Old 04-26-2010, 11:47 AM   #16
JoelWisman
JoelWisman's Avatar
Oddometer: 1,353
I agree with your post above Griz, but will add a few things.
Yes the F800GS will compensate for a more free intake and exhaust to a point. It does have an oxygen sensor and a learning fuel map.
Base idle and closed throttle decel are NOT compensated by the F800GS but rather on a fixed fuel map.
All of them pop some on decel and this is much louder with aftermarket exhausts at least partially because the exhaust noises are usually much less muffled.
If power is all that one cares about then lambda (14.7 : 1 by mass) is not what you are looking for, you are looking for a somewhat fuel rich mixture.
This will be helpful to exhaust valves, tend to foul spark plugs, suck from a hydrocarbon and carbon monoxide emissions standpoint, destroy the cat, and reduce fuel economy, but will increase HP slightly
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 04-26-2010, 12:04 PM   #17
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,619
Good to know Joel! Thank you!
Exactly!! Me? I'm looking for 14.7:1.
PAUL BUNYAN FOREST RIDERS MC
2013 KTM 300 XCW
2012 KTM 990 Adventure R
Old 04-26-2010, 07:49 PM   #18
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 1,989
Seems pretty easy to me:
http://www.powercommander.com/powerc...dl=213&yr=2009
Gangplank is offline   Reply With Quote
Old 04-26-2010, 08:41 PM   #19
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 800
Cool2 Don't mess with it
What this bikes needs for higher speed, comfy freeway cruising is a taller six gear, not more BHP. It does just fine in that department. Anyone that doesn't think so should ride a KLR for a couple years
The only thing I'd improve is the jerkiness just off idle, but the bike has enough torque to use second gear in many slow situations, so even that doesn't bother me too much.
Bucko is offline   Reply With Quote
Old 04-26-2010, 08:46 PM   #20
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 1,989
Ever try a PC? On my track bike it's the schitz!
Old 04-27-2010, 09:32 AM   #21
mousitsas
Oddometer: 2,131
If you have an AFR 14.7:1 up on top, then you are heading for a very short engine life. Better try 13:1 .
Old 04-27-2010, 06:56 PM   #22
zumohamr
Oddometer: 24
A pipe and air filter would give these 800s some much needed sound. My old TL1000s was unrideable until i used a fuel controller from yoshimura. No piggyback junk like a fuel commander. Plug it in and adjust fuel settings for each individual cylinder. (90V, a real engine) Take for a ride and repeat until bike is correct. it takes awhile but worth it. Someone could surely make something similar for these BMWs.
zumohamr is offline   Reply With Quote
Old 04-28-2010, 02:45 PM   #23
LukasM
Oddometer: 4,900
+1.
People that think that 14.7 is optimal for anything other than emissions are clearly clueless about engine tuning.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 04-28-2010, 03:12 PM   #24
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,619
Originally Posted by LukasM
+1.
Well, soooooorrry, there Lukas! I guess I'm just fucking clueless then!! I meant that I gravitate more towards the stoi ratio of 14.7:1. I actually found myself achieving the best results on my KLR's with about 14:1 using a lambda sensor and meter kit (http://www.innovatemotorsports.com/products/lc1.php and http://www.innovatemotorsports.com/p...s/g2_gauge.php). I had the exhaust header drilled and a bung welded in for the sensor. It's common knowledge that, of course, stoi 14.7:1 is hardly achievable on any engine that constantly changes RPM and load, like a motorcycle or car engine. Now, that said, on a generator motor or something of similar nature that maintains a constant RPM and load? Hell yeah, you can achieve 14.7:1 safely and effectively.
And btw, 14.7:1 is completely safe. In fact, contradicting such a fact would be disagreeing with decades of hard scientific evidence regarding the internal combustion engine! I'm with Joel on this one, guys. Anyone feeling the need go any richer than 14:1 is looking for spark plug fouling, damage to catalytic convertors, a reduction in fuel economy, etc. But, yeah, you will increase HP slightly.
2013 KTM 300 XCW
Old 04-28-2010, 03:13 PM   #25
LukasM
Oddometer: 4,900
Well, soooooorrry, there Lukas! I guess I'm just fucking clueless then!! I meant that I gravitate more towards the stoi ratio of 14.7:1. I actually found myself achieving the best results on my KLR's with about 13.5:1. Best power and fuel economy. It's common knowledge that, of course, stoi 14.7:1 is hardly achievable on any engine that constantly changes RPM and load.
No offense Griz, but yes, it would appear that you are clueless. I'm far from an expert myself but what you are saying just doesn't make any sense.
I am not sure why "it is common knowledge that 14.7 is hardly achievable", and also why you would even try to tune for that - unless for emission reason as I mentioned above?
A properly tuned engine will target around 12.6 under full load for max power, and then lean out to about 15.4 under light load to cruise economically. With correctly set up EFI this is entirely achievable.
What did you use to tune your KLR then?
Old 04-28-2010, 03:19 PM   #26
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,619
It is hardly achievable for any sustained period of time, due to fuel quality, load, and RPM change.
Click on the links in my above post ^
And read this while you're at it:
http://en.wikipedia.org/wiki/Air-fuel_ratio
2013 KTM 300 XCW
The Griz screwed with this post 04-29-2010 at 09:31 AM Reason: Removed most of the head explody. Kept tuning info.
Old 04-28-2010, 03:27 PM   #27
itsatdm
NoMoTDM still Gary
itsatdm's Avatar
Oddometer: 3,702
Sounds like this is the reason for the the slight stumble, when slowly trying to ease over things just off idle. If it is, than doesn't sound like there is much that can be done about it.
Old 04-28-2010, 04:03 PM   #28
LukasM
Oddometer: 4,900
Way too much editing of your posts going on Griz... Next time just make a new one instead of changing what you said (optimal results with 13.5 or was it 14.0?) and adding stuff 5 times.
So you tuned your KLR with the G2 gauge then? Did you do it on a dyno? Any graphs?
If you are not very well versed in a topic, maybe you shouldn't always make these absolute statements like "And btw, 14.7:1 is completely safe. In fact, contradicting such a fact would be disagreeing with decades of hard scientific evidence regarding the internal combustion engine!". Keep an open mind man.
Whether 14.7 is completely safe depends on a multitude of factors, for example the compression ratio, fuel octane, ignition timing, induction type, etc. I would like to see you run a high compression drag racing engine or even a low compression one with 20 lbs of boost at your "completely safe" 14.7:1 on standard gas. You'd be picking up your pistons in pieces.
In case of a stock F800GS, this is unlikely to be an issue. But then again, if you were going to reprogram your EFI to compensate for the free flowing exhaust, air filter, etc why not make it optimal instead of just safe? You know, like, rich at full load and lean for cruising? More power and still get better mileage?
Old 04-28-2010, 04:40 PM   #29
upweekis
upweekis's Avatar
Oddometer: 1,892
I read somewhere that a guy is making a new throttle roller(gear, whatever the part is on the handlebar grip) that is cammed, so that at less than 1/3 throttle, it moves slower, and then picks up to normal after that. I think that would cure a lot of off-road problems. Of course, I can't find it now...
John Nail
2012 XT1200z (the Dark Ronin)
2008 XT250
1994 XR650L
upweekis is offline   Reply With Quote
Old 04-28-2010, 04:44 PM   #30
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,486
johngil is online now   Reply With Quote
Times are GMT -7.   It's 06:28 AM.
