Old 10-06-2011, 03:53 PM   #46
motolab OP
motolab's Avatar
Oddometer: 2,696
Hello Dean,
The SUZ0111100002 rebuild kit contains all of the correct parts for your '93 DR350SE. I have them in stock at $36.29 ea.
Don't forget to inspect the slide guide. emulsion tube and jet needle.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-08-2011, 01:14 AM   #47
motolab OP
motolab's Avatar
Oddometer: 2,696
I now have in stock:
Suzuki DR650 slide springs.
Added them above as well, so the list is complete.
Regards,
Derek
Old 10-13-2011, 07:17 PM   #48
motolab OP
motolab's Avatar
Oddometer: 2,696
09494-00754 Needle Jet 691 Y-2 for '92-'95 DR650 at $23.55 ea.
Will add it above as well, so the list is complete.
Regards,
Derek
motolab screwed with this post 02-15-2015 at 09:33 PM Reason: lowered price
Old 12-07-2011, 11:04 PM   #49
motolab OP
motolab's Avatar
Oddometer: 2,696
Non-vacuum operated petcocks for DRs
5LP-24500-01-00 Petcock, $19.60 ea.
Use it on '90-'11 Suzuki DR650, '90-'99 DR350SE & '90-'95 DR250SE to replace the stock vacuum operated petcock.
Regards,
Derek
Old 12-12-2011, 08:30 PM   #50
motolab OP
motolab's Avatar
Oddometer: 2,696
Adjustable euro DR650 jet needles now in stock
13383-12D20 Jet Needle 6H11 (adjustable), $17.29 ea., fit European '93-'95 Suzuki DR650. Use on USA models to add adjustability.
13383-32E00 Jet Needle 6F19 (adjustable), $17.29 ea., fit European '96-'11 Suzuki DR650. Use on USA models to add adjustability.
Will add them above as well, so the list is complete.
Regards,
Derek
Old 01-18-2012, 11:05 PM   #51
motolab OP
motolab's Avatar
Oddometer: 2,696
584.31.030.000 Throttle Valve spring, $41.74 ea.
Regards,
Derek
Old 02-10-2012, 07:46 PM   #52
motolab OP
motolab's Avatar
Oddometer: 2,696
UP-123 Breather Filter, $13.29 ea.
Regards,
Derek
Old 04-17-2012, 04:08 PM   #53
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,486
I just took delivery of a pack of parts from Motolab to rebuild my carb & I would like to compliment Derek on the great service
Communication was very prompt with some helpful advice from someone who obviously knows their stuff. The parts were delivered to me (in New Zealand!) in less than a week. Included with the rebuild kit were some more useful notes on servicing the BST40 & all this cost less than ordering the stuff from the local dealer & waiting a month!
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 04-17-2012, 04:16 PM   #54
motolab OP
motolab's Avatar
Oddometer: 2,696
Cheers
Clint
Hello Clint,
Thank you sir for the kind words!
Regards,
Derek
Old 07-24-2012, 01:39 PM   #55
motolab OP
motolab's Avatar
Oddometer: 2,696
Cold start enrichment plunger springs added to stock
584.31.053.000 Spring, 22.5mm, For Starting Piston, $2.69 ea. ($6.43)(Suzuki part number 13417-22010)
Regards,
Derek
Old 03-24-2013, 10:44 AM   #56
motolab OP
motolab's Avatar
Oddometer: 2,696
Extended fuel screws
MIK0111221000 Extended Pilot Screw Set, $12.48 ea., includes screw, spring, washer, and o-ring; fits Aprilia Moto 6.5, '90-'12 Suzuki DR650, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
and
CRZ-SCR-5020M Extended Pilot Screw Set (longer than the above), $19.58 ea., includes screw, spring, washer, and o-ring; fits Aprilia Moto 6.5, '90-'12 Suzuki DR650, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4.
Regards,
Derek
Old 07-10-2013, 10:20 AM   #57
motolab OP
motolab's Avatar
Oddometer: 2,696
Pilot screw washers
13291-29900 Pilot Screw Washer, $1.14 ea., fits '90-'13 Suzuki DR650 and '91-'98 non-USA GSX-R1100. Also fits Aprilia Moto 6.5, Cagiva Canyon 500/600, '03-'04 Husqvarna SM610S, '00 KTM 400SXC, '01 KTM 400 LC4-E, '03 KTM 625SXC (USA only) & '98-'07 KTM 640LC4
Regards,
Derek
Old 09-16-2013, 10:42 AM   #58
zflorin
Oddometer: 2
Hello motolab,
I'm looking after an o-ring, near to throttle valve guide(item 37 on diagram),
you can see it under this link
http://http://www.ktmpartsexpress.co...005%2F02030029
is the o-ring marked with #, near the item 37 on the diagram.
can you help me with a part number?
thanks!
zflorin is offline   Reply With Quote
Old 09-16-2013, 11:46 AM   #59
motolab OP
motolab's Avatar
Oddometer: 2,696
Originally Posted by zflorin View Post
Hello motolab,
thanks!
Hello zflorin,
There is no KTM part number for the slide guide o-ring, but I have them in stock at $2.92 ea.
Regards,
Derek
Old 09-16-2013, 01:18 PM   #60
zflorin
Oddometer: 2
Originally Posted by motolab View Post
Hello zflorin,
There is n slide guide o-ring
Derek
yes, you're right, but this is because on Suzuki diagram it isn't any code for this o-ring.
do you have a Suzuki part number for this o-ring?
thanks!
Times are GMT -7.   It's 05:21 AM.
