Old 02-25-2013, 04:06 PM   #13501
BroncoDave
BroncoDave's Avatar
Oddometer: 4,456
Need advice from the experts.....again... I balanced my first tire today...and was wondering if better to put weights in both sides of rim or just one side? Previously it only had weights on one side when done by dealer.
BroncoDave is offline   Reply With Quote
Old 02-25-2013, 04:13 PM   #13502
beantop
Remember, Safty Forced
beantop's Avatar
Oddometer: 4,231
What kinda wheel are you doing (spoked or Mag), Do you have room down the center of the wheel..
I Use the stickey back weights and run them right down the center...
This keeps any rocks,boulders,twiggs,loggz or the occasional wildlife from jumping out and ripping them off easilly...
http://www.harborfreight.com/catalog...=wheel+weights
Dan B.
Thanx for your Tyme, Have a Great Day
'00 KTM 640 LC4(yugo) '05 BMW R1200GS(cadillac)
Hi Connie
Peaceful Valley MY ASS (Eddie Bolted)
beantop is offline   Reply With Quote
Old 02-25-2013, 04:15 PM   #13503
BroncoDave
BroncoDave's Avatar
Oddometer: 4,456
I can't put them I the center
Old 02-25-2013, 04:16 PM   #13504
tommu56
tommu56's Avatar
Oddometer: 1,375
Originally Posted by DenniSMC View Post
I must have the shoes!!!!!
bacon flipflop
tommu56 is offline   Reply With Quote
Old 02-25-2013, 04:19 PM   #13505
tommu56
tommu56's Avatar
Oddometer: 1,375
Spokes = wrap solder around them at the nut!
The KLR way!!!!!
Yamaha in this case.
Old 02-25-2013, 04:20 PM   #13506
scootac
Just a Traveler
scootac's Avatar
Oddometer: 3,145
Originally Posted by madmaximum View Post
68 miles.
On YOUR peddle bike?
The world is a book, those who don't travel, read but a single page
'81 R100RT, '04 ST 1300, '02 DR 650
scootac is online now   Reply With Quote
Old 02-25-2013, 04:32 PM   #13507
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,296
Haven't balanced a tire yet.
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 02-25-2013, 04:45 PM   #13508
beantop
beantop's Avatar
Oddometer: 4,231
That would be the easiest way to do it....
Just put it on and don't worry about it unless it rattles your bike to pieces.
I usually balance my tires (only cause I have acces to a fancy dancy balance machine) , But I've also just mounted the tire and put it on with no problems...
I asume your using a mag wheel with a rib in the center, Just use the stick on weights and put them on the flats any where on the wheel (where it's needed), I just try to put them in the center to keep them outa harms way...
Dan B.
Hi Connie
Old 02-25-2013, 04:47 PM   #13509
rockinrog
rockinrog's Avatar
Oddometer: 2,907
I use dyna beads never had an issue with vibrations etc.
rockinrog is offline   Reply With Quote
Old 02-25-2013, 04:47 PM   #13510
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 5,928
I'm w/Dan on this one. They come from the molds in pretty good balance anymore.
I run them after mounting and if they happen to be out of balance I throw in Dynabeads. Most of the time they need nothing.
Jeff B is offline   Reply With Quote
Old 02-25-2013, 04:50 PM   #13511
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 5,928
I should also mention that I recycle the Dynabeads. I harvest them out of a tire w/a spray can lid.
Old 02-25-2013, 04:53 PM   #13512
enduro0125
enduro0125's Avatar
Oddometer: 14,296
Most tires have a dot on the sidewall signifying the heavy spot.
I put that where my valve stem is,no wobbles,no worries.
AMA 487807A
Old 02-25-2013, 05:05 PM   #13513
LadyDraco
KillerSmileIHazIt !!
LadyDraco's Avatar
Oddometer: 29,954
I use Ride-On.. It balances and helps to prevent flats ..And keeps the tire cooler..
Knock on wood I have NEVER had a flat in 200K miles...
I have been using it since 2002...
Avon doesn't put that dot on their tires ..
TISE
Life is what you make of it~If it don't fit make alterations
Check it from time to time as I'm always adding to it..
My Rides and life on the Farm
Just because the road is rocky doesn't mean your spirits should get rocky, too.{Crazy Cora}
LadyDraco is offline   Reply With Quote
Old 02-25-2013, 05:08 PM   #13514
enduro0125
enduro0125's Avatar
Oddometer: 14,296
That's why I said "most".
AMA 487807A
Old 02-25-2013, 05:11 PM   #13515
LadyDraco
LadyDraco's Avatar
Oddometer: 29,954
I know ... I was just making it a good point .. Avon doesn't do that..
As I had looked one time for a while ..
And I can only find the ware-bar markers..
TISE
Times are GMT -7.   It's 07:56 AM.
