Old 12-30-2009, 06:56 AM   #16
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
I don't know the correct stackup of the washers without taking mine apart again, but the parts fiche shows the stackup I think.
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 12-30-2009, 06:57 AM   #17
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,238
i helped a friend with a gen light on all the time issue. i went thru all the tests in the ME charging book and it ended up being a washer issue. i think only 1 post is supposed to have a washer. call rick at ME and he can tell you. buy his book, it rocks.
bmwblake is offline   Reply With Quote
Old 12-30-2009, 07:26 AM   #18
pecos OP
BAM!!
pecos's Avatar
Oddometer: 465
Parts fiche nor Haynes manual show the stack. Would have thought fiche would show it.
pecos is offline   Reply With Quote
Old 12-30-2009, 07:28 AM   #19
pecos OP
BAM!!
pecos's Avatar
Oddometer: 465
Originally Posted by AntonLargiader
If the light stays on it could mean that you shorted the brushes or it might just mean that the system still isn't working.
Shorted brushes - easy to look for with a multimeter. Lift the brushes and look for continuity between the terminals and the case.
Otherwise, maybe you just left something disconnected.
Original issue was the chirping. Like staying on is new issue. It doesn't even flicker. Which seems like the washer issu.e
So you can short a brush? Is there something special inside it?
Old 12-30-2009, 02:26 PM   #20
pecos OP
BAM!!
pecos's Avatar
Oddometer: 465
.....there is a washer in there that isolates the circuit on one of the studs and if it's not put back together right, it won't work.
That was the issue. I needed to isolate the DF side vs the D- (grounded side)
Thanks. File this one away.
Times are GMT -7.   It's 04:26 PM.
