Old 12-12-2009, 11:37 PM   #1
TrappedAtWork OP
No Longer Trapped!
TrappedAtWork's Avatar
Oddometer: 254
Question Honda CT110 - will not idle
Hi All,
Spent the day in the shed (sorry Cob "racing workshop"), so overall a good day.
We have a honda CT110 postie, that we thought had a sticking throttle cable, so set about trying to fix it today.
We cleaned the carbie out, took the bowl off and blew out the jets, all seemed ok. Reassembled with no spare parts. Everything appers to be normal.
The problem:
We can kick start the engine, with just a little throttle to get it going.
Idle will not hold the engine, therefore we must hold the throttle on just slightly, to get it to idle.
After reving engine it will return down to near idle speed, the die if the throttle is not held on. After reving a few times in a row and closing the throttle the revs continue to rise, until the engine seems it is about to explode. (They make a lot of noise at 15000 revs )
We unscrewed idle screw a turn or two and the revs fall, the engine will die if the throttle is not held on just slightly.
We also tried to take out the free play in the throttle cable, near the twist grip.
The throttle cable does not appear to be sticking.
This is a very small slide carbie with a long needle through the middle of the air flow chamber.
Air filter is clean, added fresh fuel to the tank.
Box of matches standing by.
Any thoughts gratefully accepted...
Cheers,
TAW
No longer trapped: Riding the Pan American Highway right now! https://transcendenttravel.wordpress.com/
TrappedAtWork is offline   Reply With Quote
Old 12-13-2009, 06:37 AM   #2
showkey
Oddometer: 2,001
The pilot jet (also know as the slow jet is plugged) it is a very very small hole and you should hold up to the light to check, you can pass a small wire through but be careful not to inlarge or ream the jet larger.
This asumes the air screw is open about 2 turns as a starting point.
showkey is offline   Reply With Quote
Old 12-13-2009, 07:01 AM   #3
mcma111
mcma111's Avatar
Oddometer: 12,928
Slide
Did you put the slide in backwards???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-13-2009, 07:17 AM   #4
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,683
That can cause the problem as well as a too tight intake valve clearance.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 12-13-2009, 09:42 AM   #5
showkey
Oddometer: 2,001
Not really possible and still have run off idle.....the slide has a slot and the slide bore has a pin they must line up for the slide to be in the down or closed position.
Old 12-13-2009, 09:45 AM   #6
showkey
Oddometer: 2,001
#14 is the pilot or slow jet
Old 12-13-2009, 12:07 PM   #7
trail90man
Oddometer: 12
It is possible you are barking up the wrong tree
I have about 30,000 miles experience on trail 90s. It sounds like you should check the spark advance. This is a mechanical unit behind the points up on the left side of the head. if this sticks, it is impossible to set the idle. You can wash the advance out with some wd-40 without removing or re-setting the points and see if that allows you to set the idle. if it helps the real solution is to remove the advance unit and clean and grease it.
Kyle :-)
trail90man is offline   Reply With Quote
Old 12-13-2009, 12:50 PM   #8
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,729
You can ask these folks. They have alot of CT experience. I would like to have been able to go on one of these rides, looks like a blast!
http://rides.webshots.com/album/229770370jeQVmM
2004 MOJAVE DESERT SMALL BIKE RIDE Ridgecrest to Randsburg
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin screwed with this post 12-13-2009 at 01:00 PM
vtwin is offline   Reply With Quote
Old 12-14-2009, 02:04 AM   #9
TrappedAtWork OP
No Longer Trapped!
Oddometer: 254
Thumb
Thanks, I believe this this the problem.
From memory, I think the outlet from the Pilot screw (circled in red) is blocked, I will pull it apart and have another look. I did not really pay attention yesterday.
I'll take a look as soon as I can get to the racing workshop.
TrappedAtWork screwed with this post 12-14-2009 at 02:13 AM
Old 12-14-2009, 02:07 AM   #10
TrappedAtWork OP
No Longer Trapped!
Oddometer: 254
Cheers but I don't believe so, there is only one way that it goes in.
Old 01-09-2010, 03:17 AM   #11
TrappedAtWork OP
No Longer Trapped!
Oddometer: 254
Thumb
Thanks to showkey.
The postie now idles.... Cheers...
Old 05-01-2010, 09:37 PM   #12
tundrawolf
Desert Rat V Star
Oddometer: 313
Kyle :-)
I used oil to lubricate the advance assembly. Should I use grease? It seems to have significant resistance with grease. Does it matter?
tundrawolf is offline   Reply With Quote
Times are GMT -7.   It's 02:41 AM.
