Go Back   ADVrider > Riding > Regional Forums > Northeast - Greater Flugistan and home of the carpet baggers.
Old 11-16-2012, 09:20 AM   #10201
TowPro
Lets ride
Oddometer: 3,298
Originally Posted by rockinrog View Post
I am not exactly sure how to tell. It makes the normal noise I am used to hearing when you turn the key on, but not sure thats the fuel pump.
I just went out and listened to mine. When I first turned on the key I didn't hear anything but that noise the spedometer makes when it does the test sweep.
But then I opened up the gas cap, put key in ignition, turned it to on and I could hear a motor run under the seat for around 1/4 second. I guess that is the fuel pump putting pressure into the injection system?
But when I left key on, and turned kill switch on and off I did not hear that motor run.
TowPro is offline   Reply With Quote
Old 11-16-2012, 09:22 AM   #10202
rockinrog
rockinrog's Avatar
Oddometer: 2,953
I think the pump is still working, because if I turn the throttle while I am cranking it over it seems to speed up. If the pump isn't working I would think turning the throttle wouldn't do anything?
rockinrog is offline   Reply With Quote
Old 11-16-2012, 09:30 AM   #10203
GrimeTime
GrimeTime's Avatar
Oddometer: 184
You checked the kill switch right?
http://www.BubblerGPS.com
GrimeTime is offline   Reply With Quote
Old 11-16-2012, 10:21 AM   #10204
Mark_O
Drain Bamaged
Mark_O's Avatar
Oddometer: 17,459
You're supposed to wait until he's tried everything else before you mention that.
Sarcasm, just one more free service I provide.
Mark_O is offline   Reply With Quote
Old 11-16-2012, 10:53 AM   #10205
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 6,179
Sidestand or clutch interlock switch.
Jeff B is offline   Reply With Quote
Old 11-16-2012, 11:07 AM   #10206
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 6,179
Diagnosic tool to check them..............
Old 11-16-2012, 11:15 AM   #10207
rockinrog
rockinrog's Avatar
Oddometer: 2,953
Yes, checked it.
Old 11-16-2012, 11:55 AM   #10208
GrimeTime
GrimeTime's Avatar
Oddometer: 184
Been there, done that. Same symptoms.
Old 11-16-2012, 12:05 PM   #10209
rockinrog
rockinrog's Avatar
Oddometer: 2,953
I was thinking it wouldn't even crank if the side stand was down..but I could be wrong... will check after work..thx for the suggestions guys.
edit.. thats if you put it in gear with side stand down.
Old 11-16-2012, 12:14 PM   #10210
Mark_O
Drain Bamaged
Mark_O's Avatar
Oddometer: 17,459
Your point escapes me.
Old 11-16-2012, 12:15 PM   #10211
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,667
He had the asshat part right.
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 11-16-2012, 12:19 PM   #10212
Mark_O
Drain Bamaged
Mark_O's Avatar
Oddometer: 17,459
Shhush you.
Old 11-16-2012, 12:20 PM   #10213
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,388
Almost shot some chicken salad out my nose.
Laconic is online now   Reply With Quote
Old 11-16-2012, 01:31 PM   #10214
LadyDraco
KillerSmileIHazIt !!
LadyDraco's Avatar
Oddometer: 30,030
Battery...??
My black would turn crank but NOT kick over ...
Put a new battery in and Voom....
Just saying ..
TISE
Life is what you make of it~If it don't fit make alterations
Check it from time to time as I'm always adding to it..
My Rides and life on the Farm
Just because the road is rocky doesn't mean your spirits should get rocky, too.{Crazy Cora}
LadyDraco is offline   Reply With Quote
Old 11-16-2012, 01:40 PM   #10215
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,856
The bike just shut off. It will crank, but not fire.
Are you out of fuel?
2006 Tdub
2006 Wee
DingDangKid is offline   Reply With Quote
Times are GMT -7.   It's 04:51 PM.
