at routine fd oil change.
This was the damage as the pinion moved about.
Are your 4 bolts at the gearbox output all tight? Wheel bearing?
boxerboy81 is offline   Reply With Quote
Old 01-27-2015, 05:57 AM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,473
Might just be that the wheel spline cup rivets have sheared:
Happened to me last Fall, happened to Voltaire recently. Leading up to the rivet failure there is a rhythmic clunk-clunk-clunk noise and leading up to the noise there was drivetrain slop.
Or, better, if the driveshaft bolts have loosened, you'll also get that rotating noise and slop.
Pull the rear wheel, take a look. If it is OK, pop the driveshaft boot loose and take a look. If them's OK, drain the rear drive oil and see what is on the magnetic drain plug.
Fingers crossed.
--Bill
'73 R60/5 Toaster
Old 01-27-2015, 11:02 AM   #7
ME 109 OP
ME 109's Avatar
Oddometer: 2,572
Thanks for the replies gents
I had the bike on the c/stand when rotating the wheel back and forward. It sounds awful, and the noise is very much coming from the fd itself. There is more than one noise.
I'm satisfied without having removed the wheel yet, that the wheel bearings are fine because there is no wheel wobble, and the noise is too loud and heavy.
Drain plug only has normal sludge without any trace of coarse material. I'm hoping that's a good sign.
Off to work now, so I'll rip into it when I get home.
Old 01-27-2015, 11:07 AM   #8
chasbmw
Oddometer: 2,119
Could it be a Fractured spring on the drive shaft.
Charles
1971 Commando Fastback
chasbmw is online now   Reply With Quote
Old 01-27-2015, 11:25 AM   #9
Kanticoy
Oddometer: 286
Not that I doubt you, but I had a U-joint failure as well and I would have sworn that it was a final drive issue. I found out that one of the "crimps" that holds the cap onto the U-joint had come loose. Luckily the needle bearings were in tact so I hammered it back into place and then tack welded it on. Many thousands of miles since and no noise. Found the issue when I pulled the FD and had no noise, but when I moved the flange on the drive shaft, sure enough there was the clunk.
Kanticoy is offline   Reply With Quote
Old 01-27-2015, 11:30 AM   #10
spo123
Man About Town
spo123's Avatar
Oddometer: 751
interesting...
I second, Bill Harris's, suggestion......Damaged rivets (if multiple) should cause the frequency suggested.
The LACK of SWARF on the rear end drain plug would point this way, as well...
Pull that rear wheel.
FYI, the u-joint would not produce that many "clicks" in a single revolution of the wheel.
Please keep us "in the loop".
Best wishes as to a "painless" outcome.
spo
1973 /5 LWB Toaster
spo123 is offline   Reply With Quote
Old 01-27-2015, 11:44 PM   #11
Brun
Brun's Avatar
Oddometer: 175
Ah now Jeff, I know how worried you were about nothing going wrong with the ol' RS for months on end. Praise the gods - you have a proper problem to deal with. Waiting with bated breath to read the prognosis.
Cheers
Charlie, and the lovely Brunhilde (74 R90/6)
Graduate, Wallace and Gromit School of Engineering and Design (pending)
Brun is offline   Reply With Quote
Old 01-28-2015, 12:57 AM   #12
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,483
Pfft...just use earplugs and keep riding it, lack of forward motion will make it easier to find.
Initially I suspected the clutch, then the U joint, then the FD....but it was waskelly wivvits.
I'd put up a pic but did not use NASA rated bolts or genuine BMW factory rivets with the holes reamed out to a light press fit.
Link to Classic BMW Racer Project.
Noobs guide to racing.
http://www.advrider.com/forums/showthread.php?t=790873
Saigon to Hanoi two up on a Honda 150
http://advrider.com/forums/showthrea...1009571&page=2
Voltaire is offline   Reply With Quote
Old 01-28-2015, 01:39 AM   #13
Bill Harris
Oddometer: 7,473
You're too modest. The solution you chose was brilliant:
Originally Posted by Voltaire View Post
Wheel is back
My mate made up tapered adapters to go under the nuts.
Whilst arguably ( useful word for around here) not the same as the original BMW rivets, most likely better than the 40 year old disintegrating that came apart in the last race at probably over 100 mph.
Looking forward to next two race meets to see how the new rear Ohlins and modified Racetech front end go
For ref, the whole thread:
http://www.advrider.com/forums/showthread.php?t=1032754
--Bill
'73 R60/5 Toaster
Old 01-28-2015, 04:09 AM   #14
ME 109 OP
ME 109's Avatar
Oddometer: 2,572
It wasn't the final drive
It's the gearbox.
But I just made the flange puller tools the other day, so the sucker is on the bench with the flange removed.
When I got home from work the first thing I did was to rotate the rear wheel to re-assess. I thought the same thing, that all the noise was from the final drive.
I can turn the output flange by hand in neutral, but it was bloody stiff. I couldn't turn it when in gear.
In neutral, the input shaft appears unaffected when rotated.
I did put a taller 5th in, a year or so ago. I've checked the numbers for the correct non x gear and it matched the receipt. My RS build was Sept, 81
The speedo cable broke on the way home this last ride too. But the speedo cable drive gears are fine.
Hey maybe I should change the thread title to '81 tranny clunking' It's not too late.
Old 01-28-2015, 05:18 AM   #15
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,418
Well, the good news is you know how to fix it!
Times are GMT -7.   It's 07:05 AM.
