Old 09-15-2011, 01:44 PM   #61
Schtum
Free Genie
Schtum's Avatar
Oddometer: 1,972
Originally Posted by macrae85 View Post
Same with ABS.An ABS system lets off the brakes when the 'ring' stops moving,doesnt
matter what size of rim that's on there.
Sorry Mac but I think you'll find this is incorrect. The computer takes into account the difference in rotation speeds between the front and rear wheels and uses this information to make decisions about ABS operation. So if you fit different sized wheels you have to re-program the ECU to take account of this, otherwise you bugger up the ABS operation.
Schtum is offline   Reply With Quote
Old 09-15-2011, 04:18 PM   #62
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
Not sure where I read it... but one of the BMW techs around here said that when you first start moving, it is sort of an ABS calibration period. At this time, it figures the difference in wheel speeds for different size wheels. Also, several people have done wheel size conversions without reprogramming anything and did not have any adverse effects.
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 09-15-2011, 04:36 PM   #63
Schtum
Free Genie
Schtum's Avatar
Oddometer: 1,972
If that's correct then that's great and it might be that's why it takes a couple of wheel revolutions before the Brake Failure light extinguishes each time you fire up the bike and ride off. However, I think it's as well to know that and the fact that the ABS begins to take effect long before the wheels lock up.
Old 09-15-2011, 08:29 PM   #64
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
true, it does measure a difference in wheel speeds. This is why the ABS does not work if one sensor is missing or broken..
Old 09-18-2011, 12:45 AM   #65
Steffo OP
Steffo's Avatar
Oddometer: 211
On the ABS..
What I did was to order a new ABS rotor, for 17" front wheel, with the new wheel and it works flawlessly.
I have only one regret with this new wheel. I should have done it two years ago.
2009 BMW F800GS.
Steffo is offline   Reply With Quote
Old 09-26-2011, 12:53 AM   #66
nutter_on_the_bus
Who? Me?
nutter_on_the_bus's Avatar
Oddometer: 8
Question ABS Ring
Steffo
Where did you get the new ABS ring from? With the original one the ABS switches off after hitting 30.
We recognise that life and living are activities with a danger of personal injury or death.
Participants in these activities should be aware of and accept these risks and be responsible for their own actions.
nutter_on_the_bus is offline   Reply With Quote
Old 10-24-2011, 12:23 AM   #67
nutter_on_the_bus
Who? Me?
Oddometer: 8
Just for completeness
as search engines often come up with unfinished queries
I have come across a Wunderlich part for the old F650GS single, http://www.wunderlichamerica.com/mot...e/8160576.html which is the ABS ring for their 17" conversion for the single,and as this has the same PCD it should solve the problem.
Tried this and it works.
Old 10-02-2012, 12:21 AM   #68
Hamish71
Hamish71's Avatar
Oddometer: 408
So, apologies if reviving an old thread is a crime but I have read many many threads, on many forums trying to resolve this issue.
It would appear, you CAN, fit a 17 inch wheel to the front, as long as you use the wunderlich part for the abs ring. Correct?
As an alternative, has anyone made the F800R front wheel fit the f800gs yet?
Hamish71 is offline   Reply With Quote
Old 11-08-2012, 09:20 PM   #69
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 811
My winter project
get out and live
sailer is offline   Reply With Quote
Old 05-27-2013, 03:30 PM   #70
tazakos
F800gs black&yellow
tazakos's Avatar
Oddometer: 8
did u do it?
tazakos is offline   Reply With Quote
Old 05-28-2013, 08:46 AM   #71
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Originally Posted by tazakos View Post
did u do it?
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 06-11-2013, 12:45 PM   #72
tazakos
F800gs black&yellow
tazakos's Avatar
Oddometer: 8
wow, a beast! where is the front system from?
nice work man
Old 06-11-2013, 01:49 PM   #73
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
nice work man
it is a WP ktm front end with a ktm SM wheel
Ben
My Photo's
Old 06-16-2013, 03:21 PM   #74
tazakos
F800gs black&yellow
tazakos's Avatar
Oddometer: 8
sorry for repeating the question, but which KTMs front end was that? do you still have ABS?
thanks a lot
Old 11-29-2013, 01:50 AM   #75
Baitfish
Baitfish's Avatar
Oddometer: 24
Don't knock it 'til you try it !
I decided to see if I could have 2 bikes in 1.
I got sick of changing between road and dirt tyres depending on who I was riding with, so the obvious solution was 2 sets of wheels with tyres and brakes ready for quick swaps.
Even better, how about tubeless 17" super sticky road rubber to really mess with the sports bikes .
For playing in the dirt it looks like this -
And here's what it looks like with a 120/70-17 on a 3.5" front and 180/55-17 on a 5.5" rear ready for the street -
Uses custom lasercut ABS rings to keep the speedo correct and the ABS happy.
Changeover is pretty quick if I don't remove the pannier racks, bash plate toolbox, etc. Simply pull axles, swap wheels, drop rear preload, add 1/2 turn rear damping, add 4 clicks front compression and 4 clicks front rebound damping.
Turns like a sports bike. Sports bike wheels are light too.
Probably need a lower front guard to complete the look but that's just another time adder when changing over.
I doubt this will be one of a kind for long, I already have 3 mates with F8s (all serious dirt riders) who want me to do a set of 'tards for them too.
Baitfish is offline   Reply With Quote
Times are GMT -7.   It's 11:21 PM.
