Old 12-03-2009, 06:41 AM   #1
DeutschMark OP
Full Tilt Boogie
DeutschMark's Avatar
Oddometer: 336
Lightening Airhead Lifters
Has anybody lightened airhead lifters with any success? The old Dr. Curve article mentioned elongating the oval hole on the lifter.
If anyone has done this, how much weight is safe to remove?
Thanks.
89 BMW R100RS
97 Suzuki DR440
And away we go!
DeutschMark is offline   Reply With Quote
Old 12-03-2009, 08:57 AM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,964
every little bit helps, I guess.
No idea.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 12-03-2009, 10:48 AM   #3
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,234
Never thought of it. I wonder about using titanium? Would there be a metalurgical problem between them and the cam?
Old 12-03-2009, 04:18 PM   #4
skrub
Oddometer: 258
I once aponatime owned one of the Butler&Smith short rod factory race engines. It did not have the utra trick lifters. I have heard thay where titanium and had to be welded in a vacuum chamber. Some one once made a lifter with a ti button on the top to prevent the push rod from pushing through because of the high spring rates used on the hugh cams. I had an idea to use a R65 lifter its a cup the push rod rides in the bottom. Then the side can be drilled or slotted with no fear of damage. The push rods then need to be longer, Jegs sells a kit ala cut to fit for a hemi eng.
skrub is offline   Reply With Quote
Old 12-12-2009, 08:43 PM   #5
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,458
Seems like you would only lose a couple of grams....pass on breakfast and take a good dump and you'll likely lose more.......
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 12-12-2009, 08:51 PM   #6
BrianK
F'in' half ass lookie boy
BrianK's Avatar
Oddometer: 858
Yeah, but that's not reciprocating weight.... at least, I HOPE NOT!
BrianK is offline   Reply With Quote
Old 12-12-2009, 09:00 PM   #7
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,458
ABC# 1992
Old 12-12-2009, 10:32 PM   #8
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
I have built a lot of airhead race motors in the past 25 years and this is an area I would not tuch on a street bike. If you ever rev the motor you will crack a lifter and on the street you will never notice the added performance. If your looking for cheap reliable horse power in a Boxer you can do 2 things.
up the compression and port match the heads.
Old 12-12-2009, 11:15 PM   #9
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
Siebenrock have light weight cam followers, Valves and pushrods. Not cheap though.
Rob Farmer is offline   Reply With Quote
Old 12-13-2009, 05:22 AM   #10
Beemerboff
Oddometer: 2,334
The real problem is that the lifters dont get a straight push at the rods , so for a top race engine you want to be welding up the holes and re machining them so that they do- said to be worth 500 revs by those that should know.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 12-13-2009, 07:08 AM   #11
DeutschMark OP
Full Tilt Boogie
Oddometer: 336
I've already got the compression part covered. I've got a set of late 9.5 pistons and I'm going to dual plug, so I'll bump it a little more. I also have a Scheffer/Edelweiss asmmetrical cam ordered and already have some Mikuni carbs. This should be a peppy airhead! When the heads are done I'll have the machinist use 44mm intake valves.
As far as the port matching goes, I pulled the heads and planned to do a little smoothing and casting flash removal, but there doesn't seem like there is much to remove. The intakes are clean, with only a little casting flash. There is a small hump on the bottom of both intake ports that could be smoothed over and a booger size piece of flash on the short radius of one intake. Is this what you are referring to?
On the exhaust side, there is a small step outward all of the way around the area where the head transitions to the spigot. Are there any gains to be had by removing this?
89 BMW R100RS
97 Suzuki DR440
And away we go!
Old 12-13-2009, 07:48 AM   #12
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
The ridge meets flush with the exhaust pipe. Any smoothing you do should be done with a small length of exhaust tubing in place to match up to first.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 12-13-2009, 10:25 AM   #13
Boxer Metal
Mad Scientist
Oddometer: 3,521
What year and size motor is this? What are the heads off of?
Old 12-13-2009, 10:36 AM   #14
DeutschMark OP
Full Tilt Boogie
Oddometer: 336
1989 1000cc with original heads.
89 BMW R100RS
97 Suzuki DR440
And away we go!
Times are GMT -7.   It's 02:40 AM.
