05-17-2011, 01:21 PM
#181 | |
Grin!
Oddometer: 4,429
05-18-2011, 07:07 PM
#182 | ||
Hacking and welding
Oddometer: 64
The Hooligan (R80/7 Cafe Project) |
05-19-2011, 08:47 AM
#183 |
Oddometer: 250
Any idea if the acewell will work with my dyna III electronic ignition?
about to take the plunge. Also, any further info on the charge light situation? still best to use an external light or has a solution for the acewell light been discovered? Thanks, Aric |
05-19-2011, 09:06 AM
#184 | |
Grin!
Oddometer: 4,429
In my correspondence with Craig, at Acewell UK, he sent me his thoughts on how to use the "Hazard" symbol as a charging light on the 2000-series Acewells, and he then refers to the new units being developed now.
From Craig at Acewell: Quote:
05-19-2011, 12:49 PM
#185 |
Oddometer: 250
Thanks Bob, that's helpful. Any idea about compatibility with the electronic ignition, I no longer have the bean can.
05-19-2011, 02:53 PM
#186 |
Grin!
Oddometer: 4,429
I have put one on a /6 with points, and on a bike with Hall sensor, hooked up per instructions, and they both work fine (it is the tach pickup that depends on the "ignition" sensor, and signal is picked up at the coil, either way)
05-20-2011, 06:19 AM
#187 |
Oddometer: 250
Then I guess the only thing left to do is order one up! I'll get the speedo cable as well- anyone else have more feedback on the s11 cable?
05-20-2011, 07:03 AM
#188 |
cascadian
Oddometer: 189
simple easy..
works fine.. |
06-06-2011, 09:12 AM
#189 |
Oddometer: 250
Got the 2853 from dime city with s11 cable, all electrics are working- 2 questions- anyone know how to get the fuel sensor to stop blinking and does the yellow tach wire go straight to the coil or to the black tach wire in the harness?
pics soon. |
06-06-2011, 10:33 AM
#190 |
Grin!
Oddometer: 4,429
My fuel gauge blinks, too... not hooked up to anything.
What model do you have? I have a /6, so there is no tach wire, but the later bikes with electronic tachs have that wire...The black tach wire in the harness goes to/from the coil, so you can use it as is... try it and see if it works! I am having issues with the tach signal not being at all steady (jumps to 2x revs and back again).... but I have plain points, not the electronic ignition. I ran the wire to the coil directly... might have to try the "wrap it around the sparkplug lead" method to see if it works better. On the other bike that I put an Acewell on, the tach worked perfectly, but it was electronic ignition... |
06-06-2011, 12:19 PM
#191 |
Oddometer: 250
Great, thanks-
not quite road worthy yet, but soon... ![]()
06-25-2011, 07:28 AM
#192 | |
Oddometer: 19
Cheers, Colby |
06-25-2011, 07:46 AM
#193 |
Oddometer: 250
love the motogadget stuff- wanted the classic but not going to spend that kind of money. happy with this so far.
06-30-2011, 03:34 PM
#194 |
Oddometer: 20
I have the 3904 acewell, and was able to successfully hook to th original black tach wire in the harness to the yellow acewell wire. Not jumpy at all, and works like a charm. I too ordered the acewelll s-11 cable from dimecity. Seemed like fast friendly service, and got a tracking number this morning :)
07-01-2011, 07:35 AM
#195 |
Oddometer: 250
Thanks, I did just that, wired the black the yellow and have a good tach reading.
Here's my problem though- I took the bike for the first ride since the re-builid and melted some wires under the tank, right front turn signal. engine died, cut the wires and restarted, head down the road, engine cut again but couldn't locate any more melting. Looking through the harness where it meets the acewell wiring it looks like I used the black/grey wire that runs through the smaller fuse for power and the blue/green wire for the gen light. is this the problem? too much current? do i need to split the blue/green wire for power and gen light? any help appreciated, don't want to fry anything else! The bike will start and idle without issue. |
