Old 06-12-2014, 10:30 PM   #1
Stener OP
Oddometer: 23
800gs, no freeplay in clutch
I have just purchased a 2009 800gs, There is no freeplay in clutch ,there is no adjustment left, I've heard that when the clutch wears it actually tightens the cable.If this is correct then I'm assuming that my clutch needs replacing. Bike has 48000 km on it. Does this sound right? Thanks for any input.
Stener is offline   Reply With Quote
Old 06-12-2014, 11:12 PM   #2
ebrabaek
Oddometer: 4,745
If you have no adjustment left then yes your discs have been worn thin and needs to be replaced.
it is worn this bad....and not slipping in 6'th gear.....?????
Erling
Old 06-13-2014, 03:20 AM   #3
Moptop
Moptop's Avatar
Oddometer: 77
Had the same problem and ended up stranded in the middle of nowhere. Replace it. Also with the 2008-9 model the clutch cable was a little "short". They have since replaced it with a new part no cable. I would do that at the same time.
Moptop is offline   Reply With Quote
Old 06-13-2014, 04:27 AM   #4
JRWooden
Oddometer: 4,256
+1 on other advice...
If you need to buy some time while you get parts and etc.
Some folks have had luck replacing the upper adjusting nut on the cable with a thinner nut (or grinding down stock nut) to get a bit of extra slack.
Be VERY careful when adjusting freeplay - it several folks have broken off the little "arm" on the side cover casting ...
JRWooden screwed with this post 06-13-2014 at 04:32 AM
Old 06-13-2014, 12:24 PM   #5
BillsburgGS
BillsburgGS's Avatar
Oddometer: 312
Yup!
At my 18K service for my 2010 the dealer pointed it out to me. Previously, wehn we put on risers it was very tight and I learned BMW outsources the cables and has sometimes switched OEM suppliers and modestly in length when the supplier changes.
We thought a loner cable (new, longer spec) would work, but I ended up needing a clutch to get back to proper free play..
BillsburgGS is offline   Reply With Quote
Old 06-13-2014, 01:46 PM   #6
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,790
There's some info here:
http://www.advrider.com/forums/showthread.php?t=959542
I hear there may be this Reckless clutch thing available soon that includes plates if you can wait.........
Reckless?
Reclining?
Reclusive?
Elusive?
Erling, what's that again?
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 06-13-2014, 02:11 PM   #7
ebrabaek
Oddometer: 4,745
Reckless?
Reclining?
Reclusive?
Elusive?
Recliner.......
Erling
Old 06-14-2014, 10:54 AM   #8
chris73
Oddometer: 249
Originally Posted by ebrabaek View Post
Recliner.......
So the rekluse will include plates? When the dealer replaced my prematurely fried clutch on warranty, they didn't change the filthy oil. I rode it 500 kms, and checked the freeplay in the morning. Freeplay was gone, and had to adjust it way back. I changed the oil and adjusted it and it is fine now, but I would say half gone, if I had to guess. When it comes time to replace, I may look at the rekluse if it comes with plates.
chris73 is online now   Reply With Quote
Old 06-14-2014, 11:39 AM   #9
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,790
New clutches need to break in. 500 kms or less and all the play is gone on the initial adjustment on every new Twin or new clutch on one. Standard.
Old 06-14-2014, 11:42 AM   #10
ebrabaek
Oddometer: 4,745
Ask me that question in a week or two. Sorry. Not meaning to sound like an a$$. If you can hold out on buying a new one for a week or two, you will have your answer.
Erling
Old 06-14-2014, 02:53 PM   #11
BcDano
One Lucky Dude
BcDano's Avatar
Oddometer: 324
Not meaning to hijack this thread but I have been wondering about my clutch as well. Bike is an 09 and I now have just over 105,000 kms on the clock. Clutch feels fine and when I do the 6th gear test it doesn't seem to slipping.
Question is we are on a World Ride and get really remote at times, do I throw in a new one?
BcDano is offline   Reply With Quote
Old 06-14-2014, 03:09 PM   #12
Jisei
Jisei's Avatar
Oddometer: 36
2010
I had a 2010 which I bought at about 5500km in. Previous owner had the clutch replaced under warranty. I sold the bike at 15000 km and there was no play left in the cable.
Jisei is offline   Reply With Quote
Old 06-14-2014, 03:22 PM   #13
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,790
Nah, take it out of Sara's bike.
Old 06-14-2014, 03:28 PM   #14
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,790
Well, consider how much adjustment you have left, where you are and how hard/ how much to get a new one. Some Countries are more expensive or may take a month to get. If you could arrange to have one available where you plan to be in a month then maybe peace of mind is more important.
I've sent parts to BA before no problem but it took two weeks. I have a new one here in Toronto but again, would take weeks to ship it to you.
Ya know it'll fail at a most inoportune time.....
Old 06-14-2014, 08:09 PM   #15
chris73
Oddometer: 249
That's good to know. My concern was how much I had to adjust it. There isn't much adjustment left before is affects shifting I rekon. It feels very good right now though.
Times are GMT -7.   It's 09:15 AM.
