Old 12-01-2009, 03:21 PM   #1
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 3,995
Fuel resistant glue
I need to repair obsolete, defunct carburetor floats that are the brass type, and have corrosion right through them in several places. (I know, I've never seen that before either) and so far I know of contact cement and JB weld are rated for gasoline service... any others? any preference one over the other and why? Thanks!
2007 Tiger 1050
2005 Royal Star Tour DeLuxe
1973 Yamaha TX750
1974 Norton 850 Commando Roadster
Old 12-01-2009, 04:41 PM   #2
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 912
You will have to carefull not to make the floats too heavy (JB weld). I have repaired brass floats before by soldering them, but this was very difficult and also added weight to the float. If you can another float that you can adapt you may be farther ahead.
__________________________________________
"There's a fine line between a skinning and a shearing"
RecycledRS is offline   Reply With Quote
Old 12-01-2009, 04:51 PM   #3
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 3,995
that's my concern
of course is the weight... and long term fuel resistance. I've solder repaired them before as well, when they had a chafe through from contact or a crack. This corrosion is the craziest shit I've ever seen on brass. The aluminum bodies and bowls are PERFECTLY corrosion free... possible galvanic thing?
2007 Tiger 1050
1973 Yamaha TX750
concours screwed with this post 12-01-2009 at 05:49 PM
Old 12-01-2009, 04:54 PM   #4
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,395
Very thin brush-on epoxy works.
The type they use for making epoxy glass fibre, for repairing Airhead BMW fairings etc.
I have used it on old Harley cork floats that became "waterlogged" with petrol and on brass floats in ancient Amal carbs.
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Old 12-01-2009, 05:26 PM   #5
GreaseMonkey
Rhymes w/piecejunkie
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 4,765
Go to a stained glass supply store. They have some copper foil tape you can use to cover the holes, then solder the edges.
In regards to soldering, use a very fine solder and if possible a 40 watt iron with the smallest tip for it you can find. Wipe the seam with a Q tip and you can keep the weight down.
GreaseMonkey is offline   Reply With Quote
Old 12-02-2009, 04:39 AM   #6
cagiva549
whats a cagiva
Oddometer: 2,454
This will be the one of the most important repairs you will ever undertake , not done right the bike will never run . done correctly you will never have to deal with it again . I would look in to having somebody build a new float assembly . Try to find floats similar in size then solder them to your float arms . Some experiminting my have to be done to get the correct float level . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 12-02-2009, 09:18 AM   #7
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 3,995
Thanks! As a professional mechanic, I undestand the importance here, normally I wouldn't waste my time and effort trying to repair them. FLING! over the shoulder they'd go... but.. the bike is not real valuable, I want to see if the engine is reasonably sound, before making any significant investment in parts. I remember Dad patching up lawnmower/minibike stuff with contact cement back when we had little money for parts. Just trying to get input from all the McGyver's here... what a GREAT resource for sharing!!
2007 Tiger 1050
1973 Yamaha TX750
Old 12-02-2009, 12:12 PM   #8
Sonex522
zipper suited sun god
Sonex522's Avatar
Oddometer: 1,348
I've used fuel tank repair epoxy to reattach supply and return lines that rusted off of a fuel pump. Still holding fine after a year.
Sonex522 is offline   Reply With Quote
Old 12-02-2009, 12:37 PM   #9
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 3,995
I remember now
That the LocTite stuff that comes in a two part flat ribbon? I remember using that on my old shitbox cars, lol it HELD!!
2007 Tiger 1050
1973 Yamaha TX750
Old 12-02-2009, 04:01 PM   #10
cagiva549
whats a cagiva
Oddometer: 2,454
Just leave the carb off and run the engine with starting fluid and see what it sounds like 30 seconds or so might give somewhat an idea weather to continue on with more serious repairs . I guess if its a kick start that could be a pain in the ass or foot . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
Old 12-02-2009, 04:04 PM   #11
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 29,130
Starting fluid is a bad idea. It will auto ignite at about 4:1 compression so it's going to be making all sorts of racket. Use carb cleaner that has toluene and other high octane components.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 12-02-2009, 06:09 PM   #12
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 3,995
Yeah...
Pretty much just use it to wash spark plugs on misbehaving 2-strokes, lol
2007 Tiger 1050
1973 Yamaha TX750
Old 12-05-2009, 10:51 PM   #13
greenthumb
b00b
Oddometer: 172
http://www.eclecticproducts.com/sealall.htm
Seal-All Uses
• Distributor caps, interior panels, radiators, gaskets, transmission, carburetor floats, body and trunk leaks, battery cables and terminals, generators, tools, and much more.
greenthumb is offline   Reply With Quote
Old 12-06-2009, 09:35 AM   #14
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 3,995
Originally Posted by greenthumb
COOL!! THIN consistancy... I like it!!
2007 Tiger 1050
1973 Yamaha TX750
Old 12-06-2009, 04:46 PM   #15
motorcyclefanatic
The name says it all
motorcyclefanatic's Avatar
Oddometer: 680
+ 1 on the Seal-All
I've been using it for fuel related repairs for years. It works.
http://www.johnnystoybox.com
motorcyclefanatic is offline   Reply With Quote
Times are GMT -7.   It's 09:00 AM.
