Old 03-27-2012, 06:47 AM   #361
OnkelPopanz
Oddometer: 64
Originally Posted by HighFive View Post
Seriously? How did you keep from passing out?
I've heard a lot of descriptions regarding windshields, but never this one before. That's funny.
Well I think this problem was caused by low pressure which occured with some settings of the shield (not all!). The low-pressure seemed to pull the air out of my helmet when visor open. Excuse this clumsy explanation - English is not my mother tongue...
Anyway, you've described all but the most important thing about yourself: your height. You're "inseam" has little to do with your helmet height while sitting. Unless you meant you were standing on the pegs.
So, how tall are you? What seat are you sitting on....stock high or low, or something custom? I have similar weight and inseam, but am 5'9" tall, on a Renazco modified seat that is actually 1/2" taller than stock high.
As I wrote my height is 181 cm. Don't know what exacly this is in English measurements (something about 6'?). My Seat is a little bit higher than stock I think (maybe about 2 cm).
I have experienced none of the problems with the D3 which you have described. At least not, while wearing either of my Shoei helmets (RF1000 & Hornet). The D3 has been absolutely fantastic for me in any of the elevated positions beyond half way up.....whether tilted forward or aft.
Maybe its that Schuberth helmet that is causing the suffocation. Think I'll steer clear of those based on your description.
HF
Experiences with windscreens are quite individual I think....
OnkelPopanz screwed with this post 03-27-2012 at 10:19 AM
OnkelPopanz is offline   Reply With Quote
Old 04-07-2012, 11:33 PM   #362
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
New Dash Layout for the Desierto III
I am banged up with a broken collar bone from a MTB training run crash during my prep for the APC rally in August. So in the interests of doing something useful towards the rally prep over Easter I have designed a new dashboard. Both our F658's have a Touratech dash back with the Desierto III fairings which allowed me to mount the necessary charge outlets and stuff, but it was always a bit of a mess and constantly annoyed me.
So the CAD work is almost done for the new one. Hopefully next week I can send it to the laser cutters. After that if everything fits as it should I am going to anodize them as the powder coating on the Touratech one is a crap idea. Controls are LH: UHF radio, Burns Moto USB, Powerlet 12v outlet and RHS: Burns Moto ABS disable circuit, main headlight on/off (for when we travel where it is rude to have the HL on all the time during the day) and Clearwater spots on/off and dimmer. The space top RHS is for a future use perhaps a heated vest controller. The outline is a neat fit inside the DIII fairing, I hope TT make them all from a similar mould or it won't fit as I have made it quite a neat fit, took lots of suck-it-and-see CAD to get it right as the shape must have been originally made by a pattern maker using hand carving techniques, not a bad way of doing it but it does result in same rather "unique" shapes.
I'm also building version 3 of my custom screen for the Desierto III, the first couple were designed and built a year ago in a hurry before we shipped the bikes to New Zealand for a month of South Island play, and then had to do the job again last Christmas for the North Island because last year was a tad busy, but they don't perform that well in the rain, so I have hatched a plan for a new shape. The mould is done and I am in the process of learning how to vacuum form clear acrylic, the current ones were drape moulded and the new shape is too complicated for that process to work - pics to come when i'm a bit forther down the track.
In the pic below you can see the outline of the Touratech one for refernce
Here is what the Touratech POS looks like - very poor quality powder coating, not to mention the sloppy fit. On the LHS you can see the original UHF mount I made, it worked just fine, but not "just" right and I am a bit of a perfectionist, so a new one is needed.
And here is what the current custom screens look like - on the Nevis Track South Island in New Zealand, 27 river crossings in 5 hours what a blast!
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C screwed with this post 04-08-2012 at 01:44 PM
Mike.C is offline   Reply With Quote
Old 10-02-2012, 05:20 PM   #363
crossplane
Oddometer: 45
I've tested out the Desierto now on some longer rides, some offroad only rides, some road rides and mixed, and I'm of two minds about it.
I certainly love how it looks, it really finishes off the look of the bike. It provides pretty good wind protection but with some things I have noticed are a problem for me being 186cm tall.
1) Having the screen in its highest and full forward position creates a weird buffeting effect that if I wear a road helmet and have the visor open, the visor catches the wind and vibrates. It doesnt even need to be open all the way, but it shakes and vibrates and carries on. It's bloody annoying.
2) The screen provides great wind protection though I have to hunch a little bit to actually stay in the clean air, otherwise I'm in this weird zone between direct flow and nice wind protection and it makes my head wobble around. This is surprisingly not as bad wearing a dirt bike helmet because you can direct your head down a bit and i think the wind just slices over the top of the peak, and then you're sweet.
3) It shakes and wobbles so much! I've got it all tightened up and it's installed correctly, but the amount it appears to move around when offroad freaks me out. I know it's fine but I still get irked about that.
4) Boy do the adjustable screen bolts love to come loose. Ride offroad or on corrugated roads and they come loose so quickly it's not funny. you can make this not as noticeble by locking it in the bottom lowest position and it doesnt come as loose as easy. What things have people done to solve this? I love the adjustability but I wish I wouldn't have to stress about them rattling loose all the time.
All in all though it's stupidly expensive but I do really like it. Looks and function are right up there, but I'm just a touch too tall for its effective wind protection area I think, and that is a shame. I'm going to test with different screen positions as I think that I may be able to find one where I cop a bit more wind but it's "cleaner" air.... and see how I go. Two thumbs up from me though for the desierto but that may just be me trying desperately to justify my purchase
crossplane is offline   Reply With Quote
Old 10-02-2012, 07:14 PM   #364
ebnelson
Frozen rider
ebnelson's Avatar
Oddometer: 233
I like the desierto 3 fairing but have a reoccurring problem. Twice on washboard gravel roads I have had one of the white plastic thumb nuts with their bolt rattle off. I have been lucky enough both times to go back up the road and find the parts. Has anyone else had this issue? I feel like I am tightening them enough. I have been thinking of putting an o-ring as a washer on the bolt to get pinched by the plastic nut to help keep it from vibrating off. Ideas?
ebnelson is offline   Reply With Quote
Old 10-02-2012, 07:34 PM   #365
crossplane
Oddometer: 45
That's the same problem I'm having. The nuts that hold the windscreen on vibrate themselves loose very quickly.
I thought about using a spring washer or even an o-ring as you suggested to provide some sort of force against it, hopefully tensioning the nut so that it will not just vibrate loose.
Either that or I'll just have to replace them with nylock nuts and be done with it, and just use a tool to adjust my windscreen. I really didn't want to do that but if it's what I have to do to stop it from undoing itself, so be it...
Old 10-02-2012, 07:40 PM   #366
ebrabaek
Oddometer: 4,745
Although mine is not a D3.... I have the adjustable screen as well...... I used blue loctite on my screws.... none have ever come apart....
Erling
Old 10-02-2012, 07:45 PM   #367
crossplane
Oddometer: 45
Forgive my potential ignorance here, but doesn't that make it difficult for you to adjust the screen?
Old 10-03-2012, 01:54 AM   #368
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
TT must know about the shield adjustment problem as our DIII's came with a nylock nut and a small laser cut spanner with a bottle opener on the other end as well as the plastic nuts. The instructions also said quite clearly that if you use the bike on rough roads the plastic ones will vibrate out and to use the nylock ones.
Our experience has confirmed this.
Cheers, Mike
Old 10-03-2012, 03:11 AM   #369
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
I think some loctite would solve the problem of your screws.
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 10-03-2012, 03:53 AM   #370
crossplane
Oddometer: 45
Well don't I feel like a right idiot now! You are correct, my kit came with the same small laser cut spanner and nylock nuts as well. It didn't even click in my head that they were there for an alternative to the plastic nuts and I missed the mention of this in the instructions.
Cheers anyway for the info.
Old 10-03-2012, 09:30 AM   #371
ebnelson
Frozen rider
ebnelson's Avatar
Oddometer: 233
a wrench and nylocks are not the most convenient means of adjustment. I typically have ridden with the screen up on the highway while transiting to a dirt road pass that is the highlight of my trip. On the dirt / gravel I like the screen all the way down so that I am not looking through the screen while sitting.
I will look for wingnuts with more leverage with the addition of an o-ring or springs to maintain nut to bolt thread engagement.
Old 10-07-2012, 08:44 PM   #372
runnr548
BMW Pilot
runnr548's Avatar
Oddometer: 123
Cool2
Having made several four hour plus rides, several in downpours, I have come to the conclusion that I am very happy with the Desierto 3. Still pricey, but I am glad I bought it!
runnr548 is offline   Reply With Quote
Old 10-07-2012, 09:11 PM   #373
ebrabaek
Oddometer: 4,745
No worries.......... The screws protrude through the sliding bracket, and terminates with a nut.... The whole assy slides up and down. The loctite holds the nut in place, on the bolt, preventing the whole thing from vibrating appart.
Erling
Old 10-07-2012, 10:48 PM   #374
OZZY-GS
OZZY-GS's Avatar
Oddometer: 426
I had a machine shop spin up 6 x Spare Nuts made out of Aluminium.
I have used them the last 2 x years over very rough conditions and they have never came loose. Still have my spares somewhere.
Cost me about $20 I think
Riding
BMW F800GS
OZZY-GS is offline   Reply With Quote
Old 11-12-2012, 12:34 PM   #375
tomJ
tomJ
Oddometer: 9
Feedback after D3 longtime usage?
Gentlemen
I seriously considering purchase of D3 for my bike. Have tried the Touratech spoiler on standard screen but it does not work for me. It shifts all the air to the top part of the helmet providing buffering and very strange noise (waves of air are hitting the helmet and making this vibrating noiseeee - very irritating one).
So I started to think about D3 as it seems to provide a good flexible option for both long runs on regular roads and offroad rides. After reading this thread I am sure that it would be fine on offroad. I know from other posts on ADV that the best protection for touring is a big screen which protects you from rain, cold, air etc but ... I like to end many of my trips on offroad tracks.
So my question to some of you who have used D3 for a while is how it works on long highway runs especially with the reduction of air noise / pressure issue, rain, cold? It looks like the high of the rider is one of key issue (crossplane thank you for feedback). Since D3 is not a chip option I would not like to end with the same strange noise inside my helmet - but now a much more expensive one.
I am 180 cm high (so if think it is 5' 10''), inseam 80 cm (so 31'-32'), standard seat, schuberth C3.
Thank you in advance for your feedback? Hope it would be useful for others negotiating the budget with Santa before the incoming Christmas period ;)
Tom
tomJ is offline   Reply With Quote
Times are GMT -7.   It's 03:20 AM.
