Old 10-12-2012, 09:01 AM   #331
craydds
craydds's Avatar
Oddometer: 1,167
Looking through ignatz72's thread, it seems that one should use an incandescent bulb for the generator warning lamp. Has anyone tried an LED?
Read post #119 by Bill Harris here http://www.advrider.com/forums/showt...r#post18097765
ABC #12947
'75 R90S
craydds screwed with this post 10-12-2012 at 09:12 AM
craydds is offline   Reply With Quote
Old 10-12-2012, 09:27 AM   #332
benthic
glutton 4 punishment
benthic's Avatar
Oddometer: 397
Originally Posted by bmweuro View Post
Thanks for the drawing. What size resistor did you use?
Snowbum says :Resistor discussion: Nearly any type of resistor may be used. It can be the old-fashioned type called 'carbon composition', or any modern type of 'film' or 'deposited carbon' type....or even a 'wire wound' type. The resistor value CAN be 470 ohms, but my tests indicate that 330 ohms is better.
from the same Snowbum article: The GEN lamp is rated at 12 volts and 3 watts. Ohms law says that the lamp resistance is 48 ohms when energized by 12 volts. I guess I'll poke around an autoparts store or radioshack...
EDIT: found this from Snowbum too about the Gen lamp:recommended 168 lamp = 4.90 watts, .35 ampere, rated 1500 hours, a.c.
1978 BMW R80/7
"all we need is time and courage." - Renner
"A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M
www.blindfishz.com
benthic screwed with this post 10-12-2012 at 09:40 AM
benthic is offline   Reply With Quote
Old 10-12-2012, 10:07 AM   #333
craydds
craydds's Avatar
Oddometer: 1,167
Good info, thanks. I'll check the spec's on my little red lamp.
ABC #12947
'75 R90S
Old 10-14-2012, 02:21 PM   #334
craydds
craydds's Avatar
Oddometer: 1,167
tach cable?
Tach cable has to go:
Gone:
Now, what do I do with the "hole" ? And the rubber grommet? Is there a solid rubber grommet - no hole for the cable?
Any ideas? What have my fellow inmates done?
ABC #12947
'75 R90S
Old 10-14-2012, 08:16 PM   #335
benthic
benthic's Avatar
Oddometer: 397
I started hooking my Acewell 2853 up to my 1978 R80/7 today. it all went fairly well. My wire colors don't match what's been noted so far, but i think I've got it worked out.
My layout is:
Acewell--------------funtion----------------- BMW
orange-------------- turnsignal -------------new wire from signal
light green--------- high beam ------------ white
light blue -----------haz/Brake fluid -------blue/brown
purple--------------- nuetral ---------------- brown/black
gray -----------------oil pressure----------- brown/green
white ---------------- turn signal ----------- new wire from signal
black ----------------ground -----------------brown
brown --------------clock power -----------new wire to battery
red ------------------speedo ilumination---gray/black
blue --------------- fuel ---------------------- no match
yellow ------------- tach --------------------- black
left over bmw wires:
black/white - capped and using the new individual wires
blue
blue/green
I used the blue and blue/green as described in craydds' sketch below except i didn't wire into the acewell red, but the warning light I bought didn't come on... everything else appears to work though, so i'm wondering if i just got the wrong light.
no pictures of my rat nest, i'll just embarrass myself;)
1978 BMW R80/7
www.blindfishz.com
Old 10-14-2012, 08:28 PM   #336
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 6,065
Gone:
I simply used some black silicone caulk to fill the hole in the rubber grommet... Later front-covers (after the electronic tachs came in ('+78?)) don't have the notch for the rubber grommet, if you would want to go that way....!
I also used some high-melting-point grease, like wheel-bearing grease, to plug the hole inside the front cover where the tach cable had been.....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is online now   Reply With Quote
Old 10-15-2012, 04:48 AM   #337
craydds
craydds's Avatar
Oddometer: 1,167
Originally Posted by bpeckm View Post
I simply used some black silicone caulk to fill the hole in the rubber grommet. Later front-covers (after the electronic tachs came in ('+78?)) don't have the notch for the rubber grommet, if you would want to go that way. I also used some high-melting-point grease, like wheel-bearing grease, to plug the hole inside the front cover where the tach cable had been.
Thanks, bpeckm! Good solution. I will order a new grommet, because the old one is splitting into pieces.
ABC #12947
'75 R90S
Old 10-15-2012, 05:04 AM   #338
craydds
craydds's Avatar
Oddometer: 1,167
Originally Posted by benthic View Post
My layout is:
On my bike ('75 R90S) the grey/black is for instrument illumination, but is positive (+) only when the headlight is ON. That is why I used the BMW green/black connected to Acewell red; green/black is (+) when key is ON. On your bike ('78) the grey/black is (+) always when the key is ON ?
Good luck on your generator light. Test the lamp separately to make sure it lights up.
ABC #12947
'75 R90S
craydds screwed with this post 10-15-2012 at 08:49 AM
Old 10-15-2012, 09:53 AM   #339
Blane
Blane's Avatar
Oddometer: 305
If you find one let me know. I don't think they sell those seperately any more.
2004 R1150GS Adventure (The Valdez)
1973 R75/5 Red Toaster (Amy) SOLD
1970's Frankenbeemer Cafe (Love this Bike)
1970 R75/5 rebuild in progress
Blane is offline   Reply With Quote
Old 10-15-2012, 10:39 AM   #340
craydds
craydds's Avatar
Oddometer: 1,167
part # 62-21-1-351-554, look here http://www.maxbmwmotorcycles.com/fic...1&rnd=08102012 . I ordered one this morning.
ABC #12947
'75 R90S
Old 10-20-2012, 04:39 AM   #341
MIOB
MIOB's Avatar
Oddometer: 1,018
Gone:
If make the grommet really warm (in boiling water?) won't it become flexible enough to slide it over your Acewell cable?
Still enjoying my new Acewell 4454 a lot. It's a hughe upgrade from the already great 2853
MIOB is offline   Reply With Quote
Old 10-20-2012, 06:12 AM   #342
bill42
Old-School BMWs
bill42's Avatar
Oddometer: 374
My later r100 was made with an electric tach. Somebody with more knowledge than me can probably tell you what factory plug you need. If not maybe check the fische on maxBMW.com and look at a 1981 airhead.
Bill C.
On The Level BMW Club magazine photo editor / Art Director
1981 BMW R100 Café build thread
1958 BMW R50 aka: A BMW Motorcycle Story (link)
bill42 is offline   Reply With Quote
Old 10-21-2012, 10:03 AM   #343
craydds
craydds's Avatar
Oddometer: 1,167
You may be thinking of the Acewell speedometer sensor. There is no Acewell cable in place of the stock tachometer cable. The BMW tach cable is removed, that is why I need to plug the hole.
ABC #12947
'75 R90S
Old 10-21-2012, 10:21 PM   #344
MIOB
MIOB's Avatar
Oddometer: 1,018
Ok, sorry, misunderstood
Old 10-22-2012, 04:20 AM   #345
craydds
craydds's Avatar
Oddometer: 1,167
Nice work, MIOB !! http://www.shedbuiltbikes.com/my-projects/ .
ABC #12947
'75 R90S
Times are GMT -7.   It's 10:48 AM.
