Old 12-26-2009, 12:18 PM   #91
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,678
No, stock mirror setup.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 12-26-2009, 12:20 PM   #92
F8 Pilot
Bak in the Sadl & Lovinit
F8 Pilot's Avatar
Oddometer: 81
Thanks, looking forward to the ride report.
"Never Ride Twice on the Same Piece of Earth"
F8 Pilot is offline   Reply With Quote
Old 12-26-2009, 08:09 PM   #93
jeffchri
Oddometer: 132
Originally Posted by DockingPilot
Jeff,
hopefully you can today, because it's pouring here. And forget the dirty ride, stock shield works there, take her out and bring her up to speed to see how it does deflecting slab style wind. Although your experience will be unique.
I got to ride for about 30mins this evening, bombing back and forth up and down the interstate. I didn't wear earplugs, so that I could have a good sense of the impact of adjustments. My experience is that it's definitely better than both the stocker and the Adventure screen, which I've lived with until this point. The positions with the upper screen raked forward (pointed more towards vertical) were far better than those that had the upper screen matching the angle of the lower bit of fairing. All heights worked well enough, with the middle height probably being the best. Oddly, the tallest introduced some thrumming that wasn't entirely pleasant in the visor, perhaps due to some air coming in between the fairing and screen at the high position.
Hard to know exactly how "good" you can reasonably expect a visor-d dualsport helmet to behave at 70mph, but this sure seems like it's getting close to as good as it gets. At any rate, it was definitely nice to have windblast taken off of my torso, I could turn my head side to side and get no wind pressure blast that torqued on my neck, etc. Time will tell if some of the other vibrations I was sensing would start to drive me crazy. Plus, btw ... it looks bad-a$$ ... :)
Also Jeff, I am not having a cleance issue with the headlight. Its sorta close but no contact.
I definitely have a problem with the fit, as it runs into the anti-glare guard (http://www.touratech-usa.com/shop/sh...FD69LUvO3F9050) and prevents the headlight from being adjusted high enough. Franke, do you have one of those fitted? I've pinged the guys at Touratech to see if this is a known issue.
2009 BMW F800GS - the "attack helicopter"
2008 Husqvarna TE510 - loud and proud
2006 BMW R1200S - dedicated track bike now, mostly because of sloppy welds
2010 BMW S1000RR - soooooon, very soooon ...
Recent past: Montesa 4RT (now in the hands of the fiancee), Weestrom, F650GS Dakar, Yammy WR250F, (a scooter), (another scooter)
jeffchri screwed with this post 12-26-2009 at 08:43 PM
jeffchri is offline   Reply With Quote
Old 12-26-2009, 09:04 PM   #94
go coastal
go coastal's Avatar
Oddometer: 6
Thanks for posting the review Jeffchri. It was an expensive bet on your part but it sounds like it worked out. I have wanted this thing for quite some time but only now just pushed the "purchase" button at Touratech after reading your review.
Cheers
go coastal is offline   Reply With Quote
Old 12-27-2009, 04:39 AM   #95
DockingPilot
Oddometer: 9,678
Jeff, no, I do not actually. Is you headlight now out of position ?
Nice test Jeff. I will be out on mine today testing. Again. I'm 5'9"-5"10 with an XD , standard seat (soon to be a Renazco). And Drumming sensation or lack thereof, is what I'll be focused on.
I owned the king of the XD drummer's, the 950 Adventure !
Frank Reinbold
Old 12-27-2009, 06:18 AM   #96
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,393
I used to use an Arai XD and I have had the Shoei hornet for 2 years now and it is superior to the XD in air flow design at 70 mph in open wind on my Husky TE610. Don't be afraid to toss a new helmet into the test mix.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 12-27-2009, 06:26 AM   #97
DockingPilot
Oddometer: 9,678
Being friends with you is proving to be more expensive than having kids !
Frank Reinbold
Old 12-27-2009, 07:39 AM   #98
Indy Unlimited
Oddometer: 1,393
I wish us development gurus would live closer so as to share and compare set ups and accessories more easily and cost effectively. Oh well. You know what they say about us pioneers, we always end up taking the arrows! The Touratech arrows hit the deepest when they don't work out. That stuff is pricey!
Current Stable:
Old 12-27-2009, 10:14 AM   #99
jeffchri
Oddometer: 132
I'll try removing mine - it should be fine without it.
... And Drumming sensation or lack thereof, is what I'll be focused on.
There might still be some of that, I'm really not sure. I prefer what it is now to what I had before, though. Though again, $800 better? Umm ...
Oh, FWIW, I was playing with speeds around 60-70mph.
Old 12-27-2009, 01:21 PM   #100
DockingPilot
Oddometer: 9,678
Just in.
Again, Im 5'9" with an Arai XD.
"It's a keeper" for me.
Lets face it, it's not the low position that needed evaluation. Summer, off pavement, you want air, almost any shield will do including the stock one. No, it's the higher speeds that needed something else for me. The stock shield was best too for me. Air, and it was clean, but it was tireing after a while holding on with that wind blast.
All the aftermarket shields I've tried did take the blast off my chest and arms but threw turbelant air at my helmet creating a lot of noise.
For me, this shield in the upper/foward position cured all of this.
Finally !!
I rode fast county roads and then took it out on Rt. 80 and throttled up to 90mph. Here's what I noticed:
I can ride with my helmet shield up with no tearing. Sun glasses on.
I can turn my head left and right with it wanting to twist right around. No wind resistence at all.
I can actually hear my bike if you know what I mean.
No pressure on arms and chest.
Now, I wasn't in a vacume either. So don't get the wrong picture, it was not like riding a RT, but this bike is not an RT. But the air I was in was pretty calm. No drumming in the top/foward position. Once off the high speed roads, it takes all of 15 seconds to lower it.
One thing I want to keep an eye on is wether the wind resistence on the shield will push it back with the force and vibration. There are no notches like the 1200's have on the oem shield bracket. This is just two smooth surfaces with a knurled nut creating the sticktion.
So, at last I found a shield I am happy with. Cost me a rude amout of $$, they really have nerve , but it does the job and looks pretty cool to boot.
Now I just have to keep telling myself to keep this bike for a while with all the $$ I've got in it. My friends circle me like vultures waiting for my well farkled bikes.
Frank Reinbold
Old 12-27-2009, 04:29 PM   #101
zaner32
In over my head
zaner32's Avatar
Oddometer: 651
Thanks Frank!! Now I'll have to go out and buy one! They're only about $1,100.00 here. I've already checked!
2009 KTM 990 Adventure
Just ride!
zaner32 is offline   Reply With Quote
Old 12-27-2009, 05:06 PM   #102
go coastal
go coastal's Avatar
Oddometer: 6
Touratech Canada
Hey Zaner32,
If you can possibly find a US address to use you will save yourself about $230. I just ordered one from Seattle and had it shipped to a buddy in Port Angeles Wash. All in, with dollar difference, tax, and shipping factored in it was $935 CAD. That's enough if you ask me; too much in fact for an already overpriced item (I can't believe I actually paid that). I sent a message to Touratech Canada and asked them where they got their price from (Ze Motherland no doubt). I explained that I would rather support the Canadian Team but just couldn't justify the price difference. No reply yet...
I'm a noob but it seems most people on here are pretty friendly; somebody on here would probably let you ship it to them and then forward it on.
Ben
Old 12-27-2009, 05:21 PM   #103
DockingPilot
Oddometer: 9,678
JP, If your crazy enough to pull the trigger on one, I'll do that for you my friend.
Frank Reinbold
Old 12-27-2009, 05:53 PM   #104
markymcd
markymcd's Avatar
Oddometer: 882
Originally Posted by go coastal
Hey Zaner32,
Ben
Hey Ben, if you live within a reasonable distance from the border you can also ship to CanAmer Freight in Blaine Washington and they only charge you about $3 for receiving it. But, then again you might as well just ride down to Seattle without a fairing and install it and ride back
I've been working on a design that will attach to the stock screen that will do the same thing for probably less than half the price, but that is a little down the road from now.
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 12-27-2009, 08:17 PM   #105
go coastal
go coastal's Avatar
Oddometer: 6
CanAmer Freight
Thanks for the tip markymcd. I had no idea that you could do that. I think that's going to come in handy. I live in Victoria so Port Angles and Blaine are about the same distance/cost for me. Still a helpful tip though.
I'm intrigued about your future mod to the stock screen. Sounds far more reasonable! Keep us informed.
Ben
Times are GMT -7.   It's 03:04 PM.
