Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 11-15-2012, 01:06 PM   #1336
cms81586
Oddometer: 247
No quick change...just a stock carrier sprocket. $400 on final drive parts was plenty enough this time around (and for as often as sprockets get changed). Another $170 wouldn't have passed the sniff test with the wife for something I don't need and likely won't use. Hold off on the rivet tool for now...I'm going to wait for the sprocket to come in first. I can always ride the bike to AZ-Twin's place and have the wife follow with the stand in the car since I moved to SV last week and I'm a lot closer. As you mentioned...not necessary...but from what I'm reading a whole lot easier.
Black 08 Duc HYM 1100S, 04 Honda XR650L, Specialized TriCross...
cms81586 is offline   Reply With Quote
Old 11-15-2012, 01:12 PM   #1337
mergatroyd
Loser
Oddometer: 101
No worries. I found that the JT carrier with sprocket ended up being less than any other options (and I wanted different ratios because I have the little engine).
I find I go through chain/sprocket sets like I go through timing belts...
mergatroyd is offline   Reply With Quote
Old 11-15-2012, 02:01 PM   #1338
cms81586
Oddometer: 247
My current sprocket/chain set has 9k miles on it. The chain is toast and the front sprocket is starting to fish hook. The rear looks alright but there is some minor wear and if I'm spending $100+ on a new chain I might as well have new sprockets all the way around as well. The torque must really be a bitch on those parts even with proper lubrication. I have the factory service manual but may need a little assistance doing it the first time so I don't mess anything up...
Old 11-15-2012, 02:11 PM   #1339
mergatroyd
Loser
Oddometer: 101
Is the Hyper chain 520 or 525?
on the little bike I bumped it up to 525 and get a little better life out of it, but usually every 10-12k.
An aluminum rear sprocket will get chewed up about the same time the front does (maybe a little faster).
Old 11-15-2012, 09:36 PM   #1340
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
When you get all your stuff bring it over and we will get it done. I have all the tools we will need. The lift would be nice, but I have a big motorcycle lift like they use at the dealer, however you want to do it.
We can get lightfighter over there to help with the beer. I think it sounds like a fun day. Let me know when you want to do the work. 520-249-5237
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 11-16-2012, 01:56 PM   #1341
cms81586
Oddometer: 247
Will do I'll give you a call and let you know when I get the parts. Thanks!
Old 11-16-2012, 01:57 PM   #1342
cms81586
Oddometer: 247
Originally Posted by mergatroyd View Post
is the hyper chain 520 or 525?
On the little bike i bumped it up to 525 and get a little better life out of it, but usually every 10-12k.
525.
Old 11-17-2012, 07:59 PM   #1343
cms81586
Oddometer: 247
As luck (bad) would have it I seem to have misplaced the front sprocket during the move. Now I have the correct rear sprocket and chain but no front. Arggggghhh!
Old 11-19-2012, 01:23 PM   #1344
cms81586
Oddometer: 247
Crisis resolved. Found it hiding in a box of kitchen stuff (because that's a good place for a sprocket). Any of y'all free some time this next weekend (Fri/Sat/Sun)?
Old 11-19-2012, 04:14 PM   #1345
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
I might be camping next weekend, not sure. I know I work Friday, but not sure about Sat/Sun. You want to work on it Friday evening? I don't have anything going on then.
Old 11-19-2012, 04:34 PM   #1346
cms81586
Oddometer: 247
Pending the wife already having made plans for us...that should work. Anything I'll need to bring tool wise (I'll have the beer covered...what do you prefer by the way...)? Just off the top of my head I know I'll need a largish socket for the front sprocket retaining nut (need to measure it) and a torque wrench that can handle 130 ft/lbs. I already have the rear sprocket nut "tool" and tensioner tool that are specific to the bike.
Old 11-19-2012, 04:39 PM   #1347
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
I have some large Metric sockets, I think 23-26mm, but I will double check when i get home. I have a torque wrench that will do 130. I can't htink of anything else.
Old 11-20-2012, 09:30 AM   #1348
cms81586
Oddometer: 247
Friday evening will work if you're good with it. I'll call you today or tomorrow.
Old 11-25-2012, 11:52 AM   #1349
cms81586
Oddometer: 247
Rob,
Thanks again for the help, time, and hangover. I owe you one....
Chris
Old 11-25-2012, 12:01 PM   #1350
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
You are welcome, any time. We need to go riding one of these days. After camping last night, I now have another hangover.
Times are GMT -7.   It's 03:57 AM.
