Old 12-10-2012, 04:22 AM   #391
craydds
craydds's Avatar
Oddometer: 1,167
Originally Posted by benthic View Post
I didn't find anything in the setup to let me turn off the fuel flashing.
In the set-up menu, go to fuel sensor resistance settings - you could select the resistance, or select OFF mode.
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 12-10-2012, 07:48 AM   #392
benthic
glutton 4 punishment
benthic's Avatar
Oddometer: 397
I don't think my 2853 has that option. I just looked at the pdf manual again and it makes no mention of it either. I'll check again when I'm home tonight...
1978 BMW R80/7
"all we need is time and courage." - Renner
"A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M
www.blindfishz.com
benthic is offline   Reply With Quote
Old 01-02-2013, 09:49 AM   #393
craydds
craydds's Avatar
Oddometer: 1,167
Temp sensor
My Acewell came with a temperature sending unit. I am using it for oil temp:
It is the M10x1.0 thread:
Sending unit seated in place:
I used a crush washer and some gasket compound. No leaks so far:
Still no leaks:
On a water cooled bike one could use the sending unit for water temp, but for our old airheads why not use it for oil temp? It does function properly and I now have an oil temp reading on my Ace:
ABC #12947
'75 R90S
Old 01-02-2013, 10:12 AM   #394
some_guy
some_guy's Avatar
Oddometer: 144
What model? I would have to figure out how to rig that up with the thermostat and oil cooler...
some_guy is offline   Reply With Quote
Old 01-02-2013, 10:22 AM   #395
craydds
craydds's Avatar
Oddometer: 1,167
That is on my 1975 R90S. I previously had an oil-cooler/thermostat on it but it was removed and traded away. If you have the oil-cooler/thermostat you will have to find another location (methinks) for the sending unit. Perhaps tap into the oil pan? That was my original plan; seems simple enough. But I ended up doing it as pictured above.
ABC #12947
'75 R90S
Old 01-02-2013, 10:43 AM   #396
craydds
craydds's Avatar
Oddometer: 1,167
What model?
I bought the ACE-4454AB http://www.acewell.co.uk/Acewell%20S...ion=full&id=41 , and the ACE-TES temp sensor http://www.acewell.co.uk/Acewell%20A...ion=full&id=32 . This is the speed sensor - http://www.acewell.co.uk/Acewell%20A...ion=full&id=61 .
ABC #12947
'75 R90S
Old 01-03-2013, 09:14 AM   #397
batoutoflahonda
Oddometer: 1,386
cleaning up the wiring question
So I'm doing the Acewell and a Baja designs head light converted to an H4 high low, Eastern Beaver relay mod, and making a switch panel with an acc plug. I was wondering what you guys are doing with all those bulky connectors to make them look clean?
The mess:
I keep thinking aircraft canon plugs are the way to go. But it would mean repinning something like 80 wires.
So, hit me with your ideas/solutions for a clean install.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda is offline   Reply With Quote
Old 01-03-2013, 09:32 AM   #398
craydds
craydds's Avatar
Oddometer: 1,167
ABC #12947
'75 R90S
Old 01-03-2013, 09:44 AM   #399
batoutoflahonda
Oddometer: 1,386
^^^ nothing good comes easy, does it?
Old 01-03-2013, 09:50 AM   #400
craydds
craydds's Avatar
Oddometer: 1,167
Sounds like a cool project that would have very neat and tidy results. Make lotsa pics!
ABC #12947
'75 R90S
Old 01-03-2013, 07:56 PM   #401
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 6,054
If it's not something that has to come apart, I solder and heat-shrink.... it makes for a small diameter joint. I found it useful in doing the harness-to-Acewell connections after I cut off the big headlight molded plug on the Slash 6....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-14-2013, 03:10 AM   #402
KenyaBiker
KenyaRider
Oddometer: 3
That charge light on the side...
Wow! was really happy to find this thread! I have a 1981 BMW R100RS that I've converted to a Cafe Racer.
I recently ordered the ACEWELL speedo because the big old plastic ones are horrendous and the originalspeedo was inaccurate. Your post got me 95% of the way through the installation, but I couldn't get my mind around having to install the charge light separately, so I roped in a mate of mine who is a car electronics propeller head and he provided me with a simple way to use the LED in the ACEWELL speedo rather than the work around you have suggested.
We simply wired in a relay to replicate what the bulb would have done and it works perfectly. If you need a diagram and pictures, I'm happy to supply them.
KenyaBiker is offline   Reply With Quote
Old 01-14-2013, 03:57 AM   #403
some_guy
some_guy's Avatar
Oddometer: 144
I'd be interested to see what you did. I was thinking bout doing this as well, but just decided to wire in a bulb and resistor figuring it'd be less cluttered.
Old 01-14-2013, 03:41 PM   #404
Jeremiah
Jeremiah's Avatar
Oddometer: 151
We simply wired in a relay to replicate what the bulb would have done and it works perfectly. If you need a diagram and pictures, I'm happy to supply them.[/QUOTE]
I would love to see how you did it as I am getting ready to do my R65. Any ideas are appreciated!
DL1000K3
R65
R100S
GL1800
Jeremiah is offline   Reply With Quote
Old 01-16-2013, 12:58 AM   #405
KenyaBiker
KenyaRider
Oddometer: 3
Thanks[/QUOTE]
OK guys, Happy to oblige, I'll take some pics tonight and provide an update diagram.
.. also still need to get my head around uploading pics...
Times are GMT -7.   It's 05:18 PM.
