Old 07-04-2012, 06:57 PM   #166
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,343
I posted earlier in this massive thread and now using Permatex ultra black for the last 32,000. miles every time the cover comes off and back no there are no leaks. BMW should just figure it out and place some oil resistant gasket sealant on each side of the gasket and rest assured no oil leaks.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 07-04-2012, 06:59 PM   #167
JRWooden
Oddometer: 4,249
Indy:
Have you ever used Hylomar for valve covers?
Old 07-04-2012, 08:03 PM   #168
Indy Unlimited
Oddometer: 1,343
Yes and it fails due to the tight clearances required. Hylomar is great up to 0.0010" and that is why it is used in aerospace industry where clearances and machine tolerances are very tight.
I have seen it fail on my Husky water pump and cam cover. I went back to Permatex and never has it let me down.
Current Stable:
Old 07-04-2012, 08:06 PM   #169
JRWooden
Oddometer: 4,249
Thanks ... Ultra-black it is ...
I was hoping Hylomar would work as it would make reusing the gasket set a lot easier... but ... oh well....
Old 07-04-2012, 08:18 PM   #170
Snowy
Oddometer: 1,733
I take it Indy, that you are referring to this type of Permatex:
If so, I've used it for as long as it's available here, going back a couple of years at least. The Ultra Copper I carry in my tool kit for incidents like my "hole in the engine cases" on my DR 650, where I need to pull cases off track side and get it all to seal first go for a run back to my workshop. The last lot, a month ago, I had to redo the clutch side cover on the DR in the pissing rain on the side of a mountain at near zero degrees C after removing it and patching up a hole. Hasn't leaked a drop.
I clean the surfaces with a rag dipped in the fuel tank. I put a good bead on, and let it go tacky so it doesn't stick to my finger, then reassemble.
The Ultra Copper is rated high temp, I've used it on muffler joints with good success.
They also make some good metal putty.
It comes in handy.
Snowy is offline   Reply With Quote
Old 07-04-2012, 08:47 PM   #171
JRWooden
Oddometer: 4,249
I think Indy meant this stuff:
http://www.permatex.com/products/Aut...sket_Maker.htm
I'm a bit worried I'll not get things re-assembled before it starts to set up which was the other reason i was hoping to use Hylomar... but ...... sigh........
Old 07-05-2012, 05:03 AM   #172
Snowy
Oddometer: 1,733
I've used the Ultra Black as well. It has a pretty good ...whatever they call that time between coming out of the tube and going too hard to work.....time.
As my dear old Dad used to say....it sticks like shit to a blanket.
I had a tube of that handy when I did the DR cam chain tensioner gasket a few weeks back. Worked perfect.
Edit: it seems like every tool box I open in the garage has a different type of gasket sealer in it. It's a big garage. It took me 3 days to find the silver solder and flux I had for the bathroom pipe repairs. Now I can't find the blow torch.
Old 07-05-2012, 09:15 AM   #173
JRWooden
Oddometer: 4,249
I have the same problem in my garage ... except my garage is not that big....
Old 07-05-2012, 10:35 AM   #174
Indy Unlimited
Oddometer: 1,343
That is the stuff! Ultra Black is rated to 500F and has never let me down on any of my engines - No oil leaks ever period!
Current Stable:
Old 07-05-2012, 11:25 AM   #175
JRWooden
Oddometer: 4,249
But on balance ... the Ultracoper is rated to 700F (intermittant...)
Old 07-05-2012, 12:14 PM   #176
Indy Unlimited
Oddometer: 1,343
Copper is better for high pressure head gaskets and not for cam cover gaskets. In my experience.
Current Stable:
Old 07-05-2012, 02:09 PM   #177
JRWooden
Oddometer: 4,249
Thanks Indy!
Ultra-Black it is !...
Old 03-29-2013, 01:06 PM   #178
tah1800
tah1800's Avatar
Oddometer: 280
Gasket
Getting mine out of the shop today. Replacing both leaking valve cover gasket and water pump at 14K mi. under warranty.
tah1800 is offline   Reply With Quote
Old 06-08-2013, 10:43 AM   #179
Bumbobee
Bumbobee's Avatar
Oddometer: 137
Has the issue been fixed on the 2013 models or still ongoing problem?
2013 BMW F800GS
Bumbobee is offline   Reply With Quote
Old 02-24-2014, 09:58 PM   #180
lepoer
Oddometer: 18
Had the gasket problem before on my '09 F8GS. Can't remember the mileage. Now at 26k miles and there it is again. Not happy. Requested a service appt. this better be a warranty item.
Bernadette, '09 F800GS. Jesse Odyssey II bags. Givi engine guards. Sargent Touring seat. Twalcom wind deflector. Stebel Nautilus compact horn (Can you hear me now!?). Kaoko throttle lock. PIAA Cross County Auxiliary lights. TT HID Compact 2 Headlamp, Best Rest Headlight protector & Aux light mount. Metal mule radiator guard. Altrider skid plate.
lepoer is offline   Reply With Quote
Times are GMT -7.   It's 05:35 AM.
