Go Back   ADVrider > Riding > Regional forums > West – California, the desert southwest and whatever is left
Old 07-15-2010, 11:53 AM   #751
Becktastic
Bonzai Becky
Becktastic's Avatar
Oddometer: 1,153
Hey guys and gals! I'm headed your way from Eugene, Oregon and desperately in need of a good shop (or garage and guidance) to fix a carb issue on my bike. I'm not sure if it's just an o-ring or the float needle or what but I am pretty sure fuel is getting into my oil and I should probably fix it sooner rather than later. I figured I'd rather be stuck there if I have to wait for parts and such, so I'm going to change the oil and make a run for it, but I'd like to know who best to order from and/or have the work done by if it's more than I can handle. It's a klx400r which is exactly a drz400e if that matters. Thanks in advance!
Becktastic is offline   Reply With Quote
Old 07-15-2010, 12:41 PM   #752
rockydog
just a guy
rockydog's Avatar
Oddometer: 858
Torch and welder/shop needed
I'm in Emeryville with an 89 transalp, in need of a garage/shop with torch, vise and welder to straighten out a Givi engine guard. Thanks to a drunk pedestrian I bounced off the corner of the rear bumper of the car in front of me as we both braked hard and swerved to keep from hitting him. No damage to me or the pedestrian, the car's bumper is bent, broken taillight lens and her car is smeared with Transalp paint. The bike's cowling and side panel are scarred and cracked but repaired already with epoxy, etc. Bike runs fine, tracks fine, front fender has a slight paint scrape..that's how close it was. lucky puppy as I wasn't touched and didn't even fall over... just a very quick stop. very fortunate
The Givis took the impact and have a 90 degree bend and a mounting flange is twisted and bent. Basically have to fit the guard to the bike's mounting points and probably cut the bend out and weld an insert..not a huge job as the bend is in the rear single tube.
I can bring the guard and bike to your location, please contact at; backtalk8124@sbcglobal.net or 580-554-6227. I'm working/visiting from Oklahoma so all help is very appreciated, thanks in advance.
Stephen
footnote: was returning from Hilltop Sears after buying 2 metric box wrenches to complete my toolkit for the bike. I used both wrenches to pull parts off the bike
Two lane roads and two bit towns
Rockydog woofs the Isles, British Isles
rockydog screwed with this post 07-15-2010 at 12:55 PM
rockydog is online now   Reply With Quote
Old 07-15-2010, 08:37 PM   #753
SelkieRider
SelkieRider's Avatar
Oddometer: 61
Originally Posted by M N B
The 800 does ok at slower speeds, but it's a big bike and a bit top heavy, especially if you load it up with camping gear, etc. Not to mention that twitch throttle off idle. So momentum is your friend. You don't necessary have to wick it up, but get a little extra speed going and it'll plow right through stuff.
How are you likin the 800? I love mine. Such a fun bike. A hoot in the twisty goats and not bad off road for a big bike.
I've yet to ride up in Mendo. I'd love to head up there for a weekend and ride some of the easier stuff sometime.
D00d. The bike is super capable, even loaded up with camp gear. It's a little top heavy, but it isn't bad. It'll get you through stuff you never imagined you'd have to get through. Super fun! You should take it out to the desert some time and wick it up a bit.
Sing like no one's listening, love like you've never been hurt, dance like nobody's watching, and live like it's heaven on earth. ~Mark Twain
SelkieRider is offline   Reply With Quote
Old 07-15-2010, 09:52 PM   #754
bykpimp
Live and let ride
bykpimp's Avatar
Oddometer: 1,410
It's not an o-ring. think float bowel level or needlevalve and seat assembly. I can help you if you find yourself in the Santa Cruz area. Tell me why you think there is an overage of petrol in your oil please. check that your aircleaner isn't overly dirty (less air equals more fuel) do you know your current jetting spec?? I noticed you have a slippy or maybe full system on your bike.
" I can't fix your motorcycle over the phone or internet" Spanky
bykpimp screwed with this post 07-15-2010 at 10:06 PM
bykpimp is offline   Reply With Quote
Old 07-16-2010, 10:25 AM   #755
Becktastic
Bonzai Becky
Becktastic's Avatar
Oddometer: 1,153
The oil level seemed to have risen and thinned out. Someone suggested the fuel thing and I thought it smelled a bit like gas, but I might just be paranoid. It was stalling, hard starting and dripping fuel from the drainage tubes, but seems okay now. Maybe some grit was just interrupting the float needle and worked its way out? I dunno. Maybe I'll just try to ride it home.. You'll get a call if I break down near Santa Cruz :P
Old 07-16-2010, 10:33 AM   #756
MotoMind
Oddometer: 1,272
Probably just caught a cold. Next time it acts up give the carb a few good whacks on the side to loosen up a sticky float, and close the fuel tap when stopped.
MotoMind is offline   Reply With Quote
Old 07-16-2010, 01:10 PM   #757
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
but seems okay now.
watch the mpg, thats an ez to see indicator
MookieBlaylock is offline   Reply With Quote
Old 07-16-2010, 01:17 PM   #758
mcma111
mcma111's Avatar
Oddometer: 12,560
Gas
If your bike has a float bowl plug or drain, turn petcock off, remove bowl plug/open drain and turn on the petcock. If there is something in the float seat this may wash it away and allow the float to seal and stop the overflow. Change the oil if it smells of gas. If you still have problems when you get to San Francisco ping me.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-16-2010, 03:45 PM   #759
WoodsChick
WoodsChick's Avatar
Oddometer: 1,657
I thought Penny Pines was off 108? That's a long way from Stonyford...
There's a Penny Pines in almost every forest. They are plantations that cover up previously burned or logged areas. People donate money to plant a tree and then get to have a plaque with their name on it, or they could put "In memory of" or whatever on it. It's part of the forest service's reforestation plan
WoodsChick
"Coffee first..."
______________________________
AMA, D36, BRC, CORVA, WMA, USA-ALL
WoodsChick is offline   Reply With Quote
Old 07-16-2010, 03:47 PM   #760
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,209
Interesting. Thanks for the info!
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Old 07-16-2010, 04:36 PM   #761
mcma111
mcma111's Avatar
Oddometer: 12,560
Penny Pines
Penny Pines is an improved camp ground in Mendocino NF about 7 miles above CC Camp.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-16-2010, 10:20 PM   #762
M N B
M N B's Avatar
Oddometer: 1,209
After spending a small fortune to fix it, I just got my Husky TE610 back and I've got one good (maybe two) rides left on the tires on the 800GS.
Anyone riding this weekend? Preferably someplace not incredibly hot?
2009 BMW F800GS
Old 07-19-2010, 01:47 AM   #763
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,102
Paul and Todd's Weekend Ride
This weekend's ride had it all
Amazing Views
Great Camping right on a river
Knife Throwing
Heat
Snow
Rain
Great Dirt and Street Riding
Thrills
Spills (Todd)
9k feet climb up cow mtn
Totally Submerged bikes under water ... Yup Todd again
Broken Bikes
here are the pics.. I will fill in the typing part later when it's not 1:47am
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 07-19-2010, 04:18 AM   #764
WoodsChick
WoodsChick's Avatar
Oddometer: 1,657
Amazing Views
Knife Throwing
Heat
Snow
Rain
Thrills
Spills (Todd)
Broken Bikes
Nice photos! Looks like a realy nice high-elevation place to ride
WoodsChick
"Coffee first..."
Old 07-19-2010, 06:23 AM   #765
bykpimp
Live and let ride
bykpimp's Avatar
Oddometer: 1,410
Ditto on the nice pics!!! that's a record number of pics per trip frpm you, good job!!!! I loved everything on that list except for that dreaded word "Heat" me no likey that word. Even those am campsite pics looked as if the temp was already over a balmy 70 More info on the oil leaky pic. mixing oil & water???
Times are GMT -7.   It's 12:52 PM.
