Old 12-07-2009, 05:37 PM   #1
Johnny Dakar OP
Fuckin' Smartass
Johnny Dakar's Avatar
Oddometer: 14,097
Powerlet on an Airhead?
L.A. Woman's R80/7 may need a few accessories......can the bike support one?
"Just sharing this quiet time is intimate, our tent, our bikes and our faces illuminated by yellow light from the fire. This is why we travel. To experience those rare moments of perfection of solitude of life."
-Simon Thomas
Johnny Dakar is offline   Reply With Quote
Old 12-07-2009, 06:04 PM   #2
boredom
boredom's Avatar
Oddometer: 136
Depends on what it is, and most likely you'll need a new alternator setup to power anything medium-to-large-ish.
boredom is offline   Reply With Quote
Old 12-08-2009, 05:13 AM   #3
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,476
If your charging system is well maintained and up to snuff it will support a heated vest or a aux. light etc. If you want to run a couple of lights and a vest etc. all at the same time you would need a system upgrade. On my stock system I run a vest and a PIaa 35 watt light at the same time without issues. Though I am in the habit of shutting something off if I go through town and the revs aren't being kept up.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 12-08-2009, 08:05 AM   #4
Johnny Dakar OP
Fuckin' Smartass
Oddometer: 14,097
Do you guys connect directly to the battery, or into a switched circuit?
-Simon Thomas
Old 12-08-2009, 08:29 AM   #5
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Normally to a fused (but not switched) circuit. But direct connection is possible but I would ensure the + wire is fused.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 12-08-2009, 09:56 AM   #6
bmwloco
bmwloco's Avatar
Oddometer: 1,448
Get Motorrad Elektrik's new Omega 450 system.
www.motoelekt.com
You can run a big headlight, heated grips and clothing, and still have ample power to run anything else.
It has saved my tail riding year round. Sure, there are others out there, but this one is da' bomb.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 12-08-2009, 02:20 PM   #7
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,595
a quote from an inmate:
Ignition 2.5A, Headlight 4.2A, taillight 0.5A, Brakelight 1.8A, Dashlights, Maybe 0.5A -Phreaky Phil
that's about 8 amps. another quote also from Phreaky Phil:
Standard, the system puts out 17A (240w) but the rotor draws 4A of this so you are left with 13A usable (182w). -
I can't verify these numbers but I've no reason to think he's wrong. remember that 13a would be in peak condition at peak outpu(~3500rpm iirc)t. I've read of people that tested their's at less probably due to loss from corrosion.
my G/S had a 20a rotor(280w), not a 17 like the /7s and it still wouldn't charge the battery at idle.
Find the draw for the accessories you want and see if you can squeeze them in. Like JT said, if you don't turn them on until over 3500rpms you'll probably be okay if they don't draw more than 3 or 4 amps. It would make having a good battery that much more important.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil screwed with this post 12-08-2009 at 02:40 PM
bgoodsoil is online now   Reply With Quote
Old 12-09-2009, 02:22 AM   #8
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 798
Y'all know I gladly pimp out the Omega charging system. nothing like being able to run errands now with charging impunity.
baldwithglasses is offline   Reply With Quote
Times are GMT -7.   It's 10:05 AM.
