Old 03-09-2011, 01:17 PM   #6976
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,773
Originally Posted by JaxObsessed View Post
That's funny... the picture on ebay says 4oz.. the add itself says 11oz...
edit//// BAHAHAHAAAHAHAH
Edit again.. can on the way :) thanks for the recommendation..
I ordered this
and received this
06 KLR 650 "FBG" 99 Triumph 885i Tiger "Girlie"
Smokehole after midnignt..."I'm hungry", "me too" How about some Bitches n Gravy?
I'm a thread bully with no Ragrets.
Scotty P is offline   Reply With Quote
Old 03-09-2011, 01:20 PM   #6977
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,773
Originally Posted by GSA_PILOT View Post
What going on Saturday? I'm available for a day ride. Any thoughts?
I thought you were going to help me mount tires?
Old 03-09-2011, 01:38 PM   #6978
REAPER_ONE
YOU'RE DONE
REAPER_ONE's Avatar
Oddometer: 3,170
Originally Posted by blaster11 View Post
Dave is trying to talk me into going dirt riding on Saturday down at the ATV park and I am still undecided. I need to ride but unsure where and when, Dana also needs to get some seat time prior to the class since she hasn't ridden in quite some time.
I'll watch but my girls don't have the right kicks for that terrain.
REAPER_ONE is offline   Reply With Quote
Old 03-09-2011, 01:39 PM   #6979
REAPER_ONE
YOU'RE DONE
REAPER_ONE's Avatar
Oddometer: 3,170
I'm ignoring you... and your tires
Old 03-09-2011, 01:44 PM   #6980
JaxObsessed
Rhonda be strong.
JaxObsessed's Avatar
Location: From Alabama to Newfoundland it's all Appalachian
Oddometer: 15,062
I ordered this
and received this
It is 11oz... not 4
Sorry they f-up your order. mine was waiting on the porch just now.
ClownBoss: We aren't going any where. We are here with you, Rhonda, Dan and Bethany 110%.
JaxObsessed is offline   Reply With Quote
Old 03-09-2011, 01:45 PM   #6981
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,716
Note to self...don't secure hand guard nuts with Loctite 271! Oh and why would anyone secure a handguard nut with red Loctite anyway, seems a bit excessive.
JP Rifles specs 271 for their V-Tac handguards because the nut becomes the foundation for the barrel extension.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 03-09-2011, 01:47 PM   #6982
JaxObsessed
Rhonda be strong.
Oddometer: 15,062
Too far for me...
I suppose there is no way I can call you a pansy.
Old 03-09-2011, 01:53 PM   #6983
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,716
Whats your point, are you saying that Aluminum doesn't melt at 1220F or are you saying that this woman builds a badass fire and don't invite her to do the cooking at LF or invite her because all our wood will be wet and she can build a badass fire?
I'm saying that the 1220F temperature referenced does not take alloys into consideration. The heavy aluminum cookware I've seen is a rough cast, much like cast iron pipe with little or no alloy to help make it hard. Look at the difference in T6065 and T7075. T7075 is much harder and much more durable - an undoubtedly melts at a higher temperature.
Mike -
Old 03-09-2011, 01:55 PM   #6984
REAPER_ONE
YOU'RE DONE
REAPER_ONE's Avatar
Oddometer: 3,170
Too far because I need to process my application in the middle of the day...
But you knew that but I emulate the pansy and poser often.
Old 03-09-2011, 02:19 PM   #6985
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,716
Actually 7075 can melt a couple hundred degrees lower than 6065. 6065 is still up around 1080 - 1225 F and 7075 is between 890 - 1175 F. Bottom line is when working with Aluminum and heating it up you need to be careful! When in doubt if you have applied enough heat...STOP!
Shortly after this happened I started using heat crayons and eliminated the problem.
I still use 271 on clients rifles - too many of them wind up in harms way and I'll not risk something coming undone. The nut I refer to is on the outside and retains that handguard, not the barrel. The handguard nut gets ridiculously hot under any kind of sustained fire (on semi-auto) and absurdly hot under full auto - ergo the use of 271. The actual barrel nut is coated with anti seize and torqued.
Mike -
Old 03-09-2011, 03:04 PM   #6986
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,773
Scott,
That sucks about the lube...was this through Ebay?
Good news! I called and they found 3 cans and they are on the way.
They told me to keep the 3 bottles of air gun lube
Old 03-09-2011, 03:10 PM   #6987
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,773
Originally Posted by Lonestar2112 View Post
Sorta goes with this, doesn't it?
You are a sick puppy
Old 03-09-2011, 03:12 PM   #6988
JaxObsessed
Rhonda be strong.
Oddometer: 15,062
Nice!
Old 03-09-2011, 03:13 PM   #6989
Scotty P OP
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,773
I ordered this
and received this
It is 11oz... not 4
The 11 oz cans are being discontinued.... so stock up.
Edit: another ebay vendor......they are asking $7.99 for the 4 oz cans
Old 03-09-2011, 03:34 PM   #6990
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,740
But you loved it!
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Times are GMT -7.   It's 04:20 AM.
