12-27-2009, 01:36 PM
#1 |
on a mission...
Oddometer: 837
We're going to put the newest info up front here too so you don't have to dig into the whole thread. In the thread you'll still find all the development and all the different setups inmates have done with our parts...Thanks!
New for 2013 we've done some improvements to both our BMW F800/F700/F650 GS Skid Plate and Top Rack: ![]() ![]() MOD BMW F800/F700/F650 GS V3 Skid Plate Some pics of what the NEW V3 skid plate looks like now with added vents underneath: ![]() As mentioned above we put them there just so some air can be drawn up from underneath in very slow technical riding. They are in a spot that is well supported by the mounting inserts. We wanted to add them without compromising the strength underneath. from the outside up close: ![]() from the inside up close: ![]() notice our skid plates are welded inside and out! and the up close shot of our CNC machined mounting inserts: ![]() There are a few reasons we use them because they are far more $$ than the alternatives. ![]() 1. They fully support the material around them making that area stronger than just having a hole cut through it. 2. They also make the entire unit stronger as it's fully supported all 'round. 3. We can run a longer weld, strengthening the attachment points. 4. The depth is accurate so we can have our skid plate have the most ground clearance possible, still completely protect the hardware and have a smooth sliding surface to get over something if need be. Here's the new bracket in the foreground compared to the previous one: ![]() It's significantly stronger and also has other improvements :-1.5x the surface area of the previous one to give excellent resistance from the skid plate moving any direction. It's both taller and wider. -The front face is obviously very thick and the big reason for that is we have maximized the thread depth to 12mm. The threads are also rolled and not cut so they are stronger. Since the bracket is CNC'd alu it's still only 93g (3.3 oz). -The front hardware has been bumped up to M8 from the previous M6. The 5mm allen head is also more user friendly because it's less likely to strip out and it's also a much stronger interface that you can apply more torque to. The M8 bolts are fit perfectly through the skid plate holes and with the increased torque will offer an attachment that will reduce the likely hood of any movement of the skid plate. -The attachment arms are taller and even a little shorter that the previous version for max strength -It works with all previous versions of our skid plates without any modifications to the skid plate We always keep existing owners in mind! A few more pics: ![]() ![]() Some more pics of the (V2) skid plate in it's entirety: ![]() ![]() A few of the design details: -Offers complete protection for the oil filter, oil cooler, oil lines, catalytic converter at the back and as much protection on the sides as possible while still fitting with a wide variety of engine bars listed below. -Smooth underbelly to get over obstacles with CNC machined alloy countersunk mounts to protect the mounting hardware underneath and give the skid plate support while preserving as much ground clearance as possible -low angle of attack at the front makes it easier to get over something tall if need be -welded inside and out -optional front mounted tool box that sits high enough to be out of the way: http://advrider.com/forums/showthread.php?t=750749 Fits with these engine bars: -Adventure Spec (G-it) -Alt-Rider -BMW -Givi -Hepco + Becker -Holan & Holan Pro -Metal Mule -SW-Motech -Touratech -Wild @ Heart MOD BMW F800/F700/F650 GS Top Rack The reason we came out with a top rack was to provide as many features and options to the rider. In that vein ours has: -2 brands of fuel cell compatibility -3 brands of different top box options and two DIY ones -many slots and cut-outs for maximum soft bag anchoring options -excellent Giant Loop Great Basin compatibility giving forward and mid mounting options -quick release "key-hole" mounting slot allowing for quick and easy hardware swaps without removing the bolts and spacers every time -forward solo and rearward two up mounting positions to optimize load distribution Here's what the 2013 version of the Top Rack looks like: ![]() We've refined the perimeter shape to follow the shape of the saddle and simplified the rear Givi/Kappa/SW-Motech mounting point. We also added a "lengthwise" Rotopax mounting point in the centre to work with the new Giant Loop Siskiyou panniers and give yet another option. Here are some of the options mounted (shown on previous generations): ![]() Rotopax fuel cell mount bolt directly to the top rack. We've since added a 90* mounting option too, partially to optimize its fitting with the Giant Loop Siskiyou panniers. ![]() This also gives you the option of mounting a 1 gal. or 2 gal. Rotopax either length-wise or width-wise. Here it is with the Giant Loop Siskiyou: This is with the Top Rack in the rearward position and you have access to the fuel fill. ![]() You can also side mount a 1 gal. Rotopax on the right side using their L bracket and vertically top mount a 1 gal. Rotopax on top again using their L bracket. Kolpin's Jr Fuel cell mount will also fit on our Top Rack. ![]() Slots are still accessible with a 1 gal. Rotopax mounted ![]() Side mounted Rotopax works particularly well with the Giant Loop Great Basin. ![]() Givi/Kappa Monokey mounting (Top Rack forward position). You can buy their mounting kit and bolt on any Monokey top case! ![]() SW-Motech Steel Pelican Top Box adapter. Again this option bolts right on as does their Trax top box mounts. ![]() With Pelican case mounted. ![]() Caribou's QFS (DIY) system mounted. Once again the mounting point are in the Top Rack but you do have to customize your top box. An excellent affordable way to have multiple sized top boxes. ![]() Large box mounted (Top Rack in forward position). ![]() smaller top box ![]() inside showing the Dzus quarter turn qr fasteners. Not shown is our simple KISS system. Using the square holes and 1/4" carriage bolts with plastic hand nuts and a couple of washers from the hardware store you can mount any Pelican type top box easily, securely and inexpensively! We also offer specific spacer kit to fit all side racks. ![]() The fit list: Standard Spacers (2nd and 3rd from left) -stock handles -BMW Varios -BMW Alu. box side racks -Touratech -SW-Motech -Holan -Metal Mule (no front spacers required) H Spacers (far right) These substitute the standard front ones and are used with the standard rear ones -Happy Trail -Wolfman/ Backroads Moto J spacers (second from right) These substitute the standard rear ones and are used with the standard front ones -Jesse C Spacers (far left) No front spacers are required, however longer bolts are required for the front and rear. -Hepco + Becker -Caribou (using Hepco+Becker racks at this time) Last but certainly not least all out Top Racks are fully CNC machined and therefore the perimeter and every slot and cutout is chamfered to prevent any straps from getting chafed or cut and we use a lightle textured powder coat to give some grip to help prevent soft bags from sliding as much. ![]() I'm very happy to say that our parts are being used and abused by inmates everywhere in the world and we have many positive reviews! Thanks for checking it out and now back to the original beginning of the development thread! Further to my post a year?! ago I am looking for owners of F800/F650 GS's with SW Motech or Holan engine bars to try a new proto of the skid plate with. Actually I am looking to try with any engine bars bar except Touratech, BMW and Givi and hopefully with a somewhat close proximity to Vancouver, BC. ![]() Also here are a few pics of a top rack proto that has some unique features that I would like to get some feedback on. We are just running it through testing now. It's got three different ways to carry fuel using Rotopaxs' proven fuel packs and mounts. It's all set to have the mounts bolted right to it. It also has a 2" fore and aft adjustment option for riding solo or two-up. There's more info on the site at www.motooverland.com in case you are interested to see more details. Any thoughts? ![]() ![]() Thanks! Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes & Giant Loop for Canada www.motooverland.com toowheels screwed with this post 05-08-2013 at 10:47 AM |
12-27-2009, 01:39 PM
#2 |
Oddometer: 877
wow. that's the best top rack I've seen so far!!
www.adventuredecals.com |
12-27-2009, 01:56 PM
#3 |
Drunken Squirrel
Oddometer: 2,587
Me likey!
If you can fit a Giant Loop Great Basin bag on there with the fuel cans (looks like it would be close) that would be awesome! Edit: Let me know if it is for sale, I am looking for a replacement for the vario rack my bike came with (got it used and I don't have the bags (nor do I want them)). |
12-27-2009, 06:02 PM
#4 |
11th Assassin
Oddometer: 248
Looks great! I am looking around at some options now and your set up is looking like a winner. I really like that Rotopax set-up, if you guys could fit your skid plate to the Holans bars I would order them from you too.
I've still got time, I am ordering on Tuesday and wont take delivery until April. In the mean time I have your site book marked. Right now it looks like BMW aluminum skid plate that I will get pc'd, unless you can get a Holan in and fitted. Come in black?
2009 GS500 $5 off your SmugMug Photo Hosting Account Discount Code -gZGyUIZz6nv0w |
12-27-2009, 09:39 PM
#5 |
Oddometer: 84
sent you an email, im in vancouver and have a f800gs you can dingle with
live life today |
12-28-2009, 12:09 PM
#6 |
Tree Farmer Adventurer
Oddometer: 234
That looks kind of familiar. Although they did a pretty good job!
12-28-2009, 12:31 PM
#7 | |
Oddometer: 877
well... they're both made out of aluminum if that's what you mean. Hope I'm not in a police line up with you!
12-28-2009, 01:18 PM
#8 | |
on a mission...
Oddometer: 837
I too am interested to see how it will work with all the Giant Loop Great Basin. I'll let you know on that as I find out more. Incidentally that is specifically what the rear centre slot is designed to work with. As far as availability is concerned once we are done with all the testing it will go into production very quickly...I am gunning for early Feb. Zacharia_11; Alright new bike! The second version of the skid plate will be designed to accommodate more engine bar including the Holans. I'll keep you up-to-date on that too. It will be black powder coated as well, same as the top rack will be in production. Backroadsandbeyond; thanks for the offer and I'll take you up on that! TreeFarmer; that is one heavy duty rack plate! How thick is that?
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes & Giant Loop for Canada www.motooverland.com |
12-28-2009, 01:42 PM
#9 | |
11th Assassin
Oddometer: 248
I'll be checking back frequently... thanks!
12-28-2009, 04:28 PM
#10 | |
Even my posing is virtual
Oddometer: 2,513
Rack
That rack looks awesome. I have the Rotopax mounted to my Touratech rack but like your setup a lot better. I have the SW Moto side racks and they mount like the racks shown so it should fit. If you need a tester in Canada let me know. I'll probably be buying one as soon as they are for sale anyways.
04 Toyota Sienna, new wipers for 2011!! Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!! Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway, Website - http://www.apormc.com/ Vids - http://www.youtube.com/user/Motoriley?feature=mhum |
12-28-2009, 08:21 PM
#11 | |
on a mission...
Oddometer: 837
![]() I was a little surprised by the thin gauge of the BMW plate and the rivets when I first saw it. Our plate is mounted with welded CNC aluminium inserts and it is the more typical 4mm (.160") for the right amount of strength. Good welding by real humans too ![]() See pic below ... crappybiker; I like to hear all feedback but I may have selective hearingActually it is not nearly as obvious in real life...nevertheless the new version wouldn't have room for the whole MOD and so future versions will just have the M like the top rack, as will the KLR skid plate. Motoriley; Thanks...and I am in Canada too, just the other side. A better pic of the top rack in the forward position with the Rotopax 1 gal. on the side. It tucks in perfectly. ![]()
12-28-2009, 09:53 PM
#12 |
MotoInsight
Oddometer: 929
Your past bash plate didn't work with the Holan crashbars. If you send me pictures of the updated design I should be able to give you idea if the new design will work. PM me.
Also - shouldn't this thread be in vendors?
Rob Werksman - Owner, Motorcycle Insight, LLC Adventure Motorcycle Depot | S1000RR Depot | F800 Depot | Twalcom USA North American Importer - Globescout, Twalcom, Wild@Heart, Hornig, AC Schnitzer (Motorcycle) |
12-29-2009, 06:31 AM
#13 | |
Oddometer: 234
Back to the original thread, sorry abowt the temp hijack. |
12-29-2009, 10:09 AM
#14 |
on a mission...
Oddometer: 837
TreeFarmer; Thanks for the comment! It's a little hard to tell in the first pic but the rack does indeed have a taper to it. You can get more of a perspective with the bigger pic below.
F800 Rob; Yip the current plate worked with Touratech (and most probably Git) engine bars only. Some people like the increased coverage and think I should do two versions. Any thoughts y'all? There seems to be a lot of the Git set up out there and I think a good part of that is the front and side coverage of their skid plate.I was allowed to post in Beasts 'cause it was a plea for help as I was looking for people with various types of engine bars to fit the prototype skid plate with, and to get feedback. It is also because these are prototype parts we are talking about. When they are in production they will go to Vendors. Dave www.motooverland.com ![]()
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes & Giant Loop for Canada www.motooverland.com toowheels screwed with this post 12-29-2009 at 10:29 AM |
12-29-2009, 11:25 AM
#15 |
just passin' through
Oddometer: 4,135
The Great Basin will work with any of those racks shown as long as the edges and slots are rounded (tumbled or filed smooth). If not, the metal will saw right through our Ballistic Cordura webbings. As tough as it is, no webbing or strap material will survive the CNC edges.
We are looking at an '09 F800Gs and hope to pull the trigger before the end of the year (3 more days!!?). Have never owned a BMW but this one looks like it'll fit nicely in the barn.
