Old 12-11-2009, 06:07 PM   #1
DrLewall OP
DrLewall's Avatar
Oddometer: 23,796
XR400 swingarm bolt
I have been putting this off for a while now. About a year ago, I thought I would try and remover the swingarm bolt out of the XR400. I have soaked it several times with all kinds of penetrating oil to no avail. I have even gotten the assistance of a couple of friends to help me beat on this thing, complete with 500lb pnematic impacts, with no results. So this has been on my mind alot.
About 3 weeks ago, we went for a ride. The XR started to miss so I nursed it home. Tried to change the plug but the cheap plug wrench rounded off the plug. Now is the time to pull the motor, do a top end on it and fix that damn swingarm bolt and a fe other things.
ok, so myself and inmate Mossycreek decide to tackle this. We come up with a bar that we will turn down on the lathe and then us this bar as a punch and see if we can't beat the bolt out.
So we turn down abt 3 inche enough to fit thru the frame just enough to get a good solid seat and hit on the bolt..we laid the XR on its side and some wood to protect the cases just incase the hammer missed.
The only thing we accomplished was knocking the threads completetly out of the swingarm bolt nut. The bolt did not budge.
So now, we are eyeballing the 20 ton press over in the corner. We lay the XR up on the bike table and raise it up enough to fit the back end into the press.
So mossycreek starts pumping it...he had to get up on the table so he could apply more pressure we had that handle TIGHT! Could not push down any more on it. It was quite tense in the shop. We just knew something was going to pop or explode..nadda, nuttin..bolt did not move!
So now we whip out the drill..sorry, no pix of this process, doesnt matter anyway cause drilling the bolt out did not work either! What a mess!
last resort, out comes the sawzall...
Now I can get the saw in there enough to cut out the bolt..and that works..FINALLY I get the motor out
Now I have to get the remnats of the swing arm off the motor.
once the swing arm is chopped off, I slide the end pieces off and find that the bolt is rusted tight to the bushings..I take the grinder and cut into the bushing and finally get it off.
I then take the sledge and beat on the bolt and finally it starts to move. I soaked it with some liquid wrench and that seemed to help. The end of the bolt started to mushroom a bit and after knocking the bolt back and forth thru the motor mount a couple of time to loosen it up some more, I then cut off the mushroom end and drove the bolt out...all in all, I have abt 10 hrs into this trying to remove this damn bolt.
Many have suggested that I install zerks into the swingarm. Sure thats a good idea but I think from now on, the swing arm bolt will get pulled EVERY YEAR and lubed..if I have zerks in there, then all I would do is grease it and not pull it to check it..I dont EVER want to go thru this again so the bolt get pulled annually, PERIOD!
I have another swing arm on the way and I really hated to cut this one but I had no choice. Let this be a lesson to you guys, check that swing arm bolt often!
DrLewall is offline   Reply With Quote
Old 12-11-2009, 07:43 PM   #2
DRZ Charlie
Old & beat up
DRZ Charlie's Avatar
Oddometer: 11,076
Glad you finally got it out Doc. What an ordeal. Great write up and good advice.
Ride, Crash, Visit the ER, Get a splint, Recuperate, Assess your mistakes, Repair Motorcycle, Gather courage to ride again, Ride, Rinse & Repeat
My SPOT - No tracks = not riding | Mapsource Tutorial | Rides
DRZ Charlie is offline   Reply With Quote
Old 12-11-2009, 08:23 PM   #3
Dragon43
If you insist.
Dragon43's Avatar
Oddometer: 5,466
That is scary.....
I think there is a reason 2 of my bikes are hard tails.....
You are never too old to learn something stupid.
Dragon43 is offline   Reply With Quote
Old 12-11-2009, 09:41 PM   #4
ThereisnoSpoon
Wall of Death Rider
ThereisnoSpoon's Avatar
Oddometer: 1,510
The same thing happened to the XR400 that I had. I had pulled everthing apart a coule of times and greased and never siezed the swingarm bolt and the last time I tried to take it apart it was siezed. Never say never.
I didn't take the removal process as far as you did. I went a different direction - I sold it. I really liked that bike too.
ThereisnoSpoon is offline   Reply With Quote
Old 12-12-2009, 06:17 AM   #5
DrLewall OP
DrLewall's Avatar
Oddometer: 23,796
yeah I must be nutz..
but I really like this bike too..for the kind of riding I do, it is PERFECT! I do admit tho, as I get older and the old knee has really gone down hill, the thought of an electric start drz400 is very tempting..but I feel that this old XR is worth sinking some more money into and I am willing to kick it as long as I am able to and who knows, I may invest the extra $1400 for the electric start kit for it..gosh I love this machine! even tho this part is a major PIA!
Old 12-12-2009, 06:44 AM   #6
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 6,593
Dang Doc, sorry you had to go to such extreme measures.
katbeanz is offline   Reply With Quote
Old 12-12-2009, 06:50 AM   #7
mcma111
mcma111's Avatar
Oddometer: 7,981
Bolt
Boy Oh Boy, You sure showed that bolt who's BOSS...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-12-2009, 09:08 AM   #8
Elvis70
No speed traps in the sky
Elvis70's Avatar
Oddometer: 4,923
Annually?
I would take it out every 6 months after that ordeal. Jeez, never seen anything like it. Mechanical engineer I used to work with would of loved it. His favorite tools were the sawzall and the cutting torch.
Seems this is a problem with the XR's. What can you do to further prevent moisture in there? Mine don't go through the damn engine. Wondering if the heating and coolling from the engine adds to the problem? I would say it does.
I'll tape it to the handlebars, it's just logic George! If your hand is broken, you tape it to the bars! - Evil Knievel's reply to George Hamiliton's question, "How will you jump with a broken hand?".
Elvis70 is offline   Reply With Quote
Old 12-12-2009, 09:30 AM   #9
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 594
I have this press in my garage, and I can't imagine getting to the point where you can't move the jack handle any more and not have something get seriously bent and broken!
I take it this is the remaining bushing that is still rusted solid on the remains of the bolt?
Did you try PB Blaster on this? If this bushing is still rusted solid, then you've ended up with a great test case for the PB Blaster claims. I don't suppose you would be interested in soaking this in some PB Blaster overnight to see if it will break the bond?
I started using PB Blaster on some items in my XR500 rebuilds, but I had nothing this bad to deal with. I was impressed with the results of the PB blaster on some bushing to shaft(ed) rust. Normally I do what you did, get out the sawsall.......... and the hammer............. and the torch............ and the grinder.
Remind me not to buy used stuff from not so dry places.
Ghost_Mutant is offline   Reply With Quote
Old 12-12-2009, 10:40 AM   #10
DrLewall OP
DrLewall's Avatar
Oddometer: 23,796
Yes..that is the remaining bushing on the bolt..which will now be a drift punch in the shop...the PB blaster did soak abt half way down the removed bushing and we tried to twist and tunr it to no avail, thus the cutting wheel marks. The shinny part of the bolt is where I took some emery cloth to clean up the rust a little in order to get the case bushing off. Sorry I dont have any pix of that episode but as we beat this out of the case, the case bushing came out and was butted up next to the main swingarm bushing. We then put this into the press and used a torch to heat up the case bushing and then pressed the bolt down and out of the case bushing..it was pretty much covered in rust..thus the heat mark on the bolt
Old 12-12-2009, 01:01 PM   #11
Uncle Meat
Oddometer: 1
I bought an abused XR400, had to rebuild the motor and found myself in the same shape.
Soaked it and sledged it for a week.
No luck.
So I put a small gas welding tip on my cutting torch.
Since the bolt is hollow, I blew the flame thru the bolt until parts were starting to glow.
Started with the sledge again and it started moving.
LOTS of heat is your friend!
Uncle Meat is offline   Reply With Quote
Old 12-12-2009, 01:53 PM   #12
Luke
GPoET&P
Luke's Avatar
Oddometer: 3,748
Wow!
When I saw your other post about cutting off the swingarm I thought you were giving up a little early. Was I ever wrong.
I've pulled the swingarm bolts on six of these, and only one of them needed the big hammer. Nothing like this. Of course, these bikes were all from CA. The '97 still had the factory grease on it.
The other five were newer models and only one had grease on it, and that looked like it was done by a PO.
Luke is offline   Reply With Quote
Old 12-12-2009, 07:02 PM   #13
Zuber
Zoob
Zuber's Avatar
Oddometer: 985
Hummmm, wonder why shops don't like working on old bikes?
"Son, you can't do both"
Old 12-13-2009, 04:38 PM   #14
Thunderchild
Rumble, rumble
Thunderchild's Avatar
Oddometer: 260
Been there, almost done that. Here's an off site link to my saga about my XR650R swingarm bolt. Check my pictures out about halfway down the page. Nasty stuff!
http://www.xr650rforum.com/mm-swho-d...bolts-t194.htm
You're halfway there now!
TC
Lead us into the land of Dirt and Beer.
Thunderchild is offline   Reply With Quote
Old 12-14-2009, 02:56 AM   #15
MacMan
Oddometer: 568
I had a mate who told me stories of having to put his whole bike in a 20T press. Until today, I had trouble visualising it.
Gruesome!
MacMan is offline   Reply With Quote
Times are GMT -7.   It's 11:03 PM.
