Old 12-21-2009, 12:42 AM   #1
crowflies OP
Oddometer: 1
r100gs: mikuni carbs swapped in for the 32mm bings?
just wondering if there is anyone out there who has successfully replaced their stock bings with an aftermarket carb. my carbs are a mess on the bike i'm (almost done!) building, and i'm thinking it might be easier and better and maybe even cheaper to replace them rather than rebuild them. anyone use mikuni flat slides on their airhead? would love to hear about the details of the swap. and the jetting i'm running a supertrapp full stainless, motor is stock.
crowflies is offline   Reply With Quote
Old 12-21-2009, 05:26 AM   #2
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
do a search for mikuni in this thread. You'll find plenty. Stan at Rocky Point makes a prejetted kit with intake boots and pre-made cables. A no-brainer 10 minute bolt up.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 12-21-2009, 09:32 AM   #3
mykill
odd
mykill's Avatar
Oddometer: 1,166
Flatslides will be very abrupt in their power delivery and setting up can be a challenge. Not sure if they are a good fit for a stock engine. VM's are fine but even pre-jetted carbs can use some tweaking, that is where the obsession begins.
How do you want to use the bike?
For all around riding and traveling I'm a Bing fan. Mikunis work well but the bike loses some of its sweetness. Bings seem to have a lot of jetting latitude and are very forgiving.
Raised compression, head porting, cam, lightened flywheel and flatslides will make a snarling beast (relatively) that you will never be able to realax on.
Personal preference!
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 12-21-2009, 01:19 PM   #4
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
What he said, very well put and right on the mark.
NO such thing as a pre jetted kit that works for everyone.
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 12-21-2009, 04:38 PM   #5
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,509
The other option is all of the parts from a European R100GS. They ran 40mm Bings with the same cylinder heads. Works amazing.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 12-21-2009, 09:13 PM   #6
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Yeah, and I can still get the manifolds right from BMW at a reasonable price.
Robert
www.wirewerkes.com
Old 12-22-2009, 07:04 AM   #7
mykill
odd
mykill's Avatar
Oddometer: 1,166
+1
Old 12-22-2009, 01:16 PM   #8
walkingbear
walkingbear's Avatar
Oddometer: 3,582
40mm bings on 32 heads.
ok, I don't get it . It's more gas than it can burn? My understanding
that you needed bigger heads to handle the 40carbs.
Educate me!
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 12-22-2009, 02:03 PM   #9
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Educate me!
I think (correct me if i'm way off here) that the 40mm carbs still only provide as much fuel as the motor needs depending on how you treat the throttle. The difference is that they have the potential to deliver more fuel when you really want it.
datchew is offline   Reply With Quote
Old 12-22-2009, 02:40 PM   #10
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,824
The principle behind the CV carbs (constant velocity) is that the slide/needle rises, based on the pressure differences ("vacuum") of the air running through it, which is governed by the throttle plate, which is what is actually moved by your right hand. The CV's are in fact quite forgiving of things such as altitude (i.e. variations in air density), used in a wide variety of conditions on a wide variety of bikes....
The air volume that is drawn into the combustion chamber is based on two things (to put it in simple terms): the swept volume (cc's / displacement) and the speed of the engine. So yes, the CV's will "adapt" by opening the slide further for a higher displacement engine. The biggest difference between the 32mm and the 40mm Bing CV's is really only at high throttle/high speeds, when the 40mm opening can physically pass more air. The total available area of the 40mm is not being used until the slide is raised up by high engine speeds and high power demand ("as needed" by the air pressure differential. Carb theory is that a smaller carb does a better job for torque and low rpm's, the larger carbs give the high-end horsepower.
If you look at the history of the BMW's with Bing CV's, you will find that the 32mm was used for the R65, the R75, the R80 and even the R100.... quite a range of displacements. Of course they are jetted differently, and there are some minor variations of the carbs over the years, but I think it says volumes about the use-ability of the type.
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 12-22-2009, 03:08 PM   #11
walkingbear
Oddometer: 3,582
tic for tack or torque for hp
Then, the advantages of using a 40mm carb is for the avail extra potential horsepower at the high end of the RPM range. What you might lose is the greater torque value at the low / mid range.
Old 12-23-2009, 07:23 AM   #12
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
Great post. I guess it depends a lot on what speed you tend to run your engine. I try to keep mine in the 3500-4500 range whenever possible. I almost never really rev it up so based on your comments above I would not benefit from bigger carbs.
Back in the day with muscle cars I had a Mopar with a 340 ci in it. I put a mid-sized Holley 540 (IIRC) on it. Friends with basically the same motor were putting much larger carbs on there. Their cars did not appear to be faster so I never understood the appeal. IMHO, bigger is not always better.
t.
Infracaninophile is offline   Reply With Quote
Old 12-23-2009, 05:06 PM   #13
walkingbear
Oddometer: 3,582
40's on small heads
I spoke to my mechanic who trained in Germany.
He said that 40's in europe ran on big heads not small heads
Old 12-23-2009, 05:33 PM   #14
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,521
as asked above, correct me if i am mistaken but dont the smaller bore carbs help the torque in the lower rpm range and you give some of that up by going to the bigger bore carb which may help the top rpm range.
bigger bore carb = top range of rpm power
smaller bore carb = lower range rpm torque
ChromeSux is offline   Reply With Quote
Old 12-24-2009, 09:25 AM   #15
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
I don't think so... I believe US and Euro models ran on the same heads.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Times are GMT -7.   It's 03:20 PM.
