12-08-2009, 04:38 PM
#31 |
Still on 3 wheels
Oddometer: 3,382
Good job!
I just recently discovered the "Acewell" on the web and decided it was what I needed for my R90/6....R100S sidecar tug project. Both my stock instrument pods are rather poor...plus I'm using the R100S engine with the R90/6 wiring harness. (electronic VS mechanical tachometer) Lo and behold you have saved me a lot of "footwork" with your great post! Could a person possibly wire in the "Red Emergency Flasher light" on the pod to use as the BMW charging light? Or will the BMW charging system wiring complexity interfere with that application? Thanks...... |
12-08-2009, 05:30 PM
#32 | |
all roads are one
Oddometer: 593
Can't seem to find the outside diameter of the instrument listed on Acewell's site. Anyone know ? |
12-08-2009, 06:02 PM
#33 | |
Grin!
Oddometer: 4,429
12-08-2009, 06:08 PM
#34 | |
Grin!
Oddometer: 4,429
BMW's system works fine, it just cannot be wired into a standard "+" and "-". It is probably a holdover from the old generator days, it was pretty standard on those old cars that actually had a generator (as opposed to today's alternators) My solution, next time around, would be to order the unit that does not have the "gen" light, and simply use an external light (like I did on this bike, since I ended up with an un-used indicator within the pod.... ) |
12-08-2009, 06:42 PM
#35 | |
all roads are one
Oddometer: 593
12-09-2009, 02:17 PM
#36 |
Oddometer: 1,446
I bought a bashed-up DR350 and rather than take the time to source a used tach I installed an Acewell 3700 series on it (http://www.electrosport.com/street/s...eries-3700.php)
I found the wiring instructions to be a bit vague but not unmanageable- but there wasn't any real help when it came to mounting the pickup or magnet. The supplied magnets were both useless for this application and I ended up using a magnet from a fridge hold down that I epoxied into a depression I drilled into the rotor. I had to fab up my own bracket for the pick-up, and the length of the supplied cable (not easily modified) meant it had to go in front of the fork leg in order to accommodate the long travel suspension. The installation turned out to be a minor PITA but I am very happy with the instrument and it's function- enough so that I'll probably buy another one to replace the Vapor instrument on my XR650R My Bracket solution: ![]() The addition to the standard brake mount was made from a scrap of 1/8" steel plate. The center was cut out to make it lighter ![]() Mounted up. The plate is curved to hug the fork leg and provide clearance for the rotor. ![]() All done. The magnet depression was started with a standard bit, then flattened with a reground bit of the same size so that the magnet would seat firmly. A little metal epoxy was added to seal the deal. |
12-09-2009, 08:02 PM
#37 |
Grin!
Oddometer: 4,429
Nicely done!
Getting the magnet and the pickup close to each other obviously varies widely from bike to bike....but it should be good for the ages (we hope!) |
01-02-2010, 04:06 PM
#38 |
Grin!
Oddometer: 4,429
Got out for a nice ride today, and took some pics at the beach:
01-02-2010, 04:33 PM
#39 | |
Still on 3 wheels
Oddometer: 3,382
Go ahead and rub it in! Was a blazing 25 degrees here today..... Bike looks great!
01-02-2010, 06:10 PM
#40 |
Grin!
Oddometer: 4,429
The shots I took last year of the red bike made the sand look like snow....
01-15-2010, 03:44 PM
#41 |
Still on 3 wheels
Oddometer: 3,382
Received my Acewell unit today...will be wiring it up this weekend....my BMW (using a 1974 R90/6 chassis / wiring) was a mechanical tach unit with points...I'm a little unclear about how to hook up the tack...they refer to "wrapping a wire around the coil 2 -5 times...." I have two coils..they do not address that...Do I wrap both coils? The picture shows them "wrapping a coil (sparkplug) wire" rather than a "coil". Wrap both wires or one?....I don't know....never seen a tach hooked up that way......I'm a bit confused on that one.......
bmwhacker screwed with this post 01-15-2010 at 03:59 PM |
01-15-2010, 03:46 PM
#42 | |
the thread-killer
Oddometer: 4,297
You have allready aired this complaint in another post...... Any resolution to this yet?/ HAve they given you any answers yet? Robert |
01-15-2010, 03:50 PM
#43 | |
Still on 3 wheels
Oddometer: 3,382
No.................read the other thread........the situation kind of died in its' tracks....I guess it's "no ones" fault................ |
01-15-2010, 03:57 PM
#44 | |
the thread-killer
Oddometer: 4,297
Someone is at fault, somewhere. The only thing that I want to add is that after the lengthy explanation on the other thread, at 4:44 p.m. you came back here to this thread and started it all over again.... without the lengthy explanation and with no reference to the other thread..at all. Lets play fair. Robert
01-15-2010, 04:00 PM
#45 | |
Still on 3 wheels
Oddometer: 3,382
Yes, you are 100% correct........"Deleted"..........may the internet gods forgive me and my errant ways......Bottom line is that the Acewell Unit looks like a good buy......and I am sure I will like it. Plus this thread is a big help for the installation....The people at Acewell have been great to deal with so far...I would not hesitate to purchase from them again.....I received the unit today and it looks good! bmwhacker screwed with this post 01-15-2010 at 08:24 PM |
