Old 11-30-2009, 11:22 AM   #1
CarDOC OP
CarDOC's Avatar
Oddometer: 50
'99 F 650 FUNDURO Carb problem
I have replaced needle and seats on both carbs and reassemble, Only to have the bike Die and won't re-start .Need HELP
GRECKO
CarDOC is offline   Reply With Quote
Old 11-30-2009, 12:55 PM   #2
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,084
When it dies, is it flooding or what? Can you keep it running at all? If it was runnng before, than maybe you have a float sticking or something. Also maybe there is a vaccuum leak?
You can get every answer to every technical question you have by going to the Chaingang web site: http://www.f650.com/
Be warned though, you need to read all you can and do your research in the tech sections, as some guys do not want to deal with problems that have been discussed 50 times before.
I will help you as much as I can but need more specifics on how the bike acts and how it dies.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 11-30-2009, 01:21 PM   #3
JPSpen
At Large
JPSpen's Avatar
Oddometer: 1,185
Turn the gas on....
I know....
open the bowl drains and let gas get into the system.
You're either flooding or not getting gas. Pull a plug and see if it's wet.
If everything else is ok then it should run...Chokes working ? Valves been set recently ? Tight valves will make an otherwise ok bike hard to start...You didn't say WHY you changed the needles and seats.
What else besides the carbs did you do ?
Also be sure you're getting spark...
John
'03 BMW R1200CLC "Flipper"(Tis but a scratch!)
'01 BMW R1100RT "Lucky"
'91 BMW R100GS "itsnotamoneypit"
I like the wind in my face and Boobies too !!..
JPSpen is offline   Reply With Quote
Old 11-30-2009, 01:37 PM   #4
CarDOC OP
CarDOC's Avatar
Oddometer: 50
F 650 Funduro carb issues
OK original problem was carbs were leaking
Replaced needle and seats.
After doing that job the bike starts but only warms up then dies and wont re start.
GRECKO
Old 11-30-2009, 02:56 PM   #5
Mista Vern
Mista Vern's Avatar
Oddometer: 16,084
Either gas is flowing too slowly to your carbs, or the needles are hanging up, you are out of gas, or the float levels are WAY off. I'd go back and take the bowls off and make sure everything is back in there right. If the bike worked before you need to re-trace your steps.
Emily Bronte
Old 11-30-2009, 03:56 PM   #6
DADODIRT
DADODIRT's Avatar
Oddometer: 3,435
Hmmmm.
I know this might sound far off, but have you considered the voltage recitfier?
It gives the same symptoms as it would if you are out of gas.
The bike will start, then stall as if out of gas.
PM me if you are still having issues. I have some parts and a BMW shop manual for the early F650's.
I find your lack of faith in the force disturbing.
DADODIRT is offline   Reply With Quote
Old 11-30-2009, 04:17 PM   #7
CarDOC OP
CarDOC's Avatar
Oddometer: 50
99 F650 Fun duro
Anyone have info on float level setup and which carb L o rR get the float holder with the JET?
GRECKO
Old 11-30-2009, 05:19 PM   #8
Mista Vern
Mista Vern's Avatar
Oddometer: 16,084
You will find all you need on F650.com, but you gotta put some research time in.
Emily Bronte
Old 11-30-2009, 07:26 PM   #9
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,007
I just did float needle assemblies in my 99. IIRC, the float hanger with the little orifice (jet) goes in the left carb. Remember which is which while you are working on them upside down. You can double check which hanger is which on the Max BMW fiche here http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?model=F650&prod=091996-121999##
It will be the carb with the enrichener/choke valve in it. And that should be the left one.
If you didn't set the float levels right, it won't run. If the little o-rings on the float hanger brackets leak, it won't run right. You can't get them separately from BMW. But, I sent a bunch of my leftovers out of a batch of 25 I had bought to Prof - the founder of the Chain Gang at f650.com. If you aren't a member, join. Then ask Prof if he still has some of the little o-rings. He usually collects a small nominal fee for most stuff like that for the charities the Chain Gang supports.
Setting the float levels is part black art. The trick is with the carbs in your hands (I know it will be a bear pulling them out again). To set the levels so that the float bodies are parallel with the flange on the carb body where the bowls go. You want the needle to just come to rest on the seat without the weight of the floats compressing the little spring plunger inside the needle at all. Basically holding the carbs on their side and watch the needles very closely to achieve that setting as you tilt them gently side to side to move the floats gently.
Also, if you cleaned the carbs thoroughly, did you reset the idle mix screws to a basic startup position? Off the top of my head I want to say 1 1/2 to 2 turns out should get you a stable idle to start with if all else is right. But float levels control just about every circuit in the carb as far as mixture and operation goes.
Good luck. It can be done. And sometimes it can be tedious.
Edit: Oh here is a bonehead move I made putting the carbs back together because I was still in the mindset from working on my airhead carbs.... In one of my F650 carbs I put the little nylon spring perch thingy under the clip on the slide needle and did the other one correctly with the little nylon spring perch on top of the clip. When I started the bike up and revved the throttle the first time or two, the slide needle assembled incorrectly climbed right up into the slide spring and stayed up effectively dumping gas for near WOT through that carb and flooding the motor enough that it choked down and wouldn't even restart. Check those first even if you are sure you did it right.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 screwed with this post 11-30-2009 at 07:32 PM
mark1305 is offline   Reply With Quote
Old 11-30-2009, 09:04 PM   #10
Mtncrzr
Just Kidding, not really
Mtncrzr's Avatar
Oddometer: 1,213
Look for leaks in the intake boots between the carbs and cylinder.
It doesn't die when you turn the handlebars does it?
I'll be the one on the horizontal silver 640 KTM Adventure.
Mtncrzr is offline   Reply With Quote
Old 12-01-2009, 08:28 AM   #11
CarDOC OP
CarDOC's Avatar
Oddometer: 50
Funduro
Ok I will give another whirl
THANKS a Sh TON
GRECKO
Times are GMT -7.   It's 06:11 AM.
