Old 05-25-2010, 02:31 PM   #61
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 983
so, while someone else resurrected this thread, I have to ask...
why hasnt anyone reto-fitted on of these into a /5 bucket. Are they that much smaller? If anyone has,can I see a pict or two...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 05-26-2010, 08:06 AM   #62
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
The Acewell has a digital readout and I've found that it needs to sit at a certain angle to be perfectly readable, especially at about sundown. My only beef so far is that the small indicator lights are a little hard to see under direct sunlight.
Laying the Acewell flat in a /5 housing would likely render it unreadable.(?) But I never tried it...
I really like the gauge so far. The speedo is dead accurate when calibrated and the two trip odometers are a good addition.
Since this photo I tipped the housing back a tiny bit to find its' "sweet spot" for better visibility.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
bmwhacker screwed with this post 05-26-2010 at 08:11 AM
Old 05-26-2010, 07:35 PM   #63
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,578
Thats a really good point, I noticed on my bike that I will have to find a better angle for viewing.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 05-27-2010, 06:44 AM   #64
Beater
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,247
That is my ONLY complaint about mine. I wound up heating the mounting arm so that I could bend it about 15 degrees ... this way the face would point directly at me. It's bizarre that the readability issue only happens in low light situations. Daytime it's perfect ... get to be dusk or after dark .. I would have to lower my head about 2 inches to see it.
Oh and ... I wound up taking the three screws out that connect the mounting arm to the unit itself and putting on some Loctite
But beyond that ... I've been inpressed. The signal indicators are INFINATELY brighter than my stock speedo. Now I at least don't look like a complete noob riding down the road with a blinker on.
PS - I know that this might start something ... but I haven't hooked my generator light up ... and my battery is charging nicely. Flame away ... (PS- about ~1500 miles since the Acewell install) ... Yes, I am going to do it ...
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is offline   Reply With Quote
Old 05-27-2010, 06:04 PM   #65
getset
----GO----
getset's Avatar
Oddometer: 109
Anyone know of a source for purchasing one of these speedos? They seem to be out of stock everywhere.
thanks.
getset is offline   Reply With Quote
Old 05-27-2010, 06:35 PM   #66
anonny
anonny's Avatar
Oddometer: 5,578
thanks.
I got mine from the horses petuty http://www.acewell-meter.com/
Old 05-27-2010, 08:12 PM   #67
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
thanks.
I got mine from "Electrosports" in Oceanside Ca. They shipped it out quickly. I was happy with their fast service.
ABC# 1992
Old 05-27-2010, 09:21 PM   #68
anonny
anonny's Avatar
Oddometer: 5,578
Originally Posted by Chopperman
How? email and order? I dont see ordering info...or did I miss it?
Thats odd, just looked and don't see the "put item in cart" option... I'm positive I bought it off their website in December. Guess they changed how they do business.
Old 05-28-2010, 12:18 AM   #69
MIOB
MIOB's Avatar
Oddometer: 974
thanks.
Dime City also has them and tons of other cool stuff:
http://www.dimecitycycles.com/
MIOB is offline   Reply With Quote
Old 09-25-2010, 12:36 AM   #70
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
I've been using the Acewell speedo now all summer and have been very happy with its' performance. Have ridden through some pouring rain and it is definately waterproof. I like the two resettable odometers. The "Mode" button is real easy to push with heavy gloves on too. My only complaint is that the green LED signal indicators are a little hard to see under direct sunlight. I originally used the "wrap" method for the tach pickup lead but finally wired directly to the coil. Much less "bouncing" of the bar graph now. I thought of purchasing another from Electrosports to have as a spare if I ever needed it but see that they say "product no longer available"....I wonder if they quit making them or if Electrosports just quit selling them?
ABC# 1992
Old 09-25-2010, 09:21 AM   #71
anonny
anonny's Avatar
Oddometer: 5,578
Mine crapped out after a few weeks, going to have to look into their warranty.
Old 09-25-2010, 12:17 PM   #72
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
Bummer! When I purchased mine this Spring it was only $120.00 or so. Reverting back to original BMW gauges isn't a very good option so I thought I might buy another one to rat-hole if ever needed.
I'll have to read your thread to see what happened to yours'....
Couldn't find any comments about the Acewell failure in your thread.( I was following your build a while back) ....What did it do? or not do?
ABC# 1992
bmwhacker screwed with this post 09-25-2010 at 12:26 PM
Old 09-25-2010, 09:24 PM   #73
anonny
anonny's Avatar
Oddometer: 5,578
Some functions work when first energized, once the bike is started the display fades to nothing and data gets lost, clock resets back to 0. Turn off key and reboot and it goes through the same cycle.
Bummer
Old 09-26-2010, 08:28 PM   #74
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
Bummer
It must have a grudge against Kaws'....
ABC# 1992
Old 09-28-2010, 03:33 PM   #75
bpeckm OP
Grin!
bpeckm's Avatar
Oddometer: 5,797
Sounds like it is getting a jolt of juice, which is then shut off and so the display fades away. Intermittent contact? What did you wire the power source to?
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Times are GMT -7.   It's 07:00 AM.
