Old 05-21-2010, 06:28 PM   #76
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,175
Originally Posted by BMWHillbilly
Your dealer said this? Affecting the F650gs only?
He's in Turkey. Don't hold your breath for a recall here.
-Scott-
Semper Fi
'04 BMW R1150GSA, '08 KTM 450EXC-R, '04 KTM 625 SXC
"A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
YetiGS is offline   Reply With Quote
Old 05-21-2010, 11:36 PM   #77
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,389
Guys, i have an 800ST and this is a common problem with the Rotax engines...I'm ready to take mine in for a 2nd gasket reinstall and I'm at 8000 miles. Some on the F800riders.org board have had as many as 5 of them installed. Apparently the answer is to use a LOT of gasket sealant during the install, but techs don't like customers telling them how to do their job...and since in my area they don't work on a lot of F800s I don't think they've figured it out.
EJ_92606 is offline   Reply With Quote
Old 05-22-2010, 08:25 AM   #78
JoelWisman
JoelWisman's Avatar
Oddometer: 1,353
Oh contrare. I love it when a customer tells me how to fix their bike, especially if they are right.
That's one of the reason I read a lot here, I have learned more then a few things from collective experance of fellow adventure riders.
And if a customer tells me what to do but is wrong, well, that doesent bother me either. I'm wrong sometimes too, it happens.
Firstly, the ST has a slightly different engine. Cylinder bank angle, water pump cover, and finish are some of the differences, but there are others as well, including the valve cover.
Now I will admit, slipping RTV silicone everywhere will often hide the symptoms of what is wrong for a long time, but I submit, trying to glue the cover on to cover for the real cause of the leak is not the best solution.
Even if a customer is ok with the apperance of rtv that glops out of the gasket, making for a sloppy looking job, some of thar rtv glops into the motor as well.
Over time the rtv that glops into the engine from "using a lot of rtv" will break off and travel to basket and pickup screens, possibly plugging them.
Now let's put our thinking caps on for a moment.
Some bikes have leaked repeatedly.
Others, mine included, have never leaked.
Bikes that have never leaked, tend to continue to not leak after techs do a valve clearance check, which the cover has to be removed for.
Techs are trained to apply a small amount of rtv to only the left side of the cover near the cut outs. Most techs probbably do like they are trained.
When a valve cover is removed and reinstalled by a tech, it usually does not leak.
I see hundreds of F800 and F650GS's. Most have never leaked oil out the valve cover gasket, and continue to NOT leak after one of our techs r&r's the cover and uses a small amount of rtv.
So to my logic, if a small amount of rtv nearly always does the job again and again, I find it illogical that some bikes would require "a lot" of rtv unless something is different on the repeat leaker bikes.
What is defferent that causes some bikes to leak repeatedly is likely one of the following:
the gasket is defective. Yes we normally reuse the same rubber gasket and it works fine, but if the gasket is defective it needs to be replaced.
The valve cover is defective. It is warped or there is some other casting flaw, perhaps the deminsions are wrong.
The head is not flat. This would be surprising but it is possible.
The shoulder bolts that hold the cover down are streched or made wrong.
The top hat washers are the wrong shape.
The rubber washers under the top hats are defective.
There is excessive crankcase pressure from an internal engine or breather problem.
The factory screwed up some how and now a tech keeps screwing up somehow causing repeated leaks.
That's all the possible causes I can think of, there could also be others.
What can't be the cause is the abscence of "a lot" of rtv, otherwise all of them would leak and most never do.
But if you come into my shop and demand that I use a lot of rtv on your valve cover to mask the real problem, I will cheerfully do just that as long as you sign off on the service record I generate noting why I am about to use a lot of rtv and risk clogging up your oil pickup screen and baskets some day.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 05-30-2010, 07:56 PM   #79
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,567
Send a message via MSN to v8toilet
Had my first valve cover gasket replaced around 1000 miles ago. I'm ready for another.... already...
v8toilet is online now   Reply With Quote
Old 05-30-2010, 11:39 PM   #80
RAD800
RAD800's Avatar
Oddometer: 886
Send a message via MSN to RAD800
Got mine back from the yamaha dealer, he's 90% sure they were doing it wrong at BMW. He said there was nothing wrong they just had zero RTV anywhere. After a few calls to a few BMW mechanics he's got it sorted... hopefully for the last time.
RAD800 is offline   Reply With Quote
Old 05-31-2010, 03:59 AM   #81
GB
Mod Squad
GB's Avatar
Oddometer: 53,454
Mine went in for a gasket change and the dealer is very sure it will leak again. I talked to the tech and he says the bottom of the gasket has ridges on it and that's where it leaks from, even though he put a silicone sealer of sorts under it, the tech thinks it will leak again, until bmw changes the design of the gasket..
Mine started leaking around 10,000 km.
This is really a sad state of affairs when they can't make something this simple leak proof. My buddy's 800ST leaks also.
Old 05-31-2010, 04:11 AM   #82
Sydney Rider
Oddometer: 362
Howdy,
Well now that mine has been repaired twice before the end of my warranty I think that I have a case for claiming the repair of this issue during the rest of the time that I own the bike - it will be my argument that the need to redo the original 'warranty repair' constitutes an acceptance of behalf of the manufacturer that the part was faulty from manufacture and therefore until the problem is fully resolved the manufacturer will continue to endeavor to resolve the issue.
Whether this works or not is another story but I will be checking the relevant regulations later in the week to see if I have a case.
Tony
Life, live it like you stole it.
Sydney Rider is offline   Reply With Quote
Old 05-31-2010, 06:47 AM   #83
GB
Mod Squad
GB's Avatar
Oddometer: 53,454
I don't know if this makes any sense, but the tech who worked on my bike said that the gasket is shaped like this at the top: /\ (upside down v) and is flat at the bottom with channels. He thinks the leaking happens from the bottom of the gasket. I looked at my engine yesterday and saw more oil coming out of the front left area.. I'm about 80% sure this is a new leak, so I wiped it all clean and will watch it.
It would help us all in this thread if you mention the mileage of your bike when the leak around the valve cover gasket developed. Just edit your post if you need to.
Old 05-31-2010, 08:26 AM   #84
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,175
'09 started leaking at around 9,600 miles.
It's just a seep, but it's enough that if I don't wipe it every other day or so it's going to make a mess of the engine. I'll have it fixed, crosses fingers, when they do the 12k mile service.
-Scott-
Semper Fi
Old 05-31-2010, 09:34 AM   #85
Eurastus
Hej på dej!!
Eurastus's Avatar
Oddometer: 344
I've got an '09. Started leaking at 5000 miles. The local BMW service shop slapped on some white goop at the 6000 mile service. Not a drop since. Curiously, the left side engine housing covering the clutch also started leaking in the same manner at the same time. Same white goop seems to have cured that as well.
Hej på dej!!
Blog: Eurastus travels slowly
Eurastus is online now   Reply With Quote
Old 05-31-2010, 01:32 PM   #86
v8toilet
v8toilet's Avatar
Oddometer: 1,567
Mine has the white goop after replacement and is leaking...
Old 05-31-2010, 10:25 PM   #87
RAD800
RAD800's Avatar
Oddometer: 886
mine started at about 5000k's ive got 36K on it now.
Sydney rider, ive had this discussion with a few people at the same shop and they all said the same thing. If it has been a problem for a while it will be coverd under their "good will"? warranty. I'll put it to the test soon enough i guess.
Old 05-31-2010, 10:28 PM   #88
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,120
So RAD800 who was this "Yamaha Shop"? - might try them myself.
Ducksbane is offline   Reply With Quote
Old 06-01-2010, 12:26 AM   #89
RAD800
RAD800's Avatar
Oddometer: 886
They bought out sea side and are in river street, felt strange pulling up out the back of a yamaha dealership but their mechanic is ace and he's BMW qualified.
EDIT: Don't know their no. but they've diverted all seasides phones if it helps.
RAD800 screwed with this post 06-01-2010 at 12:31 AM
Old 06-01-2010, 05:07 PM   #90
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 243
Mine did not leak any oil until the 12k mile service when the dealer checked the valves and replaced the gasket.
I can see that it is weeping a little. I am at 16.5k now and I will keep an eye on it and see about getting it replaced if it worsens or until the 18k mile service.
mapuda is offline   Reply With Quote
Times are GMT -7.   It's 09:42 AM.
