Old 12-16-2009, 12:14 PM   #46
Motorcyclist
Drag a Bag!
Motorcyclist's Avatar
Oddometer: 3,384
[quote=Unca Fud]
Originally Posted by IJM
Most engineering is really an art, not a science. People frankly expect more from design than we can deliver given the variabilities of material specs, part configuration, and fatigue inputs. Here we have apparently a thermal component too.
So...............legendary German engineering really translates into legendary German WAG's? Or perhaps legendary German marketing?
Motorcyclist is offline   Reply With Quote
Old 10-03-2010, 04:11 AM   #47
Raineman
Oddometer: 62
I have just joined the elite group with this problem. Mine let go when I stomped on the brake hard (doing a brake test) and the whole disk detached from the flange.
Photos at http://picasaweb.google.com/raineman...eat=directlink
2005 1200GS with 70k km
Not happy
Ken
Raineman is offline   Reply With Quote
Old 10-03-2010, 04:18 AM   #48
touser
canned fruit
Oddometer: 359
Me too, 2005 and 60,000k's
I know the voices arn't real, but they do have good ideas.
touser is offline   Reply With Quote
Old 10-03-2010, 05:14 AM   #49
Raineman
Oddometer: 62
Hey Touser
South coast? In WA?
Any ideas of where to get a replacement part? or at what cost?
I am trolling US websites and have found them at $265 plus postage.
Ken
Old 10-03-2010, 05:41 AM   #50
IJM
Hinderant Backbenderz
IJM's Avatar
Oddometer: 225
Lucky thing you're alright!
Not happy
Ken
That looks like a pretty scary event
IJM is offline   Reply With Quote
Old 10-08-2010, 03:12 PM   #51
Raineman
Oddometer: 62
Yep
I've been having rear brake sponginess problems and had bled the brakes twice and installed new pads. I went for a ride, and when close to home tried pressing the brakes hard. An almighty bang, crunch, etc and an over whelming desire to stop the bike fast as I could hear all the grinding and clanking of metal on metal.
It could have been much worse if I had been going faster than 40 kph.
I am starting to doubt the reliability of R1200's, after being in love with BM's for so many years, what with this being not unusual, brake problems, final drives failures, fuel pump failures, etc.
Old 10-08-2010, 07:48 PM   #52
Unca Fud
nrpetersen
Unca Fud's Avatar
Oddometer: 246
These pictures and a description of what is happening should be filed with NHTSB. Complete and sudden brake failure should be completely intolerable. Has anyone in the US seen/experienced this sort of thing?
Unca Fud is offline   Reply With Quote
Old 10-08-2010, 08:46 PM   #53
marchyman OP
Cam Killer
marchyman's Avatar
Oddometer: 7,534
Lots of folks see cracks. Most (all?) of us find a crack during a tire change or a service and replace the flange at that time. This is only the second time I can recall reading of someone where the brake rotor broke free.
When you find the problem at this stage
It's no big deal to fix. I found that when I was replacing my brake rotor. It is possible that it cracked when I removed the rotor.
The flange is cheaper than an OEM rotor, but then most things are. Here is an after market rotor mounted on the new flange.
I'm still trying to figure out what to do with the old flange and rotor. Wall art? It's too pretty to throw away.
marchyman is offline   Reply With Quote
Old 10-09-2010, 12:28 AM   #54
Raineman
Oddometer: 62
First step:
To get the old flange off.
Safety gear: thick welders gloves, safety specs, fire extinguisher, swear jar.
I went to Bunnings Hardware and bought a propane torch and circlip pliers ($40 and $16)
Although the pliers were the largest ones in the shop, they were too small, as in they could barely open the clip far enough (it is already quite a wide gap at the ends). The pliers wouldn't stay clipped into the holes, so I had to file them down to a thicker part of the pins. I opened the circlip, then slid a flat blade screw driver behind it and gently wiggled it off, holding a thick rag over it to prevent it possibly springing off.
I tried to buy a harmonic balancer puller, but did not see one with the right hole spacing, so went to plan B.
I know some may say that this is sacrilege and others may say "Aussie Ingenuity" but, I used a piece of angle iron, drilled two holes 118mm apart, and used the wheel bolts to attach it to the old flange.
I then got a piece of timber and put it through the axle hole from the brake side and tapped with a heavy hammer as I heated the flange.
After about five minutes of heating and tapping, it came off OK. Damn tight fit.
Note that I feel uncomfortable hitting with any real force, as I imagine the load is being taken on the rear drive bearings somewhere. My young son helped me with the tapping.
See photos
http://picasaweb.google.com/raineman1/R1200GS#
Now I have to wait for the parts to arrive from the states
Ken
Raineman screwed with this post 10-09-2010 at 12:42 AM
Old 11-03-2010, 05:24 AM   #55
Raineman
Oddometer: 62
I have reported this issue to the WA BMW distributor and am awaiting advice as to the procedure to consider a recall or advisory.
Their first response was 'it's probably a fault on USA models only (I live in Western Australia). Then 'we haven't ever replaced one before"
I would appreciate those of you who have had this issue please supply the following details which I will pass to BMW to show that this is not a one-off problem, and appears to be manifesting itself with 60 to 70,000km:
Bike year
Milage
Location (country/state)
Fault (cracks, disintegration, etc.)
Contact detail (email should do)
thanks
Ken
Old 11-03-2010, 05:46 AM   #56
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,400
Last FD service, I had one crack. I just services the FD for an upcoming trip and discovered two more lobes had cracks. Time for a new one. Rotor is about shot too at 60K. Is there a source for these parts without letting the local dealer get in my pants too deep?
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 11-03-2010, 05:48 AM   #57
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
You can get rotors ate www.beemerboneyard.com but the dealer is the only source for the flange. You can get discounts at a few dealers like Max and Chicago BMW.
Jim
JimVonBaden is online now   Reply With Quote
Old 11-03-2010, 06:13 AM   #58
Desert Skies
One brick shy...
Oddometer: 2,400
Thanks Jim. Looks like the rotor is about 165, I'll look into the Max and Chicago.
Old 11-03-2010, 01:55 PM   #59
RogerA
Continually Confused
RogerA's Avatar
Oddometer: 73
The rotor of my 2007 GSA with 50,000 miles
Roger
2011 BMW R1200GS Adventure / 2009 Triumph Thruxton
Bikes I never should have sold: Honda 90 / Honda CB 250 / 1961 Triumph T110 / 1971 Triumph Bonneville / 2000 Kawasaki ZRX1100 / 2002 Kawasaki ZRX1200 / 2005 Kawasaki ZX636 / 2005 Kawasaki ZX12R / 2007 R1200GSA
RogerA is offline   Reply With Quote
Old 11-04-2010, 09:26 AM   #60
AngryScot
AngryScot's Avatar
Oddometer: 18,322
a few dealers in the vendors section also sell rotors, galfer etc and give an adv inmate discount
renazco for example
I finally got my extension for removing the rear rotor, I got it from wiha and then dremel'd it a bit to make it a tad smoother so it doesn't hit the rear casing.
⊕R1200GS⊕ For sale soon, snap it up and contact me.
⊕Zuma 125⊕For sale soon, snap it up and contact me.
Save $5 on Smugmug "so9RUAXlMm0bE"
AngryScot is offline   Reply With Quote
Times are GMT -7.   It's 10:14 PM.
