Old 12-27-2009, 02:50 PM   #1
TimTowtdi OP
TimTowtdi's Avatar
Oddometer: 242
Airhead Rear Main Seal
I have the rear main installation tool jtwind sells. In the instructions he mentions two different depths for the seal to be installed to. It is differentiated by whether or not the block is machined in the area of the main seal.
I just installed a new seal on a 76 R90 and used the deeper setting because when I tried the setting for a block that has not been machined, the seal rubbed on the flywheel.
What were the year breaks for the later and earlier seal depths? Does anyone have pictures of both? Jtwind?
Tim
TimTowtdi is offline   Reply With Quote
Old 12-27-2009, 03:57 PM   #2
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
Tim: Am going to do mine this week so I am all ears to hear what you learn.
Tom
Infracaninophile is offline   Reply With Quote
Old 12-27-2009, 05:09 PM   #3
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,476
I've never known where the year break is either. I tell folks that when it doubt put it in at the shallower setting and if it isn't deep enough it will be obvious and you can set it deeper. Alway helps to make note of how deep the original was in also.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 12-27-2009, 05:15 PM   #4
TimTowtdi OP
TimTowtdi's Avatar
Oddometer: 242
Ok. Thanks. I am thinking it is somewhere around 1975 or earlier. Probably a pre 1976 thing. I found this page by and he has a note in it about that being only for the older seals according to Oak. I wll look into that.
Tim
Times are GMT -7.   It's 12:10 PM.
