Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 12-08-2012, 01:21 PM   #1066
Merfman
Trustin' my cape...
Merfman's Avatar
Oddometer: 870
Originally Posted by burque magoo View Post
that's a great bike....(I might be a little biased), how many miles, and how much did you pay for it?
Hey Lomax, hell yea, I'll take it. PM inbound...
Burque - it's got a shade under 27,000 miles on it and I paid $650 for it... not sure I got a stellar deal but for what I wanted, it was in the ballpark. I probably could have gotten it a little cheaper but the seller was a AFA grad who's getting married and felt that his MC days were done. I didn't want to add insult to injury...
Merfman is offline   Reply With Quote
Old 12-09-2012, 08:47 AM   #1067
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,565
Seat Concepts Foam & Cover Installation HERE
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 12-09-2012, 06:46 PM   #1068
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,599
Fixed some poor oil-line routing from the factory...
Way to go Polaris, torque that lock nut on there hard enough that trying to loosen it with a socket bends the tab.
Muffpot... check.
Put a constant-tension clamp from McMaster on there, shouldn't come loose as the pipe expands/contracts with heat.
Align-y the skis...
Plumb the exhaust valve solenoid to puke OUTSIDE the sled instead of all over the engine...
Let it snow already.
Spewer of the poignant non sequitur
SnowMule is online now   Reply With Quote
Old 12-11-2012, 04:11 PM   #1069
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,461
I think I need to figure out how to make one of those muffpots work behind the rear cylinder of the 950
Old 12-11-2012, 04:41 PM   #1070
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
From what I hear, it won't help...
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez is offline   Reply With Quote
Old 12-12-2012, 02:12 PM   #1071
2Stamp
2Stamp's Avatar
Oddometer: 373
1400 miles I think. I haven't looked at the odo since I brought it home. Paid $3800 for it, seems about going rate here. And the PO had just put a new Scotts dampener on it.
_______________________________
2011 F800GS
2014 350XCF-W
2006 450EXC
2014 Honda Grom (hers)
2Stamp is offline   Reply With Quote
Old 12-16-2012, 05:17 PM   #1072
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,429
Current projects on 990:
Cannisterectomy (done)
Black dog skid plate
check valves (looked fine)
Flush cooling system
Mounting heated grips
Install additional power outlet
Heavier fork springs
Fresh fork & shock oil
Anti-sneeze rear wheel adjusters
Drain holes in swing arm
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 12-17-2012, 07:06 AM   #1073
rtadlock
rtadlock's Avatar
Oddometer: 1,255
Pretty sure there are already holes to for drainage in the rear swing arm. There's a big rubber plug back there somewhere. Can't miss it.
rtadlock is offline   Reply With Quote
Old 12-17-2012, 07:31 AM   #1074
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,429
Thanks Rob. If it's the one I'm thinking of, the big plastic plug is put in at the factory. A common mod is to drill two small holes on the bottom of the swingarm, at the very back of the hollow section to drain any water that gets past the factory openings.
Old 12-17-2012, 08:34 AM   #1075
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,014
I didin't realize this was an issue. I better check my 950. What do I look for? I better add some antihistimine to my tool kit
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 12-17-2012, 08:38 AM   #1076
TheDudeAbides
Sarcasm free11/11/10
TheDudeAbides's Avatar
Oddometer: 7,889
Here's the low cost mod for KLR owners
Best dualsport mirrors I've ever owned
2001 BMW F650 GS Dakar (Stolen!)
2004 DRZE
2004 BMW 1150 GSA
TheDudeAbides is offline   Reply With Quote
Old 12-17-2012, 08:51 AM   #1077
Hondo
Hondo's Avatar
Oddometer: 9,565
Just take the rear wheel adjusters and apply anti-sieze compound to the threads -
Old 12-17-2012, 01:16 PM   #1078
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,429
Fail! Think of this next time you sneeze in a full faced helmet:
Old 12-17-2012, 05:19 PM   #1079
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Oddometer: 3,014
Originally Posted by Hondo View Post
Just take the rear wheel adjusters and apply antI-sieze sneeze compound to the threads -
Corrected
Old 03-12-2013, 06:31 PM   #1080
grub
Requires Supervision
grub's Avatar
Oddometer: 2,214
Dear Abbey
My right front turn signal bulb blew. I pulled it and put in a new bulb, bulb turns on - doesn't flash. Left signal flashes. Swap left and right bulbs, right flashes, left no flashy. The way I understand things the flasher is single sided and is normally closed when cold and opens when it heats up from resistance. The old bulb and the old one that is still good are stamped 23 watts on the base, my problem is the biggest one I can find is 4 watts. I have been to two bike shops and 3 auto part stores Is there anyway to make the smaller bulb pull more juice or do I have to take the faring apart and try another flasher? These are the little push and turn bulbs about 1/4 to 5/16 in diameter.
Signed
Electrically Inept in Alamosa
'05 KTM 300 EXC - 1996 BMW R1100GS
grub is offline   Reply With Quote
Times are GMT -7.   It's 10:43 PM.
