04-17-2012, 06:46 PM
#226 |
Grin!
Oddometer: 4,429
Very clever!
I have never gotten the second Acewell to work on Ole Red... so I am talking with Dime City Cycles, where I bought it, and hoping that I can get another one ... the one that DID work was awesome! ![]() |
05-28-2012, 05:05 AM
#227 |
Oddometer: 2
I have a suggestion for the charge light indicator issue
Here is what I did you can get more info here Airheadr80.tumblr.com My solution is to install a change over relay, basically the neg wire suplly that gies to the charge indicator will control a coil of a relay that operates a n/o contact that is supplied via a positive ignition switched wire. I’ve done this and tested it and it all works fine. Feel free to contact me if you require a wiring diagram of this :) |
05-28-2012, 05:48 AM
#228 | |
Oddometer: 44
05-28-2012, 05:52 AM
#229 | |
Old-School BMWs
Oddometer: 159
You would think that there is a ratio adjustment that would work for either speed sensor. The airhead alone comes in 3 or 4 different speedo ratios. If nobody has figured this out by the time I mount mine I will call acewell customer service. |
05-28-2012, 07:06 PM
#230 | |
Oddometer: 2
Site under the sensor. I think it's 1380 and 1400 Depending on which model BMW you have Here is the link http://www.acewell.de/en/accessories...-ta7-bmw-boxer |
05-28-2012, 11:12 PM
#231 |
enamoured
Oddometer: 2,489
Has anyone had any luck fitting an alternate aftermarket speedo other than the trailtech or acewell? I'm after something small or retro but not expensive- mutually exclusive probability high.
I like these but I would assume they are run off the front wheel http://www.trademe.co.nz/Browse/List...x?id=477492269 is there a general rule re ratios for speedos? There must be some crossover between makes. |
05-29-2012, 09:28 AM
#232 |
Grin!
Oddometer: 4,429
Ratios vary all over the place... no easy conversion with mechanical speedos...at one point I was looking at the XS650 speedos but the ratios are all wrong.
05-29-2012, 01:07 PM
#233 |
enamoured
Oddometer: 2,489
06-02-2012, 01:43 AM
#234 | |
Anglo-Saxon
Oddometer: 426
Here is the answer to your question. Before fitting the acewell, it is necessary to find how far the vehicle moves with a single turn of the speedo cable.
Mark the tyre and ground, and push forward 1 wheel revolution - measure the distance travelled in MM. Put a piece of tape on the end of the original speedo cable to produce a flag, push the bike forward 1 wheel revolution again, but this time count the number of revolutions of the speedo cable. Divide the distance travelled, by the number of rotations of the speedo cable, and enter this number into the acewell. e.g. If the bike moves forward 1700mm and the speedo cable turned 3 times, then enter 567 into the C screen Regards Jake. Quote:
'A tourist sees what he went to see, a traveller sees what he sees' |
06-03-2012, 01:04 PM
#235 |
Grin!
Oddometer: 4,429
I "calibrated" by trial and error: find one of those "your speed is xx" that the cops put out to show you much you're speeding.... then while doing a steady rpm, note what the radar says vs. what the Acewell says... then go into the adjustment screen on the Acewell and try changing it by ten or twenty, whatever, and ride by again: repeat until you are satisfied that it is accurate. Works great!
06-04-2012, 10:30 AM
#236 | |
Mad Scientist
Oddometer: 2,966
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
06-04-2012, 11:13 AM
#237 |
Oddometer: 12
Finally! just got it done (feathering in the bucket to the computer desk bezel). Here is the finished product!
mohabie screwed with this post 03-15-2013 at 09:18 AM |
06-04-2012, 01:08 PM
#238 |
enamoured
Oddometer: 2,489
That is fantastic work there Mohabie!
06-04-2012, 01:19 PM
#239 |
Old-School BMWs
Oddometer: 159
06-04-2012, 10:15 PM
#240 |
Oddometer: 8
Subscribed!
Currently building up my '84 R65 and am now sorting through the bike wires and Acewell speedo wires... arg, a guy can go colour blind looking at all those wires! If I had taken a 12v electrical course in school I would have failed it for sure and if I had hair it would be gone by now from pulling it out!
A little further along since this pic was taken
