Old 12-19-2009, 08:35 PM   #91
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,157
Originally Posted by Blakebird
Noon it is then.
See you noonish. BTW: everyone is welcome to tag along if you want to do a bit of street cruising.
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is online now   Reply With Quote
Old 12-19-2009, 08:50 PM   #92
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
I need to replace my sheared footpeg bolts.. does anyone know a boulder-county source for grade 12 bolts?
Old 12-19-2009, 08:57 PM   #93
dirtbound4Max
Hangin' 10 on the F8
dirtbound4Max's Avatar
Oddometer: 334
Grade 12 Bolts in Boulder County Area
New here but have you heard of Adam Hull (Former owner / operator of "Scooters" in CS). He specializes in hard to find items and he now operates out of Greeley. Great guy with great connections...................Sean
dirtbound4Max is offline   Reply With Quote
Old 12-19-2009, 09:01 PM   #94
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,338
Grade 8 is the highest "grade" classification (in U.S. ASTM)...you're probably thinking of metric Class 12.9, equivalent to ANSI 'heat treated alloy steel'. (12.9 comes with the KLR subframe bolt upgrade kit)
IBA #11735 . 1968-present
Blakebird is online now   Reply With Quote
Old 12-19-2009, 10:24 PM   #95
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
Marc
Don't mind if i do!
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 12-20-2009, 05:19 AM   #96
justjarrod
sojourner
justjarrod's Avatar
Oddometer: 1,154
Geek, check this link for the head markings and strengths charts.
http://en.wikipedia.org/wiki/Screw
"Any society that would give up a little liberty for a little security will deserve neither and lose both." -B. Franklin
justjarrod is offline   Reply With Quote
Old 12-20-2009, 06:37 AM   #97
Lomax
Lomax's Avatar
Oddometer: 9,157
Geek,
Last time I was in a Lowe's they had grade 8 and metric bolts. Or I am sure that Ace Hardware would have what you need.
Marc
Old 12-20-2009, 07:13 AM   #98
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
Class 12.9 is what I'm looking for..
The bike is all metric.
Thanks for the link Jarrod.. I'm now smarter than I was 10 minutes ago
Geek screwed with this post 12-20-2009 at 07:19 AM
Old 12-20-2009, 07:27 AM   #99
Lomax
Lomax's Avatar
Oddometer: 9,157
Geek,
I know this is not in Boulder but I have gone here several times when I needed something strange and esoteric.
http://www.aaametric.com/
Marc
Old 12-20-2009, 02:00 PM   #100
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
New ironman sprockets and chain installed...
..now I need to figure out how to get those sheared off foot peg bolts out of the frame
Old 12-20-2009, 02:23 PM   #101
Greg@RME
Mis-Adventurer
Greg@RME's Avatar
Oddometer: 1,258
...now I need to figure out how to get those sheared off foot peg bolts out of the frame
Got a Mig welder, or access to one? My favorite way to remove bolts that have been broken off involves placing a nut over the bolt, (ID of nut should about the same size of the broken bolt) and welding inside the nut, to the broken bolt. The heat helps loosen the threads and you use the nut to turn out the broken bolt.
Just be cautious around the aluminum. If you have enough room, you could use a smaller nut to stay away from the aluminum. It doesn't take much, as long as you get a decent weld between the nut & broken bolt it will turn out.
Greg@RME is online now   Reply With Quote
Old 12-20-2009, 03:31 PM   #102
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,338
I got to ride Marc's Norton briefly, and it is one extremely sweet machine.
I haven't owned a Brit bike with 'non-standard' controls since the mid 70's, but it seems so elemental and natural still - the essence of what motorcycling was when I started in the late 60's.
Old 12-20-2009, 03:35 PM   #103
Lomax
Lomax's Avatar
Oddometer: 9,157
Blake, Ben, Bill, Good to see you all today.
I can see the ride report now. Three killer Bees attacked by the Ozo. And a free cookie.
Marc
Old 12-20-2009, 08:48 PM   #104
Duck_Pilot
Retired Roadracer
Oddometer: 6,026
First steps taken......
I went shopping today, and bought a new compressor with a 20-gallon tank. I also purchased a 15-gallon compressor tank from a craigslist local. Both work just fine. The extra tank not only boosts capacity, but will give me some portable air if needed away from home.
I even took some "before" pics of Suzi-700 to post later on, got her up on the broken centerstand, and made some initial measurements for the carb-swap to follow. Next step: strip her down to the frame, and lug the engine downstairs to my workshop. Then the bodywork goes out for paint, and the fancy Marshall Deep-Tone exhaust gets ordered from Holland.
I've decided that the Ugly Duckling (PE-175) can wait until Suzi is done. The dirty-bike will be easier and cheaper to repair, and I have no plans for what to do with her when I'm done yet, anyway. Since I only need to work 3 days in the next 2 weeks, this'll give me something to do besides housecleaning before Selena arrives next month to visit .
Life goes on........
" A man that can have patience, can have what he will." - Benjamin Franklin
"Man cannot imagine how life could be more difficult or complex. But Congress can." - Cullen Hightower
Honestly, I *do* like Socialists. They just need a little tartar sauce.
Duck_Pilot is offline   Reply With Quote
Old 12-20-2009, 09:02 PM   #105
mommer
bring on the world!!!!
mommer's Avatar
Oddometer: 1,964
i did some winter wrenching this weekend. but it is all for my "winter" ride
new 2" risers
new 908rr of course
wired up the new jacket.. you know just in case
rotopax,, it's gonna be a long way between fillups you know
i also threw in a new facet fuel pump, cuz ive been scared outta the oem 950 mechanical points. and i wired up my gps,, cuz batteries are expensive..
now to pack
just ride it out!
go fast and hang on tight!
spot linky:
http://share.findmespot.com/shared/g...UkefvUtpvQzqzl
mommer is offline   Reply With Quote
Times are GMT -7.   It's 08:48 PM.
