Old 12-04-2009, 02:44 PM   #1
Motorman OP
Motorman's Avatar
Oddometer: 496
Light Brackets For The Airhead GS???
Howdy,
I plan on installing white LED lights on my R100GSPD with the idea of being seen. From what I have been able to see (pun intended) LED technology has not yet perfected the ability to punch the light out there so the rider can see longer distances. Also, LED's have the advantage of putting out some lumens without challenging our low wattage alternators.
My choice would be to mount LED lights pendent-style from the engine guards.
This would provide the "triangle of light" that can be so effective in catching the attention of some of the brain dead drivers that we deal with on a daily basis.
Is anyone aware of any brackets that could be used and attached to the engine guards????
If this plan works well, I will post the results with pics.
Thanks in advance for your help.
Motorman
Motorman is offline   Reply With Quote
Old 12-04-2009, 05:45 PM   #2
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Do a Google search and go to the PIAA site. They make (or sell) their own brackets in various diameters. Not that cheap though.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 12-04-2009, 05:50 PM   #3
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
Check out whitehorsepress...oh, here it is
http://www.whitehorsepress.com/produ...oducts_id=6030
Old 12-04-2009, 07:36 PM   #4
bereahorn
Oddometer: 1,070
BMW clamps
BMW makes some nice clamps that fit perfectly on the engine guards. Here are the part numbers:
46631455461 is half the clamp
46631455462 is the other half
46632315308 is the rubber strap that fits between the clamp and the crash bar
These are very sturdy and will handle any lights I'm aware of.
bereahorn is offline   Reply With Quote
Old 12-04-2009, 08:43 PM   #5
Scott Davis
Which way did they go?
Scott Davis's Avatar
Oddometer: 657
LED Lights H3
I have a set of Hella 500's mounted on my eng guards and just ordered these LED's to try out: http://www.ledlight.com/h3-25-smd-12...led-light.aspx
I love the (55W) Hella's but can't leave them on without draining the battery, so I am looking for alt solutions. I just found the DRL LED H3 Lights online. I will send photos once I get them installed.
SD
Scott Davis is offline   Reply With Quote
Old 12-04-2009, 08:44 PM   #6
rcs.ptlwtx
relic
rcs.ptlwtx's Avatar
Oddometer: 46
I did this on the ST. Works great for being seen as much improvement as the LED tail light. Paid too much for the brackets at the local Harley store although these are stout enough I'm thinking of putting driving lights above and the LEDs suspended from each I would look for some "P" bracket clamps at the hardware store next time for just the LEDs. .
rcs.ptlwtx is offline   Reply With Quote
Old 12-05-2009, 12:42 AM   #7
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
These are 7/8" clamps which won't fit. Engine guards (mine, at least) are 1" diameter.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 12-05-2009, 10:51 AM   #8
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,775
I used a couple of pipe clamps to fit my spots to my bars. They cost around a dollar each. Nice and secure and withstood a road crash early in the summer. Never had a problem with vibration or the lamps moving. They also fit the crash bars.
You can get them from plumbing suppliers - available in 15mm, 22mm and 28mm
They look like this off the bike
Rob Farmer screwed with this post 12-05-2009 at 10:57 AM
Rob Farmer is offline   Reply With Quote
Old 12-05-2009, 11:04 AM   #9
Motorman OP
Motorman's Avatar
Oddometer: 496
Thanks everyone for all the info and photos. BTW, does anyone know the diameter of the engine guards on the late model GSPD's????
Old 12-05-2009, 01:51 PM   #10
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,475
I believe Ernie makes some brackets for the gs and gspd guards. If you don't see them here give him a pm or email
http://www.twinheadlighternie.smugmu...ta-Motorsports
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 12-05-2009, 03:36 PM   #11
hardwaregrrl
ignore list
Oddometer: 7,540
There are other sizes, just gotta look...
http://www.whitehorsepress.com/produ...oducts_id=6031
Old 12-05-2009, 03:48 PM   #12
Zagando
BMW uber alles!
Zagando's Avatar
Oddometer: 1,175
I think they're 22mm but I'm not sure...maybe someone else here knows exactly?
=Zagando=
2003 Honda Ruckus "Rucca"
ex: '94 K75S "Berlina" '92 R100GSPD
'85 K100RS '73 R75/5 '65 R60/2
Zagando is offline   Reply With Quote
Old 12-05-2009, 06:08 PM   #13
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
My 92 GSPD has 1" diameter guards. If your oil cooler is still in it's original position, mounting a lamp on the right guard could be a problem.
OCJ
92 R100GS-PD Euro
07 R1200GS
Times are GMT -7.   It's 11:00 AM.
