Old 10-29-2010, 10:09 AM   #16
HalfFast
Double Secret Pit Ninja
HalfFast's Avatar
Oddometer: 254
This thread should be bumped to the top
Just called Derek after finding this thread and he has my parts in stock. He is only 20 minutes away and I am totally stoked.
The local KTM dealer had me on back order for a month and when I picked up the parts they were the wrong ones.
Allan (Rider)2nd place Sportsman Moto < 2012 SCORE Baja 1000, 2012 2nd place NORRA Mexican 1000 (vintage light), 2013, 2014 1st place NORRA Mexican 1000 (vintage light)
HalfFast is offline   Reply With Quote
Old 11-01-2010, 02:10 PM   #17
motolab OP
motolab's Avatar
Oddometer: 2,695
Just a quick note to say that I have in stock:
Pilot screw well taps.
Added them above as well, so the list is complete.
Regards,
Derek
motolab is offline   Reply With Quote
Old 12-22-2010, 02:13 PM   #18
motolab OP
motolab's Avatar
Oddometer: 2,695
Just a quick note to say that I updated the list to show Aprilia Moto 6.5, Cagiva Canyon 500/600, and GSX-R1100 non-USA applications as far as they are known.
Regards,
Derek
Old 01-11-2011, 07:31 AM   #19
hupjoy
hupjoy's Avatar
Oddometer: 67
please help!!
Originally Posted by motolab View Post
Hello all,
I want to let you all know that I have these KTM items (mentioned if they are also known to fit other makes & models) in stock at below retail (shown in brackets):
584.31.037.000 Throttle Valve Guide, $36.24 ea. ($41.17)(also fits the Aprilia Moto 6.5, Cagiva Canyon 500/600, Suzuki DR650 and '91-'98 non-USA GSX-R1100 BST40 carb) -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=300 and http://www.moto-lab.com/gallery/view?itemid=298 (scroll down for descriptions and links. Click image for high res view)
584.31.021.689 Needle Jet 689 6-X, $16.43 ea. ($19.57) -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=305 (scroll down for descriptions and links. Click image for high res view)
584.31.035.000 Throttle Valve (w/two slide lift holes), $33.17 ea. ($43.19) -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=303 (scroll down for descriptions and links. Click image for high res view)(also fits the '90-'95 Suzuki DR650 BST40 carb as part number 13501-12D00, with the added advantage that the needle hole is 0.12mm or 0.004" smaller, which will help reduce needle hole, jet needle and emulsion tube wear. For an even greater reduction in wear, use the slide below)
13501-32E00 '96-'09 Suzuki DR650 Throttle Valve (w/one slide lift hole), $34.16 ea. ($59.95) -> for inspection guidelines see http://www.moto-lab.com/gallery/view?itemid=303 (scroll down for descriptions and links. Click image for high res view)(also fits Aprilia Moto 6.5)(can also be used the '90-'95 Suzuki DR650 and KTM640 BST40 carbs in order to reduce slide guide, slide, emulsion tube & jet needle wear problems)
584.31.028.000 Diaphragm $23.72 ($39.04)(also fits Aprilia Moto 6.5, Cagiva Canyon 500/600)(also fits Suzuki DR650 & '91-'98 non-USA GSX-R1100 BST40 carb as part number 13507-07D01)(not available separately from Cagiva)
584.31.050.000 Screw (plastic cold start plunger retainer), $4.16 ea. ($7.32)(also fits Aprilia Moto 6.5, Cagiva Canyon 500/600)(also fits the Suzuki DR650 BST40 carb as part number 13418-43410)(not available separately from Cagiva)
KTM0111100000 Rebuild Kit for TPS equipped models, $37.68; this contains the same parts as the 584.31.099.000 Gasket Set ($60.25) except the diaphragm but plus the throttle blade screws and float needle, which normally only comes as part of 584.21.020.000 Needle Valve 2.8 mm ($43.99)(no need for the assembly, as the seat doesn't really ever go bad) Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, pilot screw o-ring, slide guide o-ring, cold start nut to cable seal, two rubber throttle shaft v-seals and two stainless steel socket throttle blade screws.
KTM0111100001 Rebuild Kit, same as above but for models without TPS, $37.68 (also fits Aprilia Moto 6.5 and Cagiva Canyon 500/600)(also fits Suzuki DR650 & '91-'98 non-USA GSX-R1100 BST40 carb). Full list of parts contained in the kit: float needle, needle seat o-ring, cold start enrichment feed pipe o-ring, float bowl gasket, main jet access plug o-ring, pilot screw o-ring, slide guide o-ring, cold start nut to cable seal, two felt throttle shaft seals and two stainless steel socket throttle blade screws.
Float bowl gasket by itself, $6.44 ea. (also fits Aprilia Moto 6.5 and Cagiva Canyon 500/600)(also fits Suzuki DR650 & '91-'98 non-USA GSX-R1100 BST40 carb as part number 13258-44B00)(not available separately from KTM or Cagiva)
N1.50X007.5 Float Seat O-Ring by itself, $1.53 (also fits Aprilia Moto 6.5 and Cagiva Canyon 500/600)(also fits Suzuki DR650 & '91-'98 non-USA GSX-R1100 BST40 carb as part number 13374-35C00)(not available separately from KTM or Cagiva)
584.31.007.045 Idling Jet 45, $5.78 ea. ($10.99)(all sizes of this style jet in stock at the same price)(also fit the Suzuki DR650 BST40 carb, which normally takes a size 42.5 part number 09492-42010)(also fit the Suzuki '91-'98 non-USA GSX-R1100 BST40 carb, which normally takes a size 40.0 part number 09492-40014)
584.31.023.140/142/145 Main Jet 140/142.5/145, $3.68 ea. ($6.99)(all sizes of this style jet in stock at the same price)(also fit the Aprilia Moto 6.5)(also fit the Cagiva Canyon 500/600 BST40 carb, which normally takes a size 147.5 part number 0032395, 150 part number 0032398, 152.5 part number 0032394, 155 part number 0032393 or 157.5 part number 0032397)(also fit the Suzuki DR650 BST40 carb, which normally takes a size 140 part number 09491-28010)(also fit the Suzuki '91-'98 non-USA GSX-R1100 BST40 carb, which normally takes a size 122.5 part number 09491-24013, 125 part number 09491-24010 and/or 127.5 part number 09491-24011)
002-157 Air Bleed 1.2, $3.68 ea. (all sizes of this style jet in stock at the same price)(remove the pressed in main air jet, tap the hole M4X.7 and use the same style of jet to tailor main air correction)(also fit the Aprilia Moto 6.5)(also fit the Cagiva Canyon 500/600 BST40 carb as part number 0032375)(also fit the Suzuki DR650 BST40 carb, which normally takes a size 1.0 part number 09493-20007)(also fit the Suzuki '91-'98 non-USA GSX-R1100 BST40 carb, which normally takes a size 1.2 part number 09493-24007)(not available from KTM)
007-509 Float Bowl Drain Screw, $2.56 ea. (also fits the Aprilia Moto 6.5)(also fits the Cagiva Canyon 500/600)(also fits the Suzuki DR650 BST40 carb as part number 13247-02340)(not available separately from Cagiva or KTM)
584.31.034.6G5 Jet Needle, $9.79ea. ($11.38) For needle inspection guidelines, see http://www.moto-lab.com/gallery/view?itemid=306 (scroll down for descriptions and links. Click image for high res view). Buy the jet kit below to get a needle that doesn't have the wear problems the stock one does.
CRB-KT07-1.1-TI Carb Kit, Factory Pro, $72.76 ($79.95)(buy this to get the titanium needle, which doesn't have the wear problem the stock one does) Full list of parts contained in the kit: titanium needle, #145, 147.5, 150, 152.5 and 155 main jets, stainless steel socket head bowl and diaphragm cover screws, and eight needle clips (they are easy to loose)(I can also get the CRB-S65-1.1-TI kit for the DR650 at $63.66) -> For needle inspection guidelines, see http://www.moto-lab.com/gallery/view?itemid=306 (scroll down for descriptions and links. Click image for high res view)
584.31.032.000 Jet Needle Plastic Shim, $2.45 ea. ($2.82)
584.31.132.000 Jet Needle Metal Shim, $6.54 ea. ($7.59)
584.31.045.000 Jet Needle Circlip, $2.16 ea. ($1.96)
912-A2 M5X12, stainless steel socket head TPS & front throttle cable bracket screws, $0.54 ea. (also fit the Aprilia Moto 6.5, Cagiva Canyon 500/600, and Suzuki DR650 BST40 carb, but not for TPS)
125-A2 M5, stainless steel TPS screw flat washers, $0.09 ea.
127B-A2 M5, stainless steel TPS screw split lock washers, $0.14 ea.
912-A2 M5X14, stainless steel socket head diaphragm cover, right side float bowl & rear throttle cable bracket screws, $0.51 ea. (also fit the Aprilia Moto 6.5, Cagiva Canyon 500/600, Suzuki DR650 and '91-'98 non-USA GSX-R1100 BST40 carb)
912-A2 M5X16, stainless steel socket head left side float bowl screw, $0.56 ea. (also fit the Aprilia Moto 6.5, Cagiva Canyon 500/600, Suzuki DR650 and '91-'98 non-USA GSX-R1100 BST40 carb)
7991-A2 M4X8, stainless steel flat socket TPS bracket screws, $0.70 ea.
PP2699 Float Height Setting Tool, $22.95 ea. (works on most carbs)
35-2270 Pilot Jet Driver, $15.68 ea. (allows easy removal & installation of the pilot jet without the risk of the head stripping)
325-4854 Pilot Screw Well Tap, $10.22 (chasing the threads and lightly greasing the screw will help prevent it from sticking/seizing)
583.12.093.000 Fuel Pump Mikuni Rallye, $86.28 ea. ($120.99)
585.12.087.000 Fuel Pump Mikuni DF52-601, $76.57 ea. ($108.14)
Discussion over here: http://www.advrider.com/forums/showthread.php?t=347184
You can email me at dcapito@moto-lab.com or call me on (650) 363-0535.
Regards,
Derek
Hi, Derek!
I am in desperate need of a rebuild kit for the carb on my 1999 KTM LC4 640 E. It's the stock carb - I believe it's a Mikuni BST 40...KTM has them on backorder until February and it's just sitting in the shop waiting to come back to life!!
I need the gaskets mainly, I believe. I am a total newbie, so my ability to articulate what is needed is limited, but I am pretty sure all that I need is a gasket set for the rebuild. Do you have one for sale?
THANK YOU!!!
Michael
hupjoy is offline   Reply With Quote
Old 01-11-2011, 10:12 AM   #20
motolab OP
motolab's Avatar
Oddometer: 2,695
Originally Posted by hupjoy View Post
Hi, Derek!
THANK YOU!!!
Michael
Hello Michael,
KTM0111100001 Rebuild Kit, for models without TPS, $37.68 (in stock)
Unlike the kit from KTM, this includes the float needle, but does not contain the slide diaphragm, which I have available separately.
584.31.028.000 Diaphragm $23.72 (in stock)
Regards,
Derek
Old 01-30-2011, 09:08 PM   #21
edgarop
Oddometer: 61
Kit required
Im looking for a kit for my 03 640 Adv do you have any and price. where are you located?
edgarop is offline   Reply With Quote
Old 01-30-2011, 09:20 PM   #22
motolab OP
motolab's Avatar
Oddometer: 2,695
In stock in Redwood City, CA.
Regards,
Derek
Old 02-08-2011, 09:06 AM   #23
SikDMAX
Oddometer: 731
PM Sent!
Matt - SikMoto www.Facebook.com/SikMoto San Luis Obispo, CA
SikDMAX is offline   Reply With Quote
Old 02-23-2011, 10:04 AM   #24
helmholtz
Oddometer: 1
Thank you Derek!
I recently picked up a 2001 KTM LC4 with a BST-40 carb that had not been properly jetted for the exhaust and airbox. A quick phone call to Derek and the proper parts were in the mail, the same day.
Derek spent some time going over the wear issues with the BST, things to watch out for, and gave me some general tuning advice for the LC4.
Also, his carb rebuild kit is cheaper than the KTM kit and includes the rubber tipped needle valve(something which is hard to come by from KTM on it's own). The hex head throttle butterfly screws are a very Pro touch too.
Everything worked out great, and the bike starts up on the first kick.
Thank you for providing hard to find parts at a great price and for taking the time to go over the details with me. My used bike purchase started out as a dud, but got a whole lot better with those new jets. That LC4 can pull!
helmholtz is offline   Reply With Quote
Old 02-23-2011, 10:17 AM   #25
motolab OP
motolab's Avatar
Oddometer: 2,695
Sweet! I'm glad everything worked out, and thanks for the kind words!
Regards,
Derek
Old 03-25-2011, 06:37 PM   #26
motolab OP
motolab's Avatar
Oddometer: 2,695
I now have in stock:
Rebuild kits specific to DR650 BST40 carbs.
SUZ0111100002 specific to '90-'91 models.
SUZ0111100003 specific to '92-'93 models.
SUZ0111100004 specific to '94-'11 models.
I added them above as well, so the list is complete.
Regards,
Derek
Old 03-29-2011, 02:25 PM   #27
motolab OP
motolab's Avatar
Oddometer: 2,695
DR650 Needle Jet 09494-00884 for '96-'09 models.
I added it above as well, so the list is complete.
Regards,
Derek
Old 04-07-2011, 01:29 PM   #28
motolab OP
motolab's Avatar
Oddometer: 2,695
Hello all,
I was able to reduce the price of the CRB-S65-1.1-TI kit for the DR650 from $63.66 to $54.56.
I updated the list above as well, so it's correct.
Regards,
Derek
Old 04-25-2011, 07:56 PM   #29
motolab OP
motolab's Avatar
Oddometer: 2,695
Hello All,
DR650 Pilot Screw 13279-47070, which also fits the KTM and is stainless instead of brass.
Regards,
Derek
Old 05-05-2011, 11:43 AM   #30
motolab OP
motolab's Avatar
Oddometer: 2,695
Hello All,
DR650 Pilot Screw spring 13268-47070, which also fits the KTM LC4 and Aprilia Moto 6.5.
Regards,
Derek
Times are GMT -7.   It's 12:48 AM.
