Old 10-10-2012, 06:35 PM   #316
tete
clown shoes
Oddometer: 346
Yes!
1980 BMW R100RS -
tete is offline   Reply With Quote
Old 10-11-2012, 10:36 AM   #317
craydds
craydds's Avatar
Oddometer: 1,167
random pictures
pictures of installation in no particular order.
out with the ol' speedo cable:
in with the Acewell S11 speed sensor:
speed sensor plug "C" (acewell schematic). red an white wires from the sensor connect into acewell harness green and black. red-to-green. black goes to ground (-), but the purple shown on the acewell schematic is also negative. so, white-to-black, or white-to-purple? a simple test of the connections should show if the speedo functions. has anyone done this connection?
ABC #12947
'75 R90S
craydds screwed with this post 10-11-2012 at 01:21 PM
craydds is offline   Reply With Quote
Old 10-11-2012, 10:46 AM   #318
craydds
craydds's Avatar
Oddometer: 1,167
yellow tach wire to coil:
there is an temp sensor. guess I'll use it for oil temp. will drill and tap into oil pan:
there is a mode selection / lap timer switch. plugs into acewell harness. I'll try it. If I don't like it or don't need it, it can be removed:
ABC #12947
'75 R90S
Old 10-11-2012, 10:57 AM   #319
craydds
craydds's Avatar
Oddometer: 1,167
I think bpeckm cut off the plug-ins and wired directly. I used the plug-ins, labeled them and all wires according to the Acewell schematic.
plug "B", wire colors are the same on both sides:
plug "A", wire colors are differnet on each side. STUDY your wiring diagram.
give all connections a little dab:
ABC #12947
'75 R90S
Old 10-11-2012, 11:24 AM   #320
craydds
craydds's Avatar
Oddometer: 1,167
turn signals
the Acewell harness wired directly to the turn signals:
done. wire from Acewell harness goes directly to turn signal:
ABC #12947
'75 R90S
Old 10-11-2012, 11:47 AM   #321
craydds
craydds's Avatar
Oddometer: 1,167
fuel
the blue wire from plug "b" (see Acewell diagram post #302) is the fuel wire; not needed so it was deleted. the gray wire is a nothing wire that went to nowhere so it was excised:
ABC #12947
'75 R90S
Old 10-11-2012, 11:56 AM   #322
craydds
craydds's Avatar
Oddometer: 1,167
connections
time to connect each wire:
ace red to bmw green/black, and so on, until all are connected:
say goodbye to the stock plug. sob.
ABC #12947
'75 R90S
Old 10-11-2012, 12:04 PM   #323
craydds
craydds's Avatar
Oddometer: 1,167
study
Know YOUR bike's wiring. I like the BMW owner's manual schematic, seems to be the most accurate (see post #293 for a '75 R90S). Study bpeckm's wiring instructions! Read through this thread again, and again. Know your specific Acewell model wiring diagram. (see post #302 for a model 4454 diagram).
ABC #12947
'75 R90S
Old 10-11-2012, 01:31 PM   #324
craydds
craydds's Avatar
Oddometer: 1,167
generator
I bought a light to make a generator warning lamp; will connect this weekend. A few other connections to make, then it will be ready for testing and calibrations.
ABC #12947
'75 R90S
Old 10-12-2012, 12:51 AM   #325
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,509
Originally Posted by craydds View Post
adding an "idiot light" or resistor:
tried to draw a wiring diagram. can't scan the entire drawing as a photo. must be the scanner. no way it is the operator's fault. I scanned the drawing as a document, which worked well. I can email the document, but don't know how to post a document here.
Thanks for the drawing. What size resistor did you use?
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 10-12-2012, 04:21 AM   #326
craydds
craydds's Avatar
Oddometer: 1,167
Chris, I have not completed this install, yet. I got the resistor idea from another thread; I'll try to find that again. They posted a link to Motorrad, http://www.motoelekt.com/charging.htm, who sold a resistor ready made to wire into place. Motorrad still lists the resistor, but it is part of their Omega charging kit; I don't see the resistor listed as a separately available item. I am going to call them.
ABC #12947
'75 R90S
Old 10-12-2012, 04:48 AM   #327
craydds
craydds's Avatar
Oddometer: 1,167
Here is a link, http://www.motoelekt.com/genlightacc.htm , from sparymoto, post #4, in this thread http://www.advrider.com/forums/showt...rator+resistor .
ABC #12947
'75 R90S
Old 10-12-2012, 06:57 AM   #328
craydds
craydds's Avatar
Oddometer: 1,167
I called Rick Jones at Motorrad and ordered the resistor.
ABC #12947
'75 R90S
Old 10-12-2012, 08:14 AM   #329
benthic
glutton 4 punishment
benthic's Avatar
Oddometer: 397
Great information from everyone! Thanks! One thing I don't remember reading - if I WANT the "idiot" gen light, is there a specific kind/size filament bulb I need to buy? I might wire my 2853 up this weekend...
1978 BMW R80/7
"all we need is time and courage." - Renner
"A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M
www.blindfishz.com
benthic is offline   Reply With Quote
Old 10-12-2012, 08:27 AM   #330
craydds
craydds's Avatar
Oddometer: 1,167
See post #324 above as an example. I think most types of warning lamps will work, but I think it should be an incandescent bulb, not an LED (I'll check with ignatz72).
ABC #12947
'75 R90S
craydds screwed with this post 10-12-2012 at 08:44 AM
Times are GMT -7.   It's 02:15 AM.
