12-19-2009, 08:03 PM
#31 |
In a parallel world
Oddometer: 800
It ain't the legs, it's the mind
Not a bad idea (the crashbars and spraypaint), though I'm doing fine with a 30.5" inseam (just to be annoying
12-29-2009, 11:01 AM
#32 |
Oddometer: 11
One question...
Does an 800 lie almost flat on its side when dropped?
12-29-2009, 01:19 PM
#33 | |
Dirt, Sweat & Gears
Oddometer: 442
09 F800GS ABS Yellow/Black When you look like a rude, crude, scum sucking cretin, people tend not to ask you stupid questions! |
12-29-2009, 05:06 PM
#34 | |
Greg
Oddometer: 1,552
CASCADE EXPEDITIONS WABDR Tours & More. PSSOR - Dualsport Training & Adventure Camps. |
01-01-2010, 06:08 AM
#35 |
Oddometer: 444
confidence more important than inseam
Years (OK, decades) ago I saw a short kid racing an open MX and his father had to hold the bike up at the starting line because there was no way he was going to touch on either side. Damn, he was fast and won the moto going away.
However, anyone that recommends a high CG/seat height bike to any novice is doing them a great disservice. If someone is scared to death everytime they stop, because they can't easily touch, they will find a reason NOT to ride. confidence is king. |
01-01-2010, 02:56 PM
#36 | |
on the mend
Oddometer: 976
There is a guy that does Dakar who needs a running start to mount his ride - my hero
Don't take this as expert - I'm anything but. I do ride both a 800gs and a 690e. They are each a bit high for my 30" britches. Stops find me on my right ass cheek with left foot flat on the ground and right foot on the peg. My experience is that bike weight and center of gravity are more important in control and confidence than height. The 690e is taller than the 800gs but I'm happy to billy goat up stuff on the 690e I'd pass by on the 800gs. Most important in my own mind is that the bike responds quickly to input. I find that I can muscle the taller 690e around much more easily. The trade off is tarmac. So I choose based on the day. I'd say buy the 800gs - you'll be fine with the 30" I put 10k on it this year and it went from 'huge' to 'glove.' Quote:
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding. All posted pics < 6/30/12 deleted courtesy of Apple
01-01-2010, 03:38 PM
#37 |
Oddometer: 2
5' 4" 29" inseam, low seat, thick soled boots, no problem. Just be mindful to slide to the right to plant your foot flat on the ground with the left still on the peg when you stop. You will get used to it. Fit AdvSpec crash bars, Barkbusters and Jessie bags and you are good to go. You will plant your foot in a pot hole sometime or get caught in slow traffic, then you will suffer a tip over. Dont worry, the slight damage will be minimal at best if you follow my advice above. Will provide photos if you require.
01-01-2010, 04:11 PM
#38 | ||
Oddometer: 11
01-02-2010, 11:29 AM
#39 | |
Smooth IS Fast
Oddometer: 1,436
Just curious cause I leave my right on the peg where I have control of the rear brake and just hold the clutch in. Lights don't last that long that I can't hold a clutch lever for 30 or 45 seconds! |
01-03-2010, 12:44 PM
#40 |
SuperSportTourer
Oddometer: 1,004
Saki-He said 690---as in he is comparion his 800GS to a KTM 690, not BMW 650.
Yes the BMW 650 willhave a lower centre of gravity, since it is basically a lower version of the 800, with shorter suspension travel and less ground clearance.
XR200R KTM 950SM CBR Fireblade-GTU Endurance racebike 1996 YZF 600-Lost Era racebike 1999 R6-Rookie Challenge racebike |
01-03-2010, 03:11 PM
#41 | |
on the mend
Oddometer: 976
Biggest difference between 690e and 800gs will be weight alone. Dry 690e is ~ 310 lbs where 800gs is ~ 400lbs. Makes a huge difference and when riding off road, I'm more capable/confident on the 690e even though it's a taller bike than the 800gs. I guess my point is that I'm less concerned with bike height than some other factors. My personal experience is that height can be managed. Hell yes I'd like to have 33" to the floor but that ain't happening. I guess the best advice is to spend as much time as you can comparing the 650/800 on the floor or much more preferably on a test ride. Second to that I'd say get the 800 if you have confidence in you physical skills. This bike is very sweet.
01-03-2010, 03:21 PM
#42 |
Reseda, CA
Oddometer: 3,489
Changed tire/rim sizes and now my feet dangle like a little kid sitting on Dad's big bike. Yikes!
01-04-2010, 09:22 AM
#43 |
Oddometer: 11
Thanks for the info guys!
01-04-2010, 11:42 AM
#44 |
travelling beardo
Oddometer: 7,218
I'm 5'6" with 30" inseam. Right now I'm riding my F8 with the lowered seat, soft on the rear stock suspension and I lowered the front about an inch. The bike is a big upgrade for me, so I went low on the suspension to keep my confidence up while I get used to the thing. I can tip-toe the bike on both feet at a stop, but I usually flat foot one side instead and it's fine. So far, the height is not nearly as much of an issue as I thought it would be for comfort and handling, so I'm thinking I'll tighten up the back and put the forks back to normal in about a month.
hope that was helpful. If you want the bike, you'll find ways to make it work for you.
"She was a real woman. Nothing but guts. And ass." -Bukowski EX500 Ratbike Rebuild: http://advrider.com/forums/showthrea...1#post15001161 Livin' on the road, my friend, was gonna keep you free and clean... |
02-12-2010, 09:40 AM
#45 |
Danger: Keep Back 500 Ft.
Oddometer: 994
I was NOT going to shorten suspension travel, so I had an inch added to the soles of a pair of boots dedicated to use on the F800GS.
Fred |
